cg125 drive chain adjustment
halv
PostPosted: 22:57 - 22 Jul 2006    Post subject: cg125 drive chain adjustment Reply with quote
How do I do this please as the manual is not clear as it is in Japanese and I couldn't see much in Haynes either.
I know that I have to loosen the large main bolt on the right back, and that there are grooves on either side above some small nuts so that when the small nuts are adjusted these allow one to check the adjustment is the same on either side.
The question is , is there another nut that must be loosened before I actually start my adjustments ?
Many thanks
Halv
halv
PostPosted: 23:35 - 24 Jul 2006    Post subject: haynes says Reply with quote
the 'rear break torque arm bolt' must also be adjusted.
Where is that please ?
Hal
veeeffarr
PostPosted: 01:51 - 25 Jul 2006    Post subject: Reply with quote
Right,
connected to the rear wheel, there's a 'lever' that moves when you hit the rear brake.
You see there's a large metal rod connecting the pedal to that lever.
There is a spring on the wheel end, with a nut sitting on the end.
You need to adjust that nut as the free play in your rear brake will have changed after adjusting.
T
The last post was made 19 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 34.29 Kb
