R6?
Ricki_diego
PostPosted: 23:26 - 04 Aug 2006    Post subject: R6? Reply with quote
just wondering alot of yamaha R6's sell with a miledge of around 20k
is there a reason for this?
for instance alot of cars sell before cambelt changes 60ishk miles. to avoid high costs for servicing =p
is thier something like this around 20k for the r6?
the only reason i ask is if i was to get one with around 20k on the bike. what do i need to expect and look out for.
also i would be driving it alot anyone know how reliable they are? are they good for 60k miles?
excuse my "newbieness" lol
cheers guys
PostPosted: 23:39 - 04 Aug 2006    Post subject: Re: R6? Reply with quote
There is, for R6s - but I suspect it's more likely coincedence.
R6 gear boxes, especially 2nd gear I think, have been known in some cases to go around that. But not /that/ common I don't think.#
A lot of R6s get used more for fun/summer use, so don't get that high mileage on them - so 20k is about right for one that's been used a bit each summer.
stevo as b4
PostPosted: 00:08 - 05 Aug 2006    Post subject: Reply with quote
I was talking to my mates mate once who had a 99T R6. He had just clocked up 22000m and said that he would soon need to sell the bike, or otherwise get a replacement head from a low mileage R6, as the valves had begun to hammer the valve seats and cause valve seat recession. He said the bike had started to use a bit of oil too, due to this problem. All his mates had ZX9's Blackbird's Busa's or Blades, and he used to ride the bike very hard to keep up apparently, which he said is what causes the problem.
How true all the above is i don't know, but id be wary of a thrashed R6 of that mileage now, unless proved otherwise.
PostPosted: 00:16 - 05 Aug 2006    Post subject: Reply with quote
Has he actually had the valves checked at the stated intervals?
Ricki_diego
PostPosted: 00:23 - 05 Aug 2006    Post subject: Reply with quote
how much would something like that cost to replace? it jsut seemed weird how so many sell around 20k so always wondered why =) cheers for replies guys
colin1
Captain Safety
PostPosted: 05:08 - 05 Aug 2006    Post subject: Reply with quote
i tried an r6 with a noticeable problem in second gear
at less than half revs and less than half throttle it owuld pop out of gear for a second or so
when it happened on a straight i thought i could live with it, when it happened on a bend, it was very unnerving as it unsettled the bike
also, it had been fitted with a race can without rejetting so at low revs and low throttle, it wd cut out without warning which meant a bit of a topple if leant over
someone on here once said that the gear popping out thing can be fixed fairly easily but i cant remember how and im not convinced
Misc
PostPosted: 05:14 - 05 Aug 2006    Post subject: Reply with quote
Theres a guide to fix it on the R6 forum doesn't look easy tho. Although i havn't had the problom on mine, neither has alot of people on the forum.
Jebus
PostPosted: 00:06 - 06 Aug 2006    Post subject: Reply with quote
if the bike got riden very hard and not looked after then you mate will have problems, harder the bike gets ridden you need to change oil and check valves more often, its more likly down to lack of tlc that has hurt his bike than the bike having any common age related problem
2nd time around Smile CBT: 8/9/11
125 Varadero
Ricki_diego
PostPosted: 20:24 - 06 Aug 2006    Post subject: Reply with quote
so i'm guessing buying a 2nd hand bike..... the problem is not knowing how the bikes have been ridden in the past.
what other 600cc bikes are out there with good reliablity stamped all over it?
im quite into the sport fairing looking bikes mind u =p
Jebus
PostPosted: 22:00 - 06 Aug 2006    Post subject: Reply with quote
honda know how to screw a bike together and cbr's are not often bought by nutters they are seen as the sensiable option, but have a good look at the bike and chat to the owner that should tell you everything you need to know.
125 Varadero
stevo as b4
PostPosted: 23:28 - 06 Aug 2006    Post subject: Reply with quote
Anyone wanting a nice non thrashed 600 should buy my ZX6R, as it's one of the cleanest 2001 versions ive ever seen, it's still only done 8000m, and i don't think it's ever done more than 2000m or just over between oil changes. It's also never seen the red line, not with me riding it anyway![/img]
The last post was made 20 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 66.29 Kb
