83 GPZ250 no start when cold
mattsar1
PostPosted: 05:18 - 06 Aug 2006    Post subject: 83 GPZ250 no start when cold Reply with quote
Hi!
I have just got my learners and bought a GPZ250 of a guy and it was running fine..... when hot. But when it is cold, it just wont fire up. Choke on, choke off. Full throttle, no throttle. Push start, or jump start, still won't go.
I can squirt some fuel into the cylinders and it will fire and run, but if you blip the throttle it will sometimes just stop. You have to carefully rev it up to keep it running then it is fine, untill the next morning.....
Things i know
Carbies clean.
Diaphrams not split.
Good spark.
Compression OK.
Tappets not tight.
Runs good when going.
Seems to tick over fast enough on the startermotor.
Can anybody help with some ideas!
Thank you.
finpos
PostPosted: 11:26 - 06 Aug 2006    Post subject: Reply with quote
Just sounds like your actual choke is not working. Simple check would be to make sure that something on the carburettor moves when you put the choke on/off - ie. check the cable is not broken. Anything past that, you will probably have to strip the carbs down.
finpos.
mattsar1
PostPosted: 22:37 - 06 Aug 2006    Post subject: Reply with quote
The choke is working and the carbies have been stripped down and cleaned a couple of times now.
Perhaps there is some special way to set the choke up??
finpos
PostPosted: 23:50 - 06 Aug 2006    Post subject: Reply with quote
Setup of choke is normally just a case of making sure there is a bit of slack in the cable, so that you are sure that it is not on when handlebar lever is in the "off" position. It seems yours is not coming on, so doubt if that is the problem. You should check this is correct in the manual, though.
You say you have stripped down and cleaned the carbs - have you actually checked the cold start jet (assuming it has one, which I think it will) is clear??
finpos.
The last post was made 20 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 38.47 Kb
