| jonboy22 |
 jonboy22 Crazy Courier
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 12:40 - 28 Jun 2006 Post subject: |
The classic look does have a certain appeal compared to the knee down, ragging the nuts off, plastic fantastic sports bikes of today.
What about going to a Triumph or Ducati dealers and test riding one of there classic cafe racers? This may give you a modern day feel for the classics. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| feef |
 feef Energiser Bunny
bullet? that's not a vintage bike...
that's a classic. Vintage would be like the 1912 Raleigh I was riding the other week, lever throttle control, single back brake operated by the left foor, and a right hand gear shift
Bullets are reliable transport, and you can still get them new for £not-a-lot.
a ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating |
| jonboy22 |
| jonboy22 |
| feef |
| thx1138 |
 thx1138 World Chat Champion
| TheShaggyDA |
 TheShaggyDA Repost Police
 Posted: 13:53 - 28 Jun 2006 Post subject: |
I sold mine a few weeks ago, as I need something that can handle a motorway commute, and I've only room for one bike.
It was a 2004, 500cc electric start model, right hand change. The newer bikes come with a pile of plumbing to get through emissions regulations, this of course was junked from day one. I had a freer-flowing airfilter and exhaust put on, and the front sprocket was upped by 1 tooth, which brought the revs to a more relaxed level for cruising.
Since I had it from new, I had to do the running in for the first 1000 miles. With the above mods, that meant 40mph for the first 300 miles, 50mph for the next, 60 for the remainder. Without the mods it would have been 10mph lower. These bikes NEED to be run in carefully, which is why I opted for a new one rather than second hand.
You have to bear in mind that these bikes are 1950's technology, designed for 1950's roads. 1930's technology, if you consider the Albion gearbox The gearbox is clunky, and has random neutrals between each gear. There is a 5 speed, left hand change option, but I haven't tried one of those so can't comment. These are supposed to be a lot smoother. I also fitted heavier clutch springs, as it slipped with my lardy 18st weight on it.
Once run in, they are more than happy to cruise at 55mph, have a top end of 75-80mph, and will return 70+mpg. I averaged 72mpg.
Maintenance is a must, but servicing is extremely easy. This is not a bike you can get on and ride with no thought to the basics. Spares are cheap and plentiful; Hitchcocks have everything you need. If you have no mechanical sympathy, this is not the bike for you. Get a copy of Pete Snidal's service & maintenance CD, it has lots of info in it.
It's also a bike that you need to keep clean, as the amount of alloy and chrome will soon start looking shabby. I used mine through the winter, and it took a long session to clean back up again afterwards.
There's not much performance wise between the 350cc and the 500cc - the 350 is easier to start and less vibey, the 500 has a bit more torque so if you want to load up with camping gear/pillion this would be the better option.
There's a number of mods you can make relatively easily to improve reliability; lighter rockers, electronic ignition, and for the 500 an uprated oil pump. I didn't bother, but had I kept the bike I might have done as the bike got older. F2 Motorcycles (see below) do this as standard with the new bikes they sell.
The brakes and suspension are adequate for the bike's performance, if you are used to disk brakes, then you will be in for a shock, but there's gobs of engine braking so I quite often wouldn't have to touch the brakes at all when I was out on it. It does wonders for you anticipation skills There is a front disk conversion available though, if you really want to.
It's definately grinworthy riding it. The exhaust note of a single can't be beaten, and since you're not teararsing about, you do feel more relaxed and you can take in the scenery. The square section tyres might put some people off, but at the speeds you'll be going you won't be trying for kneedown anyway. Avon AMs are a common upgrade to the original equipment SMs.
Two dealers I've personally dealt with, one in Cambridge (Haywards) and one in Banbury (F2 Motorcycles) - both are very helpful, friendly and knowledgable.
Would I have one again? Yes, as long as I had something else as an everyday bike that can put up with a bit of neglect. If you've got any questions about them, I'll be happy to answer  ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
| mr.z |
 mr.z World Chat Champion
 Posted: 13:59 - 28 Jun 2006 Post subject: |
I do like the idea of running an old classic but bikes have come a looooooong was in terms of relyability.. propper vintage bikes have to be treated with extreeme care (run one at 75% for long on a run out and your going to have problems..)
https://www.classichondamotorcycles.co.uk/bikes/bikes.asp
Just a thought but have a look here, personally i very much like classic japanese bikes, many perfect for bimbleing and still able to use them as relayable transport...
Another suggestion..
Go for a URLA DNEPR COSSACK similar, they are more or less replicants of the 1940's bmws, will do 60 or so comfortable and are sturdy as a sturdy thing and have piles of carracter.. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| TheShaggyDA |
 Posted: 14:05 - 28 Jun 2006 Post subject: |
I agree, a Ural would be another candidate - again F2 is the place to go for those. I'm currently watching this on eBay. ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
[i:6e3bfc7581]But still I fear and still I dare not laugh at the madman...[/i:6e3bfc7581] |
| map |
 map Mr Calendar
 Posted: 14:12 - 28 Jun 2006 Post subject: |
As an alternative you could go for the classic looks but with modern machinery/electrics/etc. I'm thinking Kawasaki W650, although others may fit the bill. I think the W650 was dropped in 2006 but I'm sure they're out there (via MCN site I'd say ballpark £3K, maybe less).
https://www.kawasaki.co.uk/Objects/000000B630D01331.jpg
Ok, purist and those dedicated (fanatical ) supporters of genuine older bikes may think it's the spawn of the devil and shun you but from what I've been told it'll do everything you need it for.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| mr.z |
 Posted: 14:14 - 28 Jun 2006 Post subject: |
Yeh they go for stupid prices on ebay sometimes, has to be said they wont be any good for motorwaying either though..
I'd love a twowheel drive ural sidecar outfit someday to mess about offroading...
Order of worth geting.. Ural - Dnepr - Chenshing (best to worst build quality) cossacks were a mix of urals and dneprs and anything they could get their hands on it seems.
When you say your watching it do you mean you might get it? can i have a go?  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| TheShaggyDA |
 Posted: 14:18 - 28 Jun 2006 Post subject: |
No, I won't be buying that one. It ends in 8 hours, and there's no way I'm getting to Macclesfield today. I won't buy a bike unseen, and if "it will sail through it's MOT" then why didn't they get one for it - it would have pushed the price up considerably. ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
| thx1138 |
| gimpy limp |
 gimpy limp Nearly there...
| Zimbo |
 Zimbo World Chat Champion
| DAF |
 DAF Trackday Trickster
 Posted: 00:02 - 29 Jun 2006 Post subject: |
Good thread
I've been interested in getting a WWII military motorbike as a hobby/ project/ show bike. Something like this would be really cool;
https://www.astory.com/motorcycle/841dc.jpg
It's an Indian Model 841. Does anyone have any experience of bikes that old in terms of restoration, maintenance etc?
Should hopefully see a few military bikes of that era in the forthcoming War & Peace show so looking forward to that event very much. ____________________ 2005 Yam Fazer (FZ6-S) |
| MikeH |
 MikeH Brolly Dolly
 Posted: 00:12 - 29 Jun 2006 Post subject: |
Those Royal Enfields are built in Indian sweat shops with recycled bean tins mates got one, wouldn't touch a new one with a barge pole.
If you want retro feel you can't go far wrong with a good old Brit thats still made here:
https://www.webbikeworld.com/triumph-motorcycles/triumph-scrambler/triumph-scrambler.jpg
https://www.webbikeworld.com/triumph-motorcycles/triumph-scrambler/triumph-scrambler-left.jpg
https://www.webbikeworld.com/triumph-motorcycles/triumph-scrambler/triumph-scramber-rear.jpg
The twin-cylinder Scrambler adds a new twist to the Modern Classics range. A fresh take on Triumph’s past, the Scrambler is a redefinition of the bikes made famous by 50’s thrill-seekers such as Steve McQueen into a contemporary urban context.
A ‘do anything, go anywhere’ kind of bike, inspired in part by the relaxed culture of sunny California and in part by the stylishness of southern European scooter aficionados, the Scrambler has been specifically developed for a particular group of riders currently underserved in the market.
While diverse in their demographics and riding experience these riders share the view that motorcycling is great fun, socially acceptable and a liberating experience. Crucially though, they aren’t interested in riding fast and are not motivated by performance or other benchmark figures.
As a result these riders desire a bike that’s easy and un-intimidating to ride, with or without a passenger, in the rough and smooth parts of town or out and about on a longer jaunt. Added to this is a wish for the bike’s design to make a distinctive, personal statement that appeals to and is understood by both their biking and non-biking peers. Enter the Scrambler.
Very few motorcycles can claim to be unique but the Scrambler, thanks to authentic styling cues such as the flat seat, small headlight, knobby tires and upswept pipes, is certainly one of them. Only Triumph, with the brand’s strength and sense of its own history, could credibly produce such a machine, creating a whole new niche of motorcycle in the process. ____________________ Busa Junkie |
| jonboy22 |
| finpos |
 finpos World Chat Champion
| veeeffarr |
 veeeffarr Super Spammer
| gimpy limp |
 Posted: 12:20 - 29 Jun 2006 Post subject: |
that's nothing, you want to try drum brakes with a sidecar attached and the owner sitting in it any slight camber in the road at 30 or above is terrifying if your not expecting it. I went to put my foot down on the floor once or twice  ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
| Nath |
 Nath World Chat Champion
| gimpy limp |
| Nath |
 Posted: 13:00 - 29 Jun 2006 Post subject: |
eh up
The bike is doing great. It burns a little oil, and occasionally drops onto 3 cylinders in heavy rain, but otherwise it hasn't let me down. All i've had go wrong is a broken throttle cable. Unfortunately I've only got about 2000miles left in my tyres so I'm gonna have figure out where will be easiest and cheapest to buy some more.
Norway was great, but the weather turned bad and then I got a fuckin massive speeding fine which made it hard for me to enjoy those mountain roads any longer, so I headed south through finland. I'm now in Poland, and am using the internet for only the second time in 3 weeks. The speeding fine doesn't seem to have appeared on my credit card statement yet, so I'm preying that the police took pitty on me and ripped it up after I rode away. However more than likely it's just taking its time to come through For going 12mph over the speed limit they fined me 400 fucking quid. Bunch of robbing bastards
Did you get your engine sorted in the end? I would be interested to hear if you fixed the problem that was causing it to stutter at high speed. ____________________ Hard livin', hard luck. |
The last post was made 20 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
