| Sparks! |
 Sparks! Sir Tart-a-lot
| BigChris |
 BigChris Spanner Monkey
 Posted: 13:57 - 16 Jul 2006 Post subject: |
Ok firstly, unless your bike is really special the sum of the parts will not be greater than the sale of the total bike.
If you intend on swapping the drivetrain, be aware that like motorbikes you will need to swap the cogs on the back also. If your back wheel is buggered so badly, it could be more worthwhile getting a complete new wheel (minus tires etc).
Aggressors were entry level bikes for GT, one of the lowest in the range to have an alloy frame. Brand new they're about 350 quid, so i'd probably start looking somewhere about 100 and working from there.
Just to let you know, shimano are the bad boys for gears on bikes, and for a mountain bike you'd ideally want to be purchasing anything that says Deore, LX, XT, XTR or DX. Avoid everything else.
For chainsets, go for the above, and Truvative.
Sachs do good chains, but ensure that when you buy one it is compatible for the number of cogs at the back (8 and 9 speeds require thinner-than-standard chains).
If you measure the distance between bottom bracket (axel where chainset goes) to the middle of the top tube along the seat tube, that'll be your frame size.
let me know what size it is?  |
| Sparks! |
 Posted: 14:06 - 16 Jul 2006 Post subject: |
Hi Chris, The bike was £200 new, so definetly not worth £350.. It's the aggressor 3, silver frame model.. altho only difference I can see between the 3 and the upgraded 1 model is the frame colour and forks
By the time I fit even LX gearing etc it's not going to be worth selling really?! Surely I'd be better just breaking it, theres an aggressor 1 white frame on ebay going for £60 with time left on the auction, so surely I'd get £40 for mine... ?
Just not sure it's worth spending loads on decent shimano gears if I'm only going to get about £100 for the bike when fixed |
| cagiva gezzer |
| cagiva gezzer |
The last post was made 20 years, 98 days ago. Instead of replying here, would creating a new thread be more useful? |
