Strange router/WAP problem
fuzz
PostPosted: 23:41 - 17 Jul 2006    Post subject: Strange router/WAP problem Reply with quote
This is really bugging me now. My firewall is constantly blocking data packets from my router. I can't figure out where they're coming from. When I checked the logs, it looks like a rogue signal being transmitted, but this is the second time it has happened in a month. I have reset the router, but I'm still getting these packets.
They are 55 bytes in length, are directed to port 0 for some reason, from port 80, and all the checksums are wrong. I have port forwarding set up on port 80 for my web server which is currently offline. Could this be it somehow?
One thing it means though, is that I don't have a trojan on my system trying to download malware, which was my first thought. There are no outgoing requests, just these incoming acknowledgement packets. Any ideas what's going on? Is it just my router playing up?
fuzz
PostPosted: 13:03 - 19 Jul 2006    Post subject: Reply with quote
Anyone? No?
I should be able to answer it myself, really....
I've just passed my Network+ exam Laughing
NSR Mick
PostPosted: 14:14 - 19 Jul 2006    Post subject: Reply with quote
IP Spoofing?
fuzz
PostPosted: 22:45 - 19 Jul 2006    Post subject: Reply with quote
Maybe, but why would the packets be addressed to port 0? AFAIK this is a reserved port not used with any application layer protocol.
It must just be the router sending nonsense, but I want to figure out how to stop it, as it's turning in to it's own little DoS attack - even ping can take some time to display information when it's having a benny. Confused
Dave1216
PostPosted: 13:55 - 23 Jul 2006    Post subject: Reply with quote
What router are you using? have you tried flashing/upgrading the firmware?
How often is this happening? If it is only a couple of times a month it make's it hard to trace.
If it does appear more frequent - remove each factor at a time. Take the webserver out, and test. Then if it does still appear try and 'borrow' another router from somebody and see if the problem still exists.
Your noticing this on a WinXP machine? Not the router itself? If that's the case, take that machine out of the equation - maybe give linux a whirl for a few day's Wink.
Yamaha YBR-125
fuzz
PostPosted: 21:13 - 23 Jul 2006    Post subject: Reply with quote
It's a Linksys BEW11S4 v4 with the latest firmware. It is only on occasion that it happens, but I'm sure it's the router as there are no packets sent to the router to initiate communication.
Dave1216
PostPosted: 02:11 - 24 Jul 2006    Post subject: Reply with quote
If you really want to track down the problem i would suggest using a packet logger such as etherpeek. Make sure you set specific log rule's, ie only log port 0 activity. Maybe try ethereal to help you analyse it.
This should help you see info on the packet, such as header and such. If you do decided to do this - i'd be interested to see a copy of the packet!
Yamaha YBR-125
The last post was made 20 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 52.55 Kb
