Storing Bikes..
Dan 4RR
PostPosted: 12:52 - 30 Jun 2006    Post subject: Storing Bikes.. Reply with quote
Hi... A friend of mine has gone away on holiday and wont be returning until early August and has asked me to store his bike until he gets back. I have agreed to do this, but is there anything I should be looking out for when the bike is going to be stood in the same spot for 4-5 weeks without been riden? Bearing in mind that the bike will be stored in a dry, safe shed. Thumbs Up
Whosthedaddy
PostPosted: 12:55 - 30 Jun 2006    Post subject: Reply with quote
Regualrly start it (and take it for a quick spin Whistle )
Nitrogen in the wheels instead of air will be better for the tyres
Petrol 'de-gumming' additive to protect the carbs
veeeffarr
PostPosted: 12:56 - 30 Jun 2006    Post subject: Reply with quote
If you have the keys start it every couple of days for a few minutes, take it out for a ride if you can.
Dan 4RR
PostPosted: 12:58 - 30 Jun 2006    Post subject: Reply with quote
Whats this 'de-gumming' you speak off?
I do have the keys, so I'll probably just start it up every couple of days. Thumbs Up
Whosthedaddy
PostPosted: 13:00 - 30 Jun 2006    Post subject: Reply with quote
Its NOT redex, its something that prevents the carbs from becoming blocked by stake petrol.
I cant remember the name Embarassed Only cost £4 or so Thumbs Up
Davo
Davo To The Rescue!
PostPosted: 13:01 - 30 Jun 2006    Post subject: Reply with quote
I shouldn't worry too much, I left my R6 from November to Febuary without any problems, didn't do much to it.
Just left the bike on front & rear paddock stands to stop the tyre getting flat spots, took the battery out and left it on an optimate then put a cover over it.
Bendy
Mrs Sensible
PostPosted: 13:02 - 30 Jun 2006    Post subject: Reply with quote
For a month I wouldn't bother with anything special, other than sticking a charger on the battery if it's got an alarm that might drain it.
Finglonga
PostPosted: 13:11 - 30 Jun 2006    Post subject: Reply with quote
Won't need anything apart from battery charging the day before he comes back. The fuel won't go off in that short time. Wink
Andy Sez....
F.Y.Y.F.F.
map
Mr Calendar
PostPosted: 13:25 - 30 Jun 2006    Post subject: Reply with quote
VivaCity wrote:
Whats this 'de-gumming' you speak off?...
Try Silkolene FST Pro.
Yamaha also did a very good one but I haven't seen it on the shelves for a while.
One little tip, make sure the brake pads don't bind onto the discs. In other words store it dry and avoid any moisture/condensation where it's stored.
HTH Thumbs Up
Dan 4RR
PostPosted: 13:44 - 30 Jun 2006    Post subject: Reply with quote
How would stake petrol block the carbs, surley petrol stays in liquid form? Embarassed
I don't have a paddock stand so it's been left standing on it's side stand, would this cause flat spots if left in the same spot for periods of time?
Hi, the bike is going to be stored in a secure, insulated dry shed, so I hope this 'binding' of brakes wont happen.
Thanks. Karma Thumbs Up
Davo
Davo To The Rescue!
PostPosted: 14:26 - 30 Jun 2006    Post subject: Reply with quote
Not in a month, if the bike was to be left for a couple of years possibly.
As others have said, you won't need to do anything to it, just start it every so often, let it warm up to normal running temperature, that's about it.
craigs23
Mr Muscle
PostPosted: 15:41 - 30 Jun 2006    Post subject: Reply with quote
My bike was barely used over the 4 or so months of salted roads last winter. Just reguarly started it, kept an eye on the battery voltage, wheeled it around the garage every now and again, cleaned it a bit. seemed fine when it was finally unleashed at the beginning of May.
The last post was made 20 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 76.51 Kb
