| Gazdaman |
 Gazdaman I did a trackday!!!
| NSR Mick |
 NSR Mick World Chat Champion
| Lawnie |
 Lawnie Nearly there...
 Posted: 13:32 - 29 Jun 2006 Post subject: |
Is your external HDD connected via USB 1.1 or 2.0? If it's the former, you might find that the performance of the OS will be severely hindered by the limited bandwidth of the interface. If it uses FireWire instead, it'll be fast enough regardless of which baud rate.
I have a dual boot system - Windows XP and C:\ and Windows 2000 on D:\. The reason for doing so was because some applications that I use hate XP. It really is easy to do
You'll be asked during the system boot which OS you wish to use. Depending on your BIOS, it will automatically default to the first OS after x seconds, if you haven't manually made a selection. |
| Gazdaman |
| Lawnie |
| NSR Mick |
 Posted: 13:53 - 29 Jun 2006 Post subject: |
I like to keep my data away from my os and with all the apps and docs installed on my laptop it uses 17gb.  ____________________ If you dont like the way that I ride.......Stop trying to keep up!!! |
| Gazdaman |
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| senna_f4 |
 senna_f4 Scooby Slapper
 Posted: 11:25 - 30 Jun 2006 Post subject: Re: Dual booting from an external HDD |
| Gazdaman wrote: | Ok, here's the situation, I have a small form factor Dell PC with FreeBSD on it and an 80gig HDD.
I want to use that PC, since it's a good spec, but I want to dual boot XP.
Ok, 80gigs isn't really enough space for me. And the PC only has enough space for one internal HDD.
I have a good 20gigs of mp3s/movies on it, maybe I should just move those to an external HDD and then just have the 2 OSs on the 80gig.
Do I need to dual boot? I was thinking for things like using my scanner, and iTunes etc. Things that may just be a pain in the ass in unix.
I could just keep my XP pc under the desk and use my monitor switchbox if/when I need it...
Any views? Tips?
Gaz |
Gaz;
1. remove all user data to usb drive
2. repartion drive with any good partioning software that comes with BSD
3. on the generated free partion (about 10 to 20 gigs is OK for windows + applications : 2 - gigs for win, 1gig for restore, + 1.5 *RAM for swap and rest for apps and user data)
4. Install win XP on the partion created (you may format it to something lke fat 32 for windows to recogonise easily, so you can identify it) you may conver to ntfs(recomended)
5. After installation you system will only boot XP.
6. To fix it using your favourite boot manager fix the booting problem by chain loading XP (say using GRUB) or using the XP boot loader to chain load BSD. (GOOGLE is your friend )
Disclaimer: I hold nor reponsibility for anything that happens to you , your data, yuor PC or anything else
PS Only did this using Linux, XP and 2000 all on one pc + many dual booting Linux/XP combos
EDIT: Read this
https://www.devhood.com/tutorials/tutorial_details.aspx?tutorial_id=405 ____________________ "You don't know the power of the dark side." |
| Gazdaman |
| senna_f4 |
 Posted: 22:13 - 30 Jun 2006 Post subject: |
The Gimp https://www.gimp.org/ ____________________ "You don't know the power of the dark side." |
The last post was made 20 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
