| DJ Big D |
 DJ Big D Two Stroke Sniffer
 Posted: 00:57 - 12 Aug 2006 Post subject: Gears |
Hi,
Seen another post on hear but i didn't seem too clear to me
When you are doing the gears & its 1 down, 4 up. Say you start in Neutral & knock down to 1st, would you need to knock it up twice or once to get to 2nd? Unsure & don't wanna make a complete prat of myself lol
Thanks in advance  |
| Essex_Mike |
 Essex_Mike Brolly Dolly
 Posted: 01:01 - 12 Aug 2006 Post subject: |
nocking the gears up once will get it into 2nd from first
as neutral is half way between, you'll know if you've accidentaly kickd it into neutral as your bike will just not respond ____________________ CBT - Passed - 14/07/2006 Theory - Passed - 19/08/2006 A2 test - Passed -19/07/2007
Previous Bike - Suzuki EN125
Current Bike - Suzuki GS500F |
| Maz66 |
 Maz66 Two Stroke Sniffer
Neutral is half way between 1st and second so basically you go up once and ur in second, and when you need neutral you push it up a little bit.  |
| Maz66 |
 Posted: 01:05 - 12 Aug 2006 Post subject: |
| Drew |
 Drew Banned
| DJ Big D |
 Posted: 01:10 - 12 Aug 2006 Post subject: |
Great stuff guys, you have helped me out a lot!
I wont feel a turnip now  |
 Posted: 01:20 - 12 Aug 2006 Post subject: |
| Drew wrote: | just to expand on the original question...
Can you select neutral from 2nd, or do you need to go to 1st and then neutral? |
Yes, you can change from second into neutral BUT different bikes vary as to how easy this is. Generally speaking it is easier to change up from first but the more you do it, the easier it gets.
That said, I've had some (older) bikes that refuse to change into neutral at all while the bike is stationary, some will change more easily from second, some will change more easily from first.
Many modern bikes have a 'neutral finder mechanism' that makes it virtually impossable to change into anything other than neutral from first gear while stationary.
So, upshot is, you just have to get used to your own bike. If you are in second and want neutral, try for it. If you don't hit it, you are now in first and it should be easy from there.
Also worth noting that it is always easier to shift into neutral while the bike is still moving forwards slightly, although this may not be what instructors are looking for. |
| DaveS |
 DaveS Nitrous Nuisance
| Drew |
 Drew Banned
The last post was made 20 years, 54 days ago. Instead of replying here, would creating a new thread be more useful? |
