| neeeel |
 neeeel Nova Slayer
 Posted: 16:47 - 23 Jul 2006 Post subject: my bikes soooo sloooooooooooow |
i just got my first proper ride on my bike, a tzr 125 2rk, after buying it over a month ago, have ridden it a bit in town, but never had a chance to try it out full speed before now, and im very dissapointed, its slow!!
it doesnt go much over 50 in top gear, unless im goin down hill
and it doesnt rev really over 7 k in the top 3 gears
The engine apparently had a rebuild before i bought it, and im sposed to run it in, could this be why?
I have started raising the revs in the lower gears now, after getting back from my ride, and it is starting to rev over 8k in the lower 3 gears, havent tried it in the higher ones
My bike has a powervalve, i have the kit for it, but not fitted it yet, could my powervalve be closed, and would this make the bike so slow?
thanks
neil |
| Paddy Blake |
 Paddy Blake World Chat Champion
| Kickstart |
 Kickstart The Oracle
| neeeel |
 neeeel Nova Slayer
| NC30UK |
 NC30UK Scooby Slapper
| Kickstart |
| neeeel |
 neeeel Nova Slayer
| Frost |
 Frost World Chat Champion
| stevo as b4 |
 Posted: 02:15 - 24 Jul 2006 Post subject: |
Yeah a 12bhp TZR should peak at 7500-8000rpm, and then the power will die quickly, but it should not feel slow to get there. You should easily get to 70mph or more indicated speed and be able to maintain a close to this speed on the open road.
You should firstly service the bike, and check everything one thing at a time. This includes air filter, transmission oil, clutch, carb and oil pump adjustment etc etc. If it does not feel lively, then id check the exhaust system for an exhaust restriction, or a heavy carbon build up etc. Then a compression test can be carried out to see if the motor is healthy.
You are doing the bike no favours by trying to rev it hard when it's not yet run in after a re-build. Why do kids always try and ride a freshly re-built bike flat out and then moan when it fails and is expensive to fix after anyway? By the way, as you may have seen from other posts on BCF about people with broken 125's, do not listen to any advice about what is wrong with your bike from mates, who don't know a thing about them. And if you don't know confidently how to service your own bike, then take it to someone who does know what they are doing and has the tools and equipment to fully work on the machine, instead of having a go at repair's or re-builds yourself. |
| neeeel |
 neeeel Nova Slayer
| KyleH |
 KyleH Two Stroke Sniffer
| stevo as b4 |
 Posted: 23:46 - 24 Jul 2006 Post subject: |
Is it a TZR125L (early model, possible drum rear brake), or the TZR125R last model with USD forks?
The older TZR's felt far less restricted at 12bhp than the newer DT125R's which share an almost identical engine, internally. The peak power was 12.2ps at 7500-8000 rpm, and as long as you change up at this point it should keep pulling briskly/steadily at the same rate. If you go over 8000rpm, the power drops away, because the engine cant't breath enough air at this speed in restricted form. Either way it should do 70+mph.
The new DT125R's 1998> don't like revving past 6000rpm, and i suspect that the TZR125R's are also more heavily restricted too, than the early versions, so they won't like revving very much with a closed PV and at least 3 exhaust restrictions and maybe a cat too, at least in the case of the TDR anyway! |
| neeeel |
 neeeel Nova Slayer
| neeeel |
 neeeel Nova Slayer
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 13:51 - 26 Jul 2006 Post subject: |
Exhaust - de-coke it, especially if the bike has been run in as it cokes up worse at lower revs.
DO NOT use caustic soda though, if you have any aluminium parts in your exhaust, they will dissolve, instantly. Use a 50/50 mix of paraffin and petrol, pour into exhaust and shake well (do not smoke ).
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| simon1221 |
 simon1221 World Chat Champion
| simon1221 |
| dj-999 |
 dj-999 Derestricted Danger
The last post was made 19 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
