Help no replies to my sick nrg yet!!
davethenorman
PostPosted: 09:01 - 09 Aug 2006    Post subject: Help no replies to my sick nrg yet!! Reply with quote
my 1998 nrg is sick.
I brought it as a non runner, and found no compression. New piston later, we have compression and a spark.
Still not starting, so I took the reed values inlet and carb from a working nrg, and hey it starts, but runs for onlya few seconds, then dies. turning the accelerator makes things stall and die quicker.
Could the fault be with the magneto, which is not producing enough power for a good spark? I have also changed the coil, and what looks like some sort of electrical reg that sits on the side of the seat, again from a working NRG.
The last owner said that he cahnged the drive belt and then it would not start, but given the lack of compression, and carb problems he may be wrong. Does the magneto run from the crankshaft? If not below the starter ring, is a small cog which is linked to a smaller cog, but I have no idea what this runs.
Any one got any ideas on what else to look at?
Thanks
Dave
Dave The Norman
finpos
PostPosted: 10:50 - 09 Aug 2006    Post subject: Reply with quote
Hi dave,
I've read your post a few times and I think the problem is it's a bit hard to figure out what's going on!
If I'm correct:
You've changed the piston, Compression ok now.
You've swapped in the carb and electrical gubbins from a known working bike.
Every time you start the bike, it runs for a few seconds then stops.
Is that correct?
How long is a few seconds? will the bike start up straight away after it has stopped, or do you have to wait a while?
finpos.
NSR Mick
PostPosted: 10:54 - 09 Aug 2006    Post subject: Reply with quote
Kinked fuel line?
The last post was made 20 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 35.91 Kb
