| mr.z |
 mr.z World Chat Champion
 Posted: 12:36 - 07 Aug 2006 Post subject: Starter motor serviceing (urgentish) |
Ello all,
decided to tackle the tricky starting on my cx, its allways been a bit more effort than it should be (they are known for starting right off the button)
Ive posted a pic of the current state of it, somebody said would probably need some new grease as the old stuff would have gona solid after this time.. and... there dosn't seem to be any :o anywhere :/ so i was wondering where would it need it? also as you can probably see the larger bit of the core is a bit rusty, should i have a go at it with a wire brush or would that be bad? or pointless?
Should i be useing normal high melting point grease? where does it need it? any advice?
thanks for reading  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| GSXFire |
 GSXFire Trackday Trickster
 Posted: 13:00 - 07 Aug 2006 Post subject: |
All you need to do is take a bit of fine sand paper to the "Commutator ring" this is the small copper stripy bit at the far left of your picture, the bit that the two carbon brush contacts touch, get it nice and shiny and put a small blob of grease on the very end of the shaft where it goes into the end cap, you don't want any grease on the bit you just sand papered. ____________________ Fire by name Firefighter by nature.
My old bikes. https://www.bikepics.com/members/firefighter1/ |
| finpos |
 finpos World Chat Champion
 Posted: 13:18 - 07 Aug 2006 Post subject: |
Of course, you tried a new/known good battery before you took that to bits
Be really careful if you decide to clean the commutator - you'll see it's a series of copper strips seperated by thin strips of insulator. If you contaminate the insulator with bits of copper, it'll stop working entirely. If that happens you can usually fix it by scraping along the insulator with something, but be careful not to scrape too deep. It's all a bit fraught.
Same goes for any internal cleaning of rust from inside - tiny bits of metal floating around inside will kill it.
If there is no dried out grease in it, it is probably because it uses sealed bearing which will outlast the bike. Decide yourself if you want to add grease to it.
I think what I am saying is put it back together before you break it.
finpos. |
| alains |
 alains World Chat Champion
| mr.z |
 Posted: 15:08 - 07 Aug 2006 Post subject: |
Yep, battery is new and have tryed others (includeing a car battery )
Ended up cleaning the comunicators with the finest sandpaper i could find (p1200) worked nicely, then a once over with contact cleaner.. ended up greaseing the notch at the end and also going over the larger part, seemed quite a bit of rust.. i know somebody with a lathe so might see if i can get it put on there and clear the crud off...
I can imagine some hamfistedness would cause some major problems, its amazeing its gone 20 years with no attention (i know the previous owner who loged every bolt he ever brought or changed on it in a book)
Seems to have worked a treat! i'll know better once its winter but one short jab with the choke out a little had it going instantly
Thanks for the replys ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 20 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
