Any Delphi programmers?
NSR Mick
PostPosted: 15:08 - 03 Jul 2006    Post subject: Any Delphi programmers? Reply with quote
I need to write a simple application that will open one of 4 .pif files depending on which button is pressed.
The problem being is that I'm a complete noob when it comes to programming. Embarassed
veeeffarr
PostPosted: 15:09 - 03 Jul 2006    Post subject: Reply with quote
Why Delphi?
NSR Mick
PostPosted: 15:34 - 03 Jul 2006    Post subject: Reply with quote
Because thats what I've got access too. Thumbs Up
NSR Mick
PostPosted: 15:51 - 03 Jul 2006    Post subject: Reply with quote
Sorted it now, thanks for looking. Thumbs Up Mr. Green
veeeffarr
PostPosted: 15:55 - 03 Jul 2006    Post subject: Reply with quote
Sorry mate, don't know any delphi, but it is evil Razz
map
Mr Calendar
PostPosted: 16:00 - 03 Jul 2006    Post subject: Re: Any Delphi programmers? Reply with quote
gsxrmick wrote:
...simple application that will open one of 4 .pif files depending on which button is pressed...
Ok, how did you sort it?
My solution would have been, assuming the pif is to open archive files...
In Delphi create your form with the 4 push buttons.
Then on the event OnClick for each of the buttons add the following:-
LoadExe('<path and name of exe to open pif>', '<pif name to open>');
then declare a function to do this (needs to use Delphi ShellAPI)
function LoadExe( ExeName, Params : string; ): HWND;
var
pcParams,
pcName : PChar;
handle : HWND;
begin
pcParams := StrAlloc(1024);
pcName := StrAlloc(1024);
StrPCopy(pcParams,Params);
StrPCopy(pcName,ExeName);
handle := ShellExecute(0, 'open', pcName, pcParams, NIL, SW_NORMAL);
StrDispose(pcParams);
StrDispose(pcName);
result := handle;
end;
.. add your own error handling if handle <= 32 if you want.
No doubt you've found something easier Confused
HTH Thumbs Up
NSR Mick
PostPosted: 16:02 - 03 Jul 2006    Post subject: Re: Any Delphi programmers? Reply with quote
map wrote:
If you don't understand what I've written please get a grown up to help and don't use any sharp objects unsupervised.
PMSL. Thumbs Up Mr. Green
JonT
PostPosted: 19:01 - 03 Jul 2006    Post subject: Reply with quote
Delphi is actually rather good toby :p
I'm forced to use Java in uni, was forced to use Delphi in college, and first learned using visual basic.
I can just about do C/C++ if I keep a reference card about cos once you know one language its just a matter of syntax (and other nasties like pointers) to deal with.
If I have to write an application I go with Delphi first every time. It is amazingly quick to throw together some applications with. Visual Basic has become good recently but i just have a personal dislike of its syntax.
Java is long winded as hell, takes me a while to write anything in it, but it has its advantages (good as applets, nice not to recompile for different systems, not that I'm ever asked to do anything none windows anyway).
At the end of the day my personal prefference doesn't matter, its just nice to be able to say yes when your employer wants something done a certain way.
The last post was made 20 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 59.69 Kb
