R6, '99 T-plate, engine noise.
R6boyz
PostPosted: 23:54 - 07 Jul 2006    Post subject: R6, '99 T-plate, engine noise. Reply with quote
My R6 with 14000miles on it has developed a bit of an engine noise , worse when cold, virtually non-existent when hot. doesnt alter at all when the clutch is in or out, is worse when the revs are lifted to about 1500/2000ish, doesnt sound like a tappet, maybe piston slap but again, not realy the right sound. I thought maybe timing chain or tensioner problem? it is almost like a very loud fuel pump tick?? thats the best way to describe it.
have any of you had similar problems/experiences? I aint checked the tappets for a while, about 4000miles, but were fine last time.
any advice/pointers would be good. Confused
PostPosted: 00:23 - 08 Jul 2006    Post subject: Reply with quote
Is the oil level OK?
Have you checked the cam chain tensioner? TBH top end rattles are likely to be the CCT on japanese four cylinder engines.
R6boyz
PostPosted: 00:33 - 08 Jul 2006    Post subject: Reply with quote
Hi, yes, oil level is fine. had new oil and filter on a couple of months ago but made no difference to the noise. Sad
TOM M
PostPosted: 00:40 - 08 Jul 2006    Post subject: Reply with quote
Could be valve clearences???
Now owner of a 1200 Bandit
R6boyz
PostPosted: 00:52 - 08 Jul 2006    Post subject: Reply with quote
yes, could well be. am hoping thats all it is. will find out in the winter when i pull the lid off to check, as long as nowt lets go before then!! should've stuck with me old VFR, or even me 'Blade!! lol Wink
finpos
PostPosted: 13:59 - 08 Jul 2006    Post subject: Reply with quote
Mystery ticking that goes away with temperature very often down to the exhuast gaskets starting to give up (i.e. your exhaust is blowing through a tiny hole until everything heats up and expands, closing the hole)
finpos.
Phoenix
Twisted Firestarter
PostPosted: 15:11 - 08 Jul 2006    Post subject: Reply with quote
Exhaust header rattles due to broken/leaky/missing gaskets are usually pretty distinctive, a metallic clattery noise, can usually feel a blow too if you put your hand there, carefully. More likely to be your valves as the clearances change when your engine heats up which is why it goes away, hence you need a stone cold engine when you check the adjustment.
It's unlikely to be a camchain/tensioner problem, that would get worse when the engine gets hotter and the chain loosens up, and its once again a different sound, like a metallic clackety clack.
R6boyz
PostPosted: 20:07 - 08 Jul 2006    Post subject: Reply with quote
ive heard exhaust manifold gsk's/splits and it doesnt sound like that, but of course that doesnt mean it isnt that! i have had cam chains be noisy only when cold due to the tensioner bleeding dry when standing...but only on car engines.
The last post was made 20 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 54.52 Kb
