Minor Problem
phantomtek
Lil Joe Tek
PostPosted: 22:47 - 03 Jul 2006    Post subject: Minor Problem [HELP!] Reply with quote
Well today I put my mates new PC together, and set it up to run properly. His old one went bang a while ago, but the HDD is intact with all his music on, so I told him I could take it and put it into my PC and retrieve the music and give it back to him.
I got it home and plugged it into my, booted up my PC and sure enough it was all there, his whole HDD infront of me. Now the music is stored inside his Documents and Settings, which unfortunately is locked down because of the restrictions he set to stop people getting in. I tried using the HDD as my master instead of slave, and when I booted up and tried to log in it told me I need to activate Windows in order to let me in, or else I get logged out. I really don't want to have to go through all that just for 7 GB of music so has anyone got a way into the protected Documents and Settings?
Maybe if I drag and drop into my PC the encryption will be removed?
Help! Thumbs Up Cheers. Karma
Silver
PostPosted: 22:54 - 03 Jul 2006    Post subject: Reply with quote
Windows XP I assume. The reason that it said you have to reactive Windows is that it detected too many hardware changes (no surprise since the drive's in a completely different machine). Is there a reason why you can't do this?
As for getting access to the data, I'm sure it can be done although I've never had the reason to try. Does it ask for a username/password when you try and access Documents and Settings?
As for dragging and dropping, I can't see that working to be honest. It'd be a major security flaw.
phantomtek
Lil Joe Tek
PostPosted: 23:01 - 03 Jul 2006    Post subject: Reply with quote
Not really, I just don't want to reactivate Windows on that HDD and then have to do it again for my machine, also I am not too keen on having to ring them up and explain myself to them, they will think I am really dodgy Laughing
No it just says this folder is empty, just like it does when I do it on my own machine, it is quite annoying but a good feature to have.
Yeah I agree, silly idea Sad
Silver
PostPosted: 00:02 - 04 Jul 2006    Post subject: Reply with quote
Why would it? After you'd finished, you'd be using your hard drive with your Windows installation. As far as it's concerned nothing will have changed.
veeeffarr
PostPosted: 00:25 - 04 Jul 2006    Post subject: Reply with quote
Can't you set it as slave and convert the filesystem on the drive back to FAT32?
In CMD
convert x: /fs:FAT32
Davo
Davo To The Rescue!
PostPosted: 00:32 - 04 Jul 2006    Post subject: Reply with quote
Convert will only allow a conversion from FAT32 to NTFS, not vice versa. Unfortunately the only way to do it is to get the OS up and running from the spare drive, as you need the encryption key that is associated to the user account (your friends).
veeeffarr
Well use partitionmagic and convert it to FAT32 then
syl
PostPosted: 00:39 - 04 Jul 2006    Post subject: Re: Minor Problem [HELP!] Reply with quote
Right click it and alter the security properties (use the advanced button, click owner and then change the ownership to you). I'm assuming you hare administrator rights on your own PC.
Basically:
https://support.microsoft.com/default.aspx?scid=kb;en-us;308421&Product=winxp
Current bike: Kawasaki Z750S
sickpup
Old Timer
PostPosted: 01:29 - 04 Jul 2006    Post subject: Reply with quote
Or Knoppix may well get around the security.
veeeffarr
PostPosted: 01:36 - 04 Jul 2006    Post subject: Reply with quote
Is Knoppix compatible with NTFS filesystems?
senna_f4
PostPosted: 02:27 - 04 Jul 2006    Post subject: Reply with quote
1. Hook hardisk up eithe directly of through usb/fw caddy
2. Download and burn the latest knnopix cd
3. Boot on knnopix cd, hdd should automount in RO mode (Full RO NTFS support available)
4. If not use the mount command to mount it
5. Copy all the data to another hdd (FAT32, EXT3 etc) or to a network location using the built in ssh or samba server.
6. Alternatively burn to CD/DVD or at your own risk activate the RW support for NTFS and transfer files to a native ntfs drive
7. Remeber to always unmount any usb/fw drives the command is umount and the path.
Hope it helps
"You don't know the power of the dark side."
PostPosted: 02:53 - 04 Jul 2006    Post subject: Reply with quote
Therefore, this being a microsoft operating system we are talking about, it's worth a try. Wink
veeeffarr
PostPosted: 09:54 - 04 Jul 2006    Post subject: Reply with quote
Dragging and dropped will work on a FAT32 file system.
NSR Mick
PostPosted: 10:00 - 04 Jul 2006    Post subject: Reply with quote
All you need to do is take ownership of the folder.
phantomtek
Lil Joe Tek
PostPosted: 17:26 - 04 Jul 2006    Post subject: Reply with quote
How do I do that, what dmahon said has worked on one of the folders, but not all Sad
NSR Mick
PostPosted: 17:33 - 04 Jul 2006    Post subject: Reply with quote
right click the folder, go to properties then advanced. Then go to owner select your logon account in the middle window and then tick replace owner on subcontainers..... then apply ity and away you go full access. Thumbs Up
NSR Mick
PostPosted: 17:34 - 04 Jul 2006    Post subject: Reply with quote
then again we've said the same thing.
feef
Energiser Bunny
PostPosted: 17:41 - 04 Jul 2006    Post subject: Reply with quote
Linux can now support reading NTFS filesystems, but I believe writing is still shakey..
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
phantomtek
Lil Joe Tek
PostPosted: 19:25 - 05 Jul 2006    Post subject: Reply with quote
Thanks to all who helped, I have now got into the files I did as dmahon and gsxrmick suggested, restarted in Safe Mode then granted myself ownership of the folders, got access to it all.
Thanks alot. Thumbs Up
The last post was made 20 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.41 Sec - Server Load: 2.31 - MySQL Queries: 13 - Page Size: 106.21 Kb
