Down gearing
curryfishball
PostPosted: 10:39 - 12 Jul 2006    Post subject: Down gearing Reply with quote
I want to down gear my Gixxer 600 by upping the rear sprocket by 2. Is there any way to recalibrate the speedo so that its correct after the change? Its a K5 model if that helps.
Thanks
The world is a book, and those who do not travel, read only a page.
the grim reaper
PostPosted: 13:21 - 12 Jul 2006    Post subject: Reply with quote
I just do a mental change on mine, I have one tooth less on the front and I have used a GPS to check my speed, it's 10% over reading, so I know that 55mph is a true 50mph.
Other than that, it could be done with some clever electronics but you;d have to capture the existing signal at 10mph intervals and work out how to adjust it.
My bike now wheelies nicely in 2nd off the throttle though, as I found out this morning Mr. Green
Grim
curryfishball
PostPosted: 10:13 - 14 Jul 2006    Post subject: Reply with quote
Thanks, I was hoping I could adust it, would be nice to see the actual speed rather than working it out.
Do you know what the difference is for chain size? My bike uses 525 as standard, however when I was on the Renthal site, it says there is a 520 conversion kit for mu bike. Is it the width of the chain or something?
Thanks
PostPosted: 10:21 - 14 Jul 2006    Post subject: Reply with quote
You can get a box to adjust your speedo, but as mentioned you may make it 'righter' anyway, depending on how it is out.
520 width chain is narrower than strandard and will give you slightly better acceleration/pickup for a possible slightly reduced chain life.
You would need to replace both sprockets and chain at once to convert to 520.
curryfishball
PostPosted: 10:30 - 14 Jul 2006    Post subject: Reply with quote
Thanks, I'll give that a try and see how it goes. Should be fun with faster acceleration from down gearing it!
Odie
PostPosted: 21:11 - 14 Jul 2006    Post subject: Reply with quote
where is your speedo drive taken from?
The front wheel or the rear wheel?
Bendy
Mrs Sensible
PostPosted: 21:27 - 14 Jul 2006    Post subject: Reply with quote
You wants one of these
https://www.speedohealer.com/images/sh_1_sm.gif
curryfishball
PostPosted: 23:49 - 14 Jul 2006    Post subject: Reply with quote
Very Happy
Thanks, that looks really good, costs quite a bit though! But at least I'll get an accurate reading and not have a super high mileage bike.
curryfishball
PostPosted: 23:56 - 14 Jul 2006    Post subject: Reply with quote
Oops, read the price wrong, I guess its not too bad Very Happy
brooky
PostPosted: 01:37 - 15 Jul 2006    Post subject: Reply with quote
I was always under the impression newer bikes took the speedo reading from some sort of pulses within the engine, Guess I'm way out. Embarassed
Suzuki GSX-R 750 K6.
Odie
PostPosted: 08:57 - 15 Jul 2006    Post subject: Reply with quote
I was thinking they took their reading from the front end.
Kram
PostPosted: 13:28 - 15 Jul 2006    Post subject: Reply with quote
you could get a bicycle speedo, and attach the magnet on the front wheel (brake?) somewhere and use that? would give an accurate reading
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
Odie
PostPosted: 20:14 - 15 Jul 2006    Post subject: Reply with quote
Your speedo works off the front wheel, that means that your speedo is set to that wheel size.
How would altering the gearing on the rear wheel affect a speedo that works off the front wheel?
Please some-one tell me, am i missing the point?
Bendy
Mrs Sensible
PostPosted: 20:21 - 15 Jul 2006    Post subject: Reply with quote
Lots of bikes don't work off the front wheel, they work off the engine or the front sprocket. So if you change the gearing, you change the ratio and the speedo will be wrong.
There's no chance a 2005 gsxr has a speedo driven off the front wheel.
fast_tzr
PostPosted: 22:47 - 15 Jul 2006    Post subject: Reply with quote
But surely if you don't change the front sprocket the speedo reading will still be the same?
curryfishball
PostPosted: 22:57 - 15 Jul 2006    Post subject: Reply with quote
if you increase the rear sprocket, the front will need to rotate more in order for the rear to travel the same distance. so you will get in increase in mileage, and also an increase in mph (but you are not actually travelling any faster)
Odie
PostPosted: 18:22 - 16 Jul 2006    Post subject: Reply with quote
No it wont affect the front sprocket if you change just the rear one the rear one.
Think about it, if the front sprocket stays the same size how will it affect the rear wheel and sprocket?
The rear wheel might be going faster if you put a bigger rear sprocket on but it will not change the front.
PostPosted: 18:28 - 16 Jul 2006    Post subject: Reply with quote
To turn the rear wheel one revolution, the front sprocket will now need to turn slightly more/less, thus it will effect the speedo.
curryfishball
PostPosted: 19:47 - 16 Jul 2006    Post subject: Reply with quote
if you have a push bike you can try if out yourself. keep the front sprocket constant, and measure how many cycles it takes you to move 20m, then increase/decrease the rear and repeat
Odie
PostPosted: 01:52 - 17 Jul 2006    Post subject: Reply with quote
[/quote]To turn the rear wheel one revolution, the front sprocket will now need to turn slightly more/less, thus it will effect the speedo.[/quote]
But its the front sprocket that is the drive not the rear wheel!
brooky
PostPosted: 02:03 - 17 Jul 2006    Post subject: Reply with quote
LOl, Yes the reading does come from the front sprocket , but that would only be correct if the rear sprocket was OEM.
Becuase the rear sprocket is up by two, the reading will be out becuase in the time it takes the rear wheel to spin once the front sprocket would probably spin a couple times more than what it would of originally, Hence tricking the bike into thinking its going faster than it really is.
HTH
J
Odie
PostPosted: 02:26 - 17 Jul 2006    Post subject: Reply with quote
There are a couple of things that are not being taken into consideration:
1) the gear box: This is pre set.
2) The front sprocket: This can be changed, bigger = slower acceleration better top end ( Very Happy ), smaller = faster acceleration slower top speed ( Crying or Very sad ). This is the drive sprocket
3) Rear sprocket: This can be changed, bigger = faster accelleration slower top speed, smaller = slower acceleration faster top speed.
You could change the tyres, that would also affect the gearing and top speed but not as noticable as changing the sprockets!
But my point is that the engine is the drive not the rear wheel so its the drive you should be looking at not the "final drive" for your speedo reading.
You will only get out what you put in.
Its the front sprocket that is driving the rear wheel not the other way round!
brooky
PostPosted: 02:29 - 17 Jul 2006    Post subject: Reply with quote
That is as simple as anyone can explain. Its really not that hard to understand.
Anyways, Im off to bed.
Odie
PostPosted: 02:35 - 17 Jul 2006    Post subject: Reply with quote
I know what you mean, my head hurts! Very Happy
DUCMANs
PostPosted: 21:39 - 19 Jul 2006    Post subject: Reply with quote
Exactly. And to calculate what you'll get out: https://www.xs4all.nl/~ator0437/gc/
Regards, DUCMANs
The last post was made 19 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 129.73 Kb
