nsr overheating PLEASE HELP
lee125
PostPosted: 14:28 - 03 Jul 2006    Post subject: nsr overheating PLEASE HELP Reply with quote
rite i whent out on the road on my nsr for the first time before i will write about it after i was out on it for about 5 mins got to 60 then the temp gauge was almost at red Evil or Very Mad i pulled over straight away and the radiator was cold everywere so i pushed it home took all the fairings off Evil or Very Mad just took the thermostat out fired it up and all the coolent water is circulating BUT when you rev it water like builds up out the expansion chamber and with a bubble on top and when you rev it high it fires it out everywere and i dont know why its doing this cause the headgasket is new the head and barrel were not warped so what else could it be as i want to fix it now and go out again any help will very very much appreciated thanks Thumbs Up
cbt passed Smile 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years
motorbikes010
PostPosted: 14:38 - 03 Jul 2006    Post subject: Reply with quote
Check for bubbles in the radiator. Exclamation Take off the radiator cap and start the bike up. Just idling reving until it reaches half way. This should cause the thermostat to open (First check it opens) and then the water should circulate and you'll see bubbles coming out. Mr. Green top it up and then close the radiator cap. This should stop it shooting out. Remember not to fill the expansion tank too much as the water level rises a little when the bike heats up to normal temp.
All of this info is in the NSR manual which you should consult. Its very helpful.
lee125
weird Confused i was revving it quite high before i came in and wrote this question whent out topped radiator up cos of the water splashing out and it seems to have fixed itself hopefully so im going to put it together and go on a short ride and see if its ok Thumbs Up
lee125
PostPosted: 14:39 - 03 Jul 2006    Post subject: Reply with quote
thanks for the reply motorbikes010
motorbikes010
PostPosted: 14:42 - 03 Jul 2006    Post subject: Reply with quote
Dont forget if its not fixed itself to get the bubbles out of the radiator. This is a common overheating problem and also incorrect 2 stroke.
Twisted Evil Smile
lee125
PostPosted: 16:10 - 03 Jul 2006    Post subject: Reply with quote
put it together went out and its still doing it and im so pissed off now cause its the first day today im aloud on the road and it hasnt run properly yet Evil or Very Mad please help me
lee125
PostPosted: 16:11 - 03 Jul 2006    Post subject: Reply with quote
how do you get the bubble out Question Thumbs Up
lee125
PostPosted: 17:16 - 03 Jul 2006    Post subject: Reply with quote
ive taken the cylender head off and the gasket has been leaking so im skimming the head and that then putting it back together should fix it this time hopefully Praying
motorbikes010
PostPosted: 22:28 - 03 Jul 2006    Post subject: Reply with quote
Read my first reply to get the bubbles out of the radiator. Does the cylinder head look warped? Did you tighen it down properly?
Re-assemble the top end and fill the radiator. Then leave the radiator cap off and start the engine ( You will need to obviously get someone to hold the petrol tank. Let it run and you'll notice when the temp gets to half the thermostat will open which will allow the coolant to circulate and any excess air in the system will come out. Bubbles... When this stops cut the engine, top up the coolant when the level goes down again. put the cap back on and re-assemble and then go for a test run.
I strongly recommend you use castrol TTS 2 stroke and adjust the oil pump slightly on the open side so it uses a little more oil.
whilst you run in.
lee125
PostPosted: 00:38 - 04 Jul 2006    Post subject: Reply with quote
thanks mate but i have just been out for a ride on it for an hour or so and its fine now thanks for the help though Thumbs Up
The last post was made 20 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 66.08 Kb
