| bauhaus1100 |
 bauhaus1100 Derestricted Danger
| tonyyzf |
 tonyyzf Brolly Dolly
 Posted: 08:52 - 28 Jun 2006 Post subject: |
When you say you change your oil once a year regardless of miles, how many miles do you do in a year? I would recommend that the oil should be changed every 4,000 miles maximum.
If the oil was black coming out then any new oil going in will turn black almost instantly, it will pick up all the old oil that you can't get out by removing the drain plug. If you want you could flush the engine with cheap oil a couple of times to clean it up, put oil in and run it for 5-10 minutes and drain and discard again, this should keep the engine a bit cleaner.
As for the starter, it should come out with a bit of a wiggle around, check to see if its functioning once its out before stripping it, don't know if you will be able to get replacement brushes or just get another starter, I know someone who made brushes from ones out of a washing machine motor. If its burnt out then its a replacement.
If the starter appears ok then you should check the starter gear, just in case something has jammed.
Did the smoke come from the starter? or the wire attached to it? ____________________ Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/ |
| bauhaus1100 |
| finpos |
 finpos World Chat Champion
| bazza |
 bazza World Chat Champion
 Posted: 17:27 - 28 Jun 2006 Post subject: |
XV1100 starters are notorious for being made of cheese and not lasting as long as a boy band...  ____________________ "That's it. You people have stood in my way long enough. I'm going to clown college."
'98 Ducati 750SS, '08 Suzuki GSX650F ©2004-2014, Bazza's Harmless Banter |
| bish777 |
 bish777 World Chat Champion
| bauhaus1100 |
| bish777 |
 Posted: 23:04 - 29 Jun 2006 Post subject: |
| bazza |
 Posted: 23:31 - 29 Jun 2006 Post subject: |
And if you find the cnut who bought my XV1100 and lobbed into a ditch 3 days later on there, give him a slap from me...  ____________________ "That's it. You people have stood in my way long enough. I'm going to clown college."
| Paddy Blake |
| bauhaus1100 |
 Posted: 15:20 - 30 Jun 2006 Post subject: |
I'm not too sure what you're talking about, like a kick start? There is a cover on the left side of the engine to the left of the Starter. Is this possibly what you mean? I still have another day before I can get at it anyway. As far as the link for parts is concerned, I'll take a look but I'm sure shipping to Canada would be pricey. If it is the starter I should probably search here
Thanks |
| feef |
 feef Energiser Bunny
| bauhaus1100 |
 Posted: 15:43 - 01 Jul 2006 Post subject: |
I stated earlier that I was having a tough time removing the starter, in my Clymer manual it seemed simple enough, remove two bolts and a wire harness and bingo. I used a fair amount of force to try and get it out. I will attempt again tomorrow.  |
| bauhaus1100 |
The last post was made 20 years, 120 days ago. Instead of replying here, would creating a new thread be more useful? |
