Guest
PostPosted: 20:58 - 14 Apr 2002    Post subject: Keith Reply with quote
You seem to know a lot about the aprilia rs bikes. I have an rs250, wich I took out of the garage for the first time this year yesterday. I got it started and got up to about 10mph and when I pressed the front brake lightly the wheel locks up, resulting in a crash. I know the brakes on the 250 are quite powerfull, but is this normal?
James
PostPosted: 21:57 - 14 Apr 2002    Post subject: . Reply with quote
You're problem is that with the bike being stood, the smooth surface of the brake disc has slightly corroded and this results in it losing its super smooth finish. Until youve don a couple of miles and worn the disc smooth again, itll feel snatchy when you first brake.
Like shit off a stick
PostPosted: 00:57 - 15 Apr 2002    Post subject: Reply with quote
I will second that opinion. Check out the front wheel bearings as well, and the condition of the front disks, but I tend to agree that the problem is probably light corrosion on the disk, maybe also with the brakes sticking slightly, and when you overcame the slight resistance you were using enough force to lock the wheel
Guest
PostPosted: 10:43 - 15 Apr 2002    Post subject: Reply with quote
Thanks Very Happy
The last post was made 24 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 37.44 Kb
