| Sephiroth |
 Sephiroth World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
| finpos |
 finpos World Chat Champion
| critical_technique |
 critical_technique Nova Slayer
| Sephiroth |
 Posted: 20:57 - 30 Jul 2006 Post subject: |
idles at 12.6v at 4k revvs.
Checked the voltage after a quick spin, 12.4v when switched off  |
| APNess |
 APNess Trackday Trickster
| Sephiroth |
| KatOwner |
 KatOwner Nova Slayer
| Sephiroth |
 Posted: 20:06 - 31 Jul 2006 Post subject: |
lol I know there's something wrong with the charging system, but what that is, is what I'm trying to find out .
Thanks for the reply though.
And no, the voltage doesn't increase when the revvs increase, the opposite happens. |
| KatOwner |
 Posted: 20:39 - 31 Jul 2006 Post subject: |
OK
So you got a new regulator/rectifier.... and the thing is STILL not charging....
If all the wiring in between is OK, and that there is no corrosion on the connections then the next thing to replace would be the battery. A dead battery will soak up the volts. If you can...borrow a battery to test this out ...saves money!
Re-check the voltage outputs with a known good battery, and if it STILL won't chuck out around 14V as the revs rise, then you are potentially looking at a new alternator.... and a nasty bill  |
| suzi_bandit |
 suzi_bandit Traffic Copper
 Posted: 21:54 - 31 Jul 2006 Post subject: |
Any idea how old the battery is?
My bike began sounding very sluggish when I was starting it. Actually had to jump start it a couple of times because the battery just died when I was unable to fire it up on the first attempt. Tested it and although it was charging up while the bike was running it was slowly loosing it's charge when the engine was turned off.
Had it replaced and was told it was about time. I hadn't actually noticed but the old battery was dated (bloody years ago ) and the new one is also dated as it is guaranteed for 2 years. ____________________ I want a big boys bike, preferably a Speed Triple. To date I have ?7:42p stashed away to put towards one. Need to get it in the bank & earning interest asap. |
| MattEMulsion |
 MattEMulsion World Chat Champion
| Sephiroth |
 Posted: 22:08 - 31 Jul 2006 Post subject: |
Yep, new battery, and old battery which has nothing wrong with it .
Thanks, all I wanted to know was whether it was the alternator or not
What would cause the alternator to go bad...? |
| KatOwner |
| Sephiroth |
 Posted: 23:56 - 31 Jul 2006 Post subject: |
Ah right, just found a new generator winding for 70 quid  |
| finpos |
| Sephiroth |
 Posted: 17:39 - 01 Aug 2006 Post subject: |
Right, theres two wires coming from the left hand engine casing, could that be them?
I have a multimeter.
What do I do? I'm not very bright as you can tell  |
| finpos |
| Sephiroth |
 Posted: 09:29 - 02 Aug 2006 Post subject: |
Just so happens I have the old regulator infront of me
There are 5 wires, three yellow, which connect to one female connector and a black and white with a red which connect to another. |
| finpos |
 Posted: 10:32 - 02 Aug 2006 Post subject: |
Right, it's the 3 yellow wires you care about.
set meter to read ohms (Omega Symbol), a low range eg 5Ohms.
Wave leads around in the air - the meter should say something like "OL"
Touch the leads together, the meter should say something very close to zero.
Disconnect the altenator from the regulator. Measure the following on the 3 yellow wires (Y1, Y2, Y3):
Y1 to Y2
Y1 to Y3
Y2 to Y3
all should read very similar, and should be somewhere between 0.5 and 2.5 ohms. Your manual will give you the proper value.
Y1 to EARTH
Y2 to EARTH
Y3 to EARTH
all should read "OL"
If that all checks out, the stator is probably ok.
Now your remaining two wires:
One is the wire that actually charges the battery.
The other, I THINK is a thing called a "sense" wire, which provides feedback for the regulator. So if it's not connected up properly, it may be supressing it's output. Can you find where the other ends of these two wires are going??
edit - RED is the charge wire. Test the regulator output at the regulator, not the battery,
black/white is sense??. Find out where it goes.
finpos. |
| Sephiroth |
 Posted: 12:53 - 02 Aug 2006 Post subject: |
The red and black wires go into this long thick cable (where the rest of the wires are contained.
The other end of the Yellow wires go into the right hand engine casing, I haven't opened it up to check but I might be able to look at some diagrams in the manual, I'll post them up now.
When you said Y1 to earth, etc... where's the earth?  |
| Sephiroth |
 Posted: 12:54 - 02 Aug 2006 Post subject: |
Just realised those diagrams probably wont help at all.
I'll go try out what you said.
If it'll help you I can get pics of where the cables go and whatnot if you'd like?
Cheers  |
| ram_doom |
 ram_doom World Chat Champion
 Posted: 13:43 - 02 Aug 2006 Post subject: |
Sounds like stator coils, they often die shortly after the rectifier if thats not sorted quickly  ____________________ TL1000s, KDX200 |
| Sephiroth |
| finpos |
The last post was made 20 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
