Helmet painting
Bendy
Mrs Sensible
PostPosted: 17:05 - 20 Jul 2006    Post subject: Helmet painting Reply with quote
Thought I'd do a quick write up on my current project, the BCF Racing Orange Helmet Mk2.
First lid I sprayed was a learning curve, I learned what not to do. Namely try and sand it down too much and use cheap masking tape.
So this week, I've been working on the Mk2.
The project starts out with my matt black Shoei Raid, that's a little scratched and dinked but has never hit the deck properly. I figure cos it's matt it'll save me doing any sanding, so I spend a good while giving it a really thorough clean and degrease.
Unlike my Vemar, which is really easy to pull the internals out of and to remove the vents from, the Shoei doesn't really offer any clues on how to take bits off. Some time on the 'net suggests that it's all about pulling glued inners out and cutting off the visor and bottom rubber trims with a scalpel. And that they're a pig to replace. So I decide to mask them off instead, a most boring task. The visor mechanism comes off easily enough and I mask over the ACU sticker cos we'll need that later.
Many coats of orange go on and we're left looking like this:
https://www.bikechatforums.com/files/helmetstage1.jpg
Yes, spraying over the vents was intentional, they're in the 'open' position and they can stay there. There are a few dinks still showing up so I use a bit of filler to smooth them off. Sand that down and a few more coats of orange before we enter a brave new world...
Yes, I've got all ambitious and am attempting a big graffitti-style 'G' on the back of it. Being a complete airbrush newbie, I've probably gone about it the hard way, but anyways... I made a template and cut it out of A4 before masking the approximate outline. It's a curve in all directions so there's a bit of interpretation needed to get the flat design to work.
https://www.bikechatforums.com/files/helmetstage2.jpg
The whole space is filled with black, and then more masking to establish the inner bit of the design - the black is to be an outline. Proper fine line tape is good stuff, much better than using bog standard masking tape.
https://www.bikechatforums.com/files/helmetstage3.jpg
White goes on, it's left to dry and...
https://www.bikechatforums.com/files/helmetstage4.jpg
Pretty happy with that! Couple of little wonkies but I doubt anyone'll notice from a distance.
Next, I've got to get the whole thing lacquered. I'm going for an acrylic (to avoid the scary polystyrene-eating fumes of proper 2 pack) but this one seems glossier than the one I used last time, so hopefully it'll end up with a half-decent shine. Plenty of room for fuckups left with this stage, but we'll see how it goes.
Final test will be whether it passes scruitineering - if this was a road lid there wouldn't be any worries, but if G uses it for racing it gets inspected closely. Fingers crossed, you might see it at Brands next weekend. Very Happy
Oh, and G hasn't actually seen it yet. He'll probably hate it so I'll keep it for myself and be some kind of sad groupie in my very own race replica lid. Razz
Whosthedaddy
PostPosted: 17:56 - 20 Jul 2006    Post subject: Reply with quote
Any particluar reasons why it would annoy the judges, or is it because of the potential to hide crash damage?
mad4it028 This post is not being displayed because it has a low rating. Unhide this post / all posts.
Bendy
Mrs Sensible
PostPosted: 18:08 - 20 Jul 2006    Post subject: Reply with quote
Not so, I'm using paints designed for helmet use, which don't have any effect on the strength of the helmet itself.
Hiding crash damage would be the obvious one, yes. Especially if it doesn't look 'pro' enough.
craigs23
Mr Muscle
PostPosted: 18:14 - 20 Jul 2006    Post subject: Reply with quote
Like the graphic Thumbs Up
Ork12
PostPosted: 18:55 - 20 Jul 2006    Post subject: Reply with quote
Looks ace Smile
Whosthedaddy
PostPosted: 19:16 - 20 Jul 2006    Post subject: Reply with quote
Needs some sponsors on it then Wink
McGee
O RLY?
PostPosted: 19:28 - 20 Jul 2006    Post subject: Reply with quote
Looks great Mr. Green
When I first scrolled through just to see how long the thread was as I passed over the masked bit with the black paint I thought it was a swastika Laughing Embarassed
Its pronounced Jixxer!
Whosthedaddy
PostPosted: 19:32 - 20 Jul 2006    Post subject: Reply with quote
Me too Embarassed
Is G a big Gangsta kind of guy that wants a graffiti stylee helmet?
Bendy
Mrs Sensible
PostPosted: 19:51 - 20 Jul 2006    Post subject: Reply with quote
No, but I wanted to do something I could mask with straight lines, cos I haven't quite progressed to drawing curves on a curved surface yet. Mr. Green
PostPosted: 22:31 - 20 Jul 2006    Post subject: Reply with quote
Looks good Bend!
Might still be worth trying to remove the liner to make sure the polystyrene is ok though.
My Shoei has plastic popper style clips that hold the cheek pads in. They just need a sharp tug and they come out. Once they are gone I guess the rest is easy. Although to be fair I've never had the whole liner out. It probably mings a bit now. Embarassed
Bendy
Mrs Sensible
PostPosted: 22:55 - 20 Jul 2006    Post subject: Reply with quote
The raid inners are glued in place. If you pull them out, you have to re-glue it all.
There's no need to check the polystyrene, the lid has never hit the deck and is painted with water-based solvent-free paints. Trying to take the inners out to check it would probably cause damage.
Jack_Cheese
PostPosted: 23:09 - 20 Jul 2006    Post subject: Reply with quote
looks f'ckin sweet! Very Happy
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Bendy
Mrs Sensible
PostPosted: 22:26 - 30 Jul 2006    Post subject: Reply with quote
Well, I lacquered it and it passed scruitineering with no problems. Smile
jay12329
Dr. Evil
PostPosted: 22:37 - 30 Jul 2006    Post subject: Reply with quote
Lid in action.
https://img160.imageshack.us/img160/2503/img0038tu7.jpg
J
quacker_boy
Cuddle Bitch
PostPosted: 00:18 - 31 Jul 2006    Post subject: Reply with quote
Very funky bendy, i'm impressed!
I plan on playing with an airbrush, lid and bike...one day...i need to get the bike first Rolling Eyes
steveh
PostPosted: 13:58 - 31 Jul 2006    Post subject: Reply with quote
gets a Thumbs Up Thumbs Up from me, always wanted to spray a lid, but the one ive got spare i wouldnt wear.
Steve.
queen of string
PostPosted: 21:36 - 31 Jul 2006    Post subject: Reply with quote
tis cool that bend, hope he appreciates all your hard work.
"Eat food, not edible, food-like items. Mostly plants."
anders This post is not being displayed because the poster is banned. Unhide this post / all posts.
Bendy
Mrs Sensible
PostPosted: 00:25 - 01 Aug 2006    Post subject: Reply with quote
Racist.
That's funny as fuck.
veeeffarr
PostPosted: 00:55 - 01 Aug 2006    Post subject: Reply with quote
"G" as in G-Unit?
Rofl.
Luke_Retrofly
Silly Lesbian
PostPosted: 11:24 - 01 Aug 2006    Post subject: Reply with quote
anders wrote:
I dont like it at all , looks racist - swastika also a bit extreme, shame you could send it and have it done profesionally with a high shine, yours looks like it hadnt had the clear coat.
sorry not for me. Sick
Is it me or are just an idiot. Question
Luke
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
distortion
PostPosted: 16:35 - 01 Aug 2006    Post subject: Reply with quote
That looks spot on Bendy Thumbs Up some nice art work there.
Whats next ?? matching leathers with the same logo in the usual colour ? Laughing
Reckon you should have put BCF Racing either side of the jaw - but looks sweet as it is Thumbs Up
Clanger
Stirrer
PostPosted: 16:41 - 01 Aug 2006    Post subject: Reply with quote
Bendy - you could always nip up to see Grapham at Plastec before you next work on a lid. He did the 'clanger' graphic on my lid, and it looks really good - he's at Burghfield just outside of Reading.
Jack_Cheese
PostPosted: 17:57 - 01 Aug 2006    Post subject: Reply with quote
I get where you're coming from, but i only saw the swastike resemblance when the tape was on.
The shine is a little bit dull, though Thinking has it been rubbed down or anything?
Jack
The last post was made 20 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 132.55 Kb
