Fuel Difference?
bearwood.beckham
PostPosted: 21:28 - 24 Jul 2006    Post subject: Fuel Difference? Reply with quote
Just wondering if theres any fuel difference between 2 & 4 strokes?
E.g. A 4T CBR125 & 2T NSR125...
Thanks
Mister James
I want to believe!
PostPosted: 21:41 - 24 Jul 2006    Post subject: Reply with quote
They both use the same petrol, the difference is that a 2-stroke mixes oil with it to burn, while in a 4-stroke engine, the oil is sealed in the engine - which only burns the petrol.
Velocifero
PostPosted: 21:55 - 24 Jul 2006    Post subject: Reply with quote
Why don't you try them for yourself and see what happens Twisted Evil Twisted Evil Twisted Evil Whistle
Jack_Cheese
PostPosted: 22:07 - 24 Jul 2006    Post subject: Reply with quote
I'm waiting for G or Kickstart to come out with "not strictly true, as oil seeps past the rings and is consequently burned"
wait for it... Rolling Eyes
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
SoND
PostPosted: 22:56 - 24 Jul 2006    Post subject: Reply with quote
2 strokes are a lot less efficient than a 4 stroke.
I think.
NSR Mick
PostPosted: 23:10 - 24 Jul 2006    Post subject: Reply with quote
I think.
I think you'll find it's the otherway round. My twin cylinder 2 stroke 250 makes about 60bhp (or it will once I fully derestrict it)
To get that sort of power from a 4 stroke requires 400cc and 4 cylinders. Thumbs Up
Jack_Cheese
PostPosted: 23:23 - 24 Jul 2006    Post subject: Reply with quote
2-strokes are less efficient in terms of horsepower per unit of fuel.
a 4t can easily be tuned to be faster by adding nitrous and a turbo or supercharger.
2-strokes can be supercharged, but often require a very high octane race fuel and will go bang very frequently. 4-strokes also have a more linear power delivery, as they have higher torque and lower revs rather than the low torque and high revs of the 2-stroke
Jack
KyleH
PostPosted: 23:27 - 24 Jul 2006    Post subject: Reply with quote
theres a reason why pro sports bikes like MOTOGP arent 2 stroke
there mostly V twin and inline 4s
NSR Mick
PostPosted: 23:32 - 24 Jul 2006    Post subject: Reply with quote
Only one reason. Emissions
Jack_Cheese
Cast your mind back a couple of years, do 500cc 2-stroke Moto GP bikes not ring a bell?
Racing snowmobiles are 2-stroke supercharged monsters, too. There is no engineering reason why they shouldn't be smokers
Jack
:edit: I'm fairly certain motogp doesn't have emissions regulations Wink
Jebus
PostPosted: 23:36 - 24 Jul 2006    Post subject: Reply with quote
2 strokes are more powerful for a given cc, without cheating (turbos etc) but that is because they go bang twice as often. they also have a narrow powerband and need help to make useful power at lower revs, thats why they came up with expansion chambers and power valves and all that stuff.
4 strokes are better and fuel and untill they start to get very highly tuned they make pretty decent power all over the rev range, they can still come with 1 hell of a kick but not as mental as a 2 stroke. they also sound a bit less nutty.
but 2 strokes sound great when you give em some revs you can really get them scream and make it sound like the engine is going to fire its piston(s) into your bollox. i think that 4 strokes sound better when they aint getting reved to the limit, and really love a v twin and v 8 rumble.
sorry that was pretty much nothing to do with the topic but got carried away Razz
2nd time around Smile CBT: 8/9/11
125 Varadero
Jack_Cheese
PostPosted: 23:42 - 24 Jul 2006    Post subject: Reply with quote
The expansion chamber is just as much cheating as a turbo is, as it artificially compresses the air/fuel mix. It just uses back pressure instead of an impeller or fan.
The powervalve just works like an exup, varying the exhaust port flow rate to allow maximum performance. This is used on yamaha 4 strokes as well as most 125 2-strokes. They are essentially the same system. It is this valve which allows the power curve to be flattened slightly by allowing the flow rate of the exhaust gases to be altered with revs, so without the valve and an open port, the fuel flow is optimised for maximum revs, but by changing the port diameter, it allows the flow rate to be optimised constantly.
jack
Jebus
PostPosted: 23:54 - 24 Jul 2006    Post subject: Reply with quote
well ride a 4 stroke without a exup type thing and you are not really going to miss it, ride a 2 stroke with no power vavle or expansion chamber you really will.
but turbos and nos really not that commom on bikes unless a real nutter owns it or a drag bike, apart from the turbo bikes in the 80's
125 Varadero
edd
PostPosted: 01:25 - 25 Jul 2006    Post subject: Reply with quote
because moto GP rules exclude 2 strokes!?!?
Bluespark Automotive - Diesel Tuning for Performance and Economy
PostPosted: 09:27 - 25 Jul 2006    Post subject: Reply with quote
So can a 2 stroke.
Pretty much the same as a tuned 4 stroke.
First depends on the state of tune rather than being 2 stroke or 4 stroke, and 2 strokes tend to have a higher peak torque, and often rev to a lower level.
Much the same idea as a tuned length exhaust as used on pretty much any performance 4 stroke.
Conventional 2 strokes are cheap and simple (basic moving parts are the piston, con rod and crank, thats it). With no valves in the head the combustion chamber shape is likely to be better. However having the exhaust port open while the inlet gases are coming in means that unburnt fuel tends to go down the exhaust and that makes the emissions pretty dire. Can be got round with direct fuel injection but not many people have tried (Aprilia have direct fuel injection scooters on sale). 4 strokes are more expensive and complicated. With direct control over the port timing mixture can be stopped from going straight out of the exhaust (although doing this limits your choice of cam timing a bit and will loose you some power that could otherwise be released).
Only reason Moto GP bikes are 4 strokes is because they had different capacity limits for 2 strokes (500cc) than for 4 strokes (990cc). Basically a massive capacity advantage for the 4 strokes to give them a hope. Not sure when 2 strokes will be banned by the rules (might just have been, might be when the 4 strokes change to 800cc).
NSR Mick
PostPosted: 13:32 - 25 Jul 2006    Post subject: Reply with quote
Keith , always posting excactly what I would say if I could be arsed typing it. Thumbs Up
The last post was made 20 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 94.05 Kb
