Author |
JonT |
 JonT Crazy Courier
Back to top |
kat250 |
 kat250 World Chat Champion
Back to top |
True Blue |
 True Blue World Chat Champion
 Posted: 20:18 - 15 May 2006 Post subject: |
Might be worth checking if your alternator is working correctly. Sounds like a low voltage problem. ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
Back to top |
Guest |
 Guest Brolly Dolly
 Posted: 22:10 - 15 May 2006 Post subject: |
yeh, stick a voltmeter across the battery and make sure you're getting 14+ volts when you rev it.
Failing that, connection loose or bad earth on the clocks like babykat says  |
Back to top |
crazymotorbik... |
 crazymotorbik... Nearly there...
Back to top |
the grim reaper |
 the grim reaper World Chat Champion
 Posted: 11:24 - 16 May 2006 Post subject: |
I had this on my Varadero and it was the battery on the way out. A lot of any bikes electrics, especially sensors, require a healthy 12V to even work in the first place. On the Varadero, the speedo sensor has three wires going into it, one is a 12V supply (the ground is supplied by the engine block) and the other two are the differential signals to tell the electronic speedo what speed I'm doing.
If it was the altenator, the battery would just die completely but, if the battery wasn't holding charge, as mine wasn't, running with the lights on puts enough strain on the battery to stop the sensors from receiving a proper 12V. Mine would die and then come back and die again and then come back again, speedo and temperature sensor. Running with the lights off saw everything come back to normal again, replacing the battery worked (so the new owner found out).
Cheers
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
Back to top |
JonT |
 JonT Crazy Courier
Back to top |
JonT |
 JonT Crazy Courier
 Posted: 22:11 - 04 Jul 2006 Post subject: |
Hi again, I've been continuing to suffer with this problem for nearly 2 months now, i've had it in the garage twice and they are still baffled.
All the connectors have been fully sprayed with WD40 to remove water as the problem, the left side block connector has been replaced by a water proof one.
I find it hard to beleive that the battery is on its way out becuase the bike starts like a champion every time! Sounds like a nice strong kick from the starter motor so its hard for me to think that this battery is dying (there is a chance it isn't a strong start just me thinking it is due to getting used to it, doubt it though).
If the alternator was working incorrectly surely the battery would of died over the last two months (I don't charge it seperately).
The bike had not received any physical damage in over a year before the clocks started going funny so I doubt its damage from impact.
Something i'm not sure if i've mentioned is the fuel light always flashes whenever the clocks die or come back to life.
Please help me! (will give good karma :p) |
Back to top |
Handsome |
 Handsome World Chat Champion
Back to top |
Phil_G |
 Phil_G Traffic Copper
 Posted: 22:17 - 04 Jul 2006 Post subject: |
a new battery will cost around the same as an hour of your mechanics time - why not give it a punt - and if it doesn't cure it, then fetch the battery back to the shop for a refund?
Also, I presume your mechanics checkedout all the earth points on teh bike to ensure a good solid connection? ____________________ 1997 Kawasaki ER 500 A1:- Once again, Its merely crap  |
Back to top |
krebsy |
 krebsy World Chat Champion
Back to top |
the grim reaper |
 Posted: 12:12 - 05 Jul 2006 Post subject: |
FWIW, my Varadero also started easily but it was still the battery that was the cause of the problem. The biggest drain of current from your battery are the lights, 55 Watts at 12V gives a current draw of 4.5 amps. Your battery has enough juice to turn the engine over, as mine did, but, when you've been riding for a while with the lights on, the battery output drops below 12V because the battery requires a bit more current to charge it than normal but the lights are taking it all. Once the battery output drops below 12V, a lot of the sensors on your bike will stop working because they are 'active' sensors (they require a power supply to work).
Buy a battery, check your charging circuit and then notice how it doesn't happen again
Cheers
Back to top |
The last post was made 19 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
