Any advice on Lap timers?
jason.clark
PostPosted: 14:11 - 02 Aug 2006    Post subject: Any advice on Lap timers? Reply with quote
Anyone got any advice on lap timers? I'm thinking of getting my self one so I can track my progress on different tracks.
I'll be using on track days to start with.
I'm assuming I'll need a beacon as well as the device on my bike as a package.
Any recommendations < £100 would be appreciated?
cheers,
jason.
[ Maybe a Duke?] <---- Yam R1 (Road) / Yam R6 (Race) <--- GSXR6 <------ GSXF6 <------ TSX50
PostPosted: 14:41 - 02 Aug 2006    Post subject: Re: Any advice on Lap timers? Reply with quote
Don't expect lap times to work at trackdays.
If you place a beacon in an obvious place, expect it to be confiscated.
In a less obvious place, an instructor may well not if their lap timer is working and check that area.
Some do work off a button press as well.
Or just hassle a friend to take some times down Smile.
For sale section on www.motoforum.com is a good place to look.
Dark
PostPosted: 16:18 - 02 Aug 2006    Post subject: Reply with quote
Take a mate with something that has a stop watch (like a mobile phone) with you, but not an actual stop watch, some track day companies frown upon timing full stop.
My missus usually times me with a couple of mobiles, shes worked out how to take split times now, which is cool. I can work out what my best lap would be by putting my best split times together.
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
Motkram
PostPosted: 07:49 - 03 Aug 2006    Post subject: Reply with quote
Like has already been said, it is generally frowned upon.
To be honest there isn't a great deal of point, as unless you ride around without any consideration for everyone else, you won't get a true figure; and you'll get kicked off for riding that way.
The best/cheapest way to get an indication is to have a mate anywhere on the track with a stopwatch on their phone.
Part-time GSXR1000 pilot>Micron Serpert system+K&N, PC111, Sigma slipper clutch, Brembo m/c+Galfer discs, Gilles rearsets, Translogic Quickshifter.
GP125>GSF400>VFR400NC30>YZF600R>YZFR1(1998)+KLR250>YZFR1(2003)>CBR900RRY>YZFR1(2002)>GSXR1000K1+RGV250
PostPosted: 08:19 - 03 Aug 2006    Post subject: Reply with quote
More subtle is to use a GPS unit and check the logs afterwards to work out the lap times.
jason.clark
PostPosted: 09:37 - 03 Aug 2006    Post subject: Reply with quote
Hi Guys,
Thanks for the advice, the timer was intended to track times for improvement over a year and at least be able to compare the level I'm at ..........against other riders.
Keith: can you point me in the direction of a GPS unit, I'm keen to have a sneek peek at it to see what it does and look like.
once again thanks all. Thumbs Up
PostPosted: 21:32 - 03 Aug 2006    Post subject: Reply with quote
Any old GPS unit that is capable of recording a log will do the trick. Have used a cheap Bluetooth GPS unit with a PDA, storing the log on an SD card.
This thread has a link to the VB application I knocked up:-
https://www.bikechatforums.com/viewtopic.php?t=72953
Basically stick the GPS log into the program (source code should be in there as well) and draw a line on the map it plots where the start finish line is and it will give you the lap times (only down to the second I am afraid, but a lot better than a stop watch).
Has a couple of radio buttons at the top. One selects which (of 2 useful) GPS log strings to use (one has a speed readout) and whether you want the map plotted directly from the coordinates or converted a bit (gives a better map).
Only tested it with the output from my GPS unit, so if you find some GPS logs I would like to try them. There might be a few issues with how the position is recorded (ie, decimal or seconds).
Zimbo
PostPosted: 21:58 - 03 Aug 2006    Post subject: Reply with quote
I usually find a lap timer works off the circuit beacon on trackdays, no guarantee though as sometimes they turn them off, not often though! You want to be a bit sensitive on using it, mount it discretely etc and you shouldn't have a problem.
As for which one, get a Rollcentre T100 or T200, costs a fraction over £100 new.
JDP
PostPosted: 11:56 - 12 Aug 2006    Post subject: Reply with quote
luckily i have one built in on my bike Razz
Follow me!!! I'll show you were to crash!!!!!!!
PostPosted: 11:59 - 12 Aug 2006    Post subject: Reply with quote
Presume it's just a button one, though?
JDP
PostPosted: 21:05 - 12 Aug 2006    Post subject: Reply with quote
does split times for upto 99 laps Very Happy
Zimbo
PostPosted: 21:22 - 12 Aug 2006    Post subject: Reply with quote
I think what G meant was, is the lap timer triggered at the start of each lap manually (pushing a button) or is it triggered automatically by an infra-red sensor picking up the circuit beacon?
jason.clark
PostPosted: 09:09 - 19 Aug 2006    Post subject: Reply with quote
Dum question... but are the "on bike pushing button laptimers" an off the shelf product or some ones home made device?
cheers,
j
PostPosted: 09:10 - 19 Aug 2006    Post subject: Reply with quote
Some come with the bike as standard. Would be easy enough to bodge one, but can also get them off the shelf.
The last post was made 20 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 82.76 Kb
