BMW F650 rear brake
sunbear
PostPosted: 08:39 - 08 Aug 2006    Post subject: BMW F650 rear brake Reply with quote
I am getting a "strange" feedback through the rear brake pedal. Wasnt there when i first got the bike a few weeks ago. When i press my foot down i get what i can only describe as little bumps coming through it. Like a slow vibration maybe. Its enough to move my foot a little. Brake pad is fine, as is the disc (no warping, grooves or lip). Any ideas? Thumbs Up
Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT !
Slickfish
PostPosted: 10:15 - 08 Aug 2006    Post subject: Reply with quote
Sounds like a warped disc but as you say its not that, does the pedal touch anything when you push it down??
finpos
PostPosted: 10:45 - 08 Aug 2006    Post subject: Reply with quote
If you are sure about the pads/disk, you need to investigate if the whole caliper or wheel is moving -
wheel bearings
caliper mounts
whatever is stopping the caliper from whizzing around the wheel when you brake (usually a reaction arm of some type)
finpos.
sunbear
PostPosted: 10:54 - 08 Aug 2006    Post subject: Reply with quote
Hi, the pedal doesnt touch anything on the bike/frame when pressed. I was thinking maybe the bearings . How do i check these ? Im not mechanically minded ! Razz
Finglonga
PostPosted: 13:15 - 08 Aug 2006    Post subject: Reply with quote
Has it got ABS fitted?
Andy Sez....
F.Y.Y.F.F.
sunbear
PostPosted: 14:44 - 08 Aug 2006    Post subject: Reply with quote
Nope Thumbs Up
map
Mr Calendar
PostPosted: 15:01 - 08 Aug 2006    Post subject: Reply with quote
Is it a F650CS? If so there was a recall for the rear caliper - click here for info. Has this work been done?
Could be the caliper moving, although I would doubt it. Just a thought.
sunbear
PostPosted: 16:13 - 08 Aug 2006    Post subject: Reply with quote
No mate. Mine is a 1996 bike so wouldnt apply to that . Thanks though Thumbs Up Anything else?
Finglonga
PostPosted: 16:42 - 08 Aug 2006    Post subject: Reply with quote
To check the bearings...You need the back wheel off the ground and grab the wheel at 3 & 9 o'clock positions and try to wobble it. If the bearings are shot there will be play in them. Also mve the wheel slowly round and as you are doing it feel for 'grittyness' in the movement, that indicates they are on the way out.
HTH
Andy Sez....
F.Y.Y.F.F.
sunbear
PostPosted: 16:58 - 08 Aug 2006    Post subject: Reply with quote
Right will try that when i get home Thumbs Up Cheers
sunbear
PostPosted: 18:48 - 08 Aug 2006    Post subject: Reply with quote
Wheel bearings seem absolutely fine.
I have took some pics of what i think maybe causing it. Im probably wrong but here they are. Behind the frame there is a round thing covered in grease that is connected to the brake lever and the chain seems to run over it. Im thinking the chain may need adjusting, but to be honest it only has about one and a half inch play. Any ideas? Could this be causing it ?
colin1
Captain Safety
PostPosted: 20:18 - 08 Aug 2006    Post subject: Reply with quote
you have links which are rusted up. see how that one isnt in line with the others
this may be why you get little bumps
sunbear
PostPosted: 22:43 - 08 Aug 2006    Post subject: Reply with quote
Problem sorted. Tightened the chain a bit and lubed it, the vibes have stopped. Will be getting a new chain asap . Cheers for replies Thumbs Up
Finglonga
PostPosted: 23:39 - 08 Aug 2006    Post subject: Reply with quote
Don't forget to replace the sprockets also. Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 81.52 Kb
