| cestrian |
 cestrian World Chat Champion
| sickpup |
 sickpup Old Timer
| cestrian |
| sickpup |
 sickpup Old Timer
| cestrian |
| cestrian |
| Jubal |
 Jubal Borekit Bruiser
| KatOwner |
 KatOwner Nova Slayer
 Posted: 20:51 - 04 Aug 2006 Post subject: |
It's a lesson usually learnt the hard way .... ALWAYS clean the bike before you start any job
The less muck on the machine... the less likely it is to cause problems. I also have a nice big bottle of WD40. Spray it liberally around any bolts you plan to undo the night before you start work.
Finally...when trying to shift bolts....a few basic lessons in physics can help:
Aluminium and alloys expand more than steel/cast iron.
If you have a steel bolt in an aloy casting....try undoing it when it's hot. The heat will expand the alloy more than the steel bolt and loosen it. If, however, it's a steel nut on a steel stud...do it cold.
p.s. MIND YOUR FINGERS! Hot metal and all that  |
| cestrian |
| KatOwner |
 Posted: 01:17 - 06 Aug 2006 Post subject: |
Good to hear it's back together and running nicely  |
| cestrian |
 Posted: 12:58 - 06 Aug 2006 Post subject: |
Thanks.
Just went outside, started it up, ran ropey for a couple of minutes then once it had warmed up, choke OFF and it seems to be running really nicely. Immediate response to the throttle, runs very evenly on tick over, feeling very happy with myself today.
I have the bike booked in to the local bikeshop/workshop for the job to be done, but now that I have fixed it myself I was wondering if I should let them have it for an hour for a tune up. Do you think it would be worth it or would I be wasting my money? I'm wondering, is there anything to tune up, or should I simply give it a new set of spark plugs and an oil & filter change and just ride it.
g)
| edd |
 edd Nearly there...
The last post was made 20 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
