GPZ500S - Forks
puzzle
PostPosted: 19:25 - 06 Aug 2006    Post subject: GPZ500S - Forks Reply with quote
The forks on my bike look very worn, plenty of black paint peeling off dispite only covering 9,000 miles. I want to renovate them but can anyone recommend the best type of paint to use, e.g. black car paint, enamel spray paint etc?
Thanks in anticipation.
Whosthedaddy
PostPosted: 19:38 - 06 Aug 2006    Post subject: Reply with quote
Hammerite may be used for most things Wink
Ichy
PostPosted: 20:01 - 06 Aug 2006    Post subject: Reply with quote
Car paint is best, just remember the finish will depend on how much effort you put into the preperation.
KatOwner
PostPosted: 21:08 - 06 Aug 2006    Post subject: Reply with quote
Smooth Hammerite is the daddy when it comes to jobs like this. Allow it to cure properly and the stuff will give you a hard, durable finish. One large can of spray should do both fork legs. Build up a few thin coats to get a good finish without nasty runs or sags. Don't leave it too long between coats though. Once the Hammerite starts to 'cure' you can get nasty reactions with the solvent in the spray. You also, ideally, want to give it a couple of days to harden before you bolt the calipers/wheel etc back together, but that's not always possible.
The stuff can be used without a primer, but as Marki says, preparation is the key. Get rid of all the old paint, and give the alloy leg a good sandpapering to give the Hammerite something to key to. When spraying, any marks you can see beforehand will look 10 times worse with a glossy coat of paint on top Wink
Avoid the hammered finish stuff.....yuck!
The last post was made 20 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 39.94 Kb
