| Tim_H |
 Tim_H Two Stroke Sniffer
 Posted: 19:41 - 11 Aug 2006 Post subject: Yamaha DT 125R - How do I know if it's been derestricted ? |
Hi all.
I've trawled bach through the search engine, and can't really answer this.
I have a 2000 'x' DR125R (approx 5000 miles), and am unsure whether it's still restricted or not.
It looks standard, inc exhaust.
It goes quite well though, at 6k it blasts to 8k, then up to 10k if I really want to.
It was probably a bit coked up when I bought it, as it would only rev to about 7k with a lot of smoke.
When you turn the ignition on, you hear the powervalve servo reset, and that's about it.
I've heard that there are loads of ways that Yamaha restricted these, and wondered which ones they've used on my bike.
thanks
Tim |
| rizo-sri200 |
 rizo-sri200 Trackday Trickster
| simon1221 |
 simon1221 World Chat Champion
| Jebus |
 Jebus Brolly Dolly
 Posted: 21:15 - 11 Aug 2006 Post subject: |
go to this site, they got all the info on restritions https://www.dtr125.net/ ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| chalky143 |
 chalky143 Traffic Copper
 Posted: 11:49 - 12 Aug 2006 Post subject: |
if it struggles 2 reach 70 then its restriced.. ____________________ Current bike :: sv650 minitwin race bike
Previous bikes::cbr600 steelie race bike, 1989 Honda vfr750f, 2013 Honda fireblade, 2013 Ducati multistrata 1200s, 2012 Triumph street triple R, 1999 yamaha r6, vfr 800, ducati 600ss, vfr 400x2, ntv 650, bandit 600, cagiva mito 125, aprilia rs 50, honda c90x2, honda hornet 600x2, cbr 600, aprilia rx50, suzuki katana
My bike pics: https://www.bikepics.com/members/chalky143/ |
| Tim_H |
| element |
 element World Chat Champion
 Posted: 17:36 - 12 Aug 2006 Post subject: |
Mines a restricted 04. Ive only got 60 so far since I dont wanna push it. Just bought a new front sprocket (+1 tooth, standard is 16t. biggest I know of is 17t and go as low as 13t?) mainly because it does fly through the gears and I want to use it to cruise to work. Think yourself lucky you dont have an 04 model  ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| Tim_H |
 Posted: 20:37 - 12 Aug 2006 Post subject: |
I just bought a 17 tooth front sprocket today. to replce the 16t one on there.
Interestingly the chap in the shop said that DT's used to have a 17t as standard, with a smaller rear sprocket too.
not tried it yet as it's raining, but I don't envisage anything over 80MPH, as that's where the speedo stops  |
| stevo as b4 |
| element |
 Posted: 16:40 - 13 Aug 2006 Post subject: |
just found a site that does upto 19t for my DT. The 17t looks big as it is. I couldnt imagine a 19t fitting in the space there is! ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
| Tim_H |
 Posted: 21:13 - 13 Aug 2006 Post subject: |
Well, I rode it with the 17t front sprocket, and, yes it's a lot less frantic at higher speeds, but slightly slower through the gears.
But, going back to my top post, I still am unsure as to whether it's been deretricted or not.
Like I said, it seems to hit a lot of power at 6k, and the noise deepens. The power delivery then flattens out slightly at 8k, and will rev to almost 10k.
Is this normal for a derestricted bike, or should it 'whip' round to 10k from say 6k? in the first 3 or 4 gears?
I don't have anything to compare it with, other than that one ride about a year ago, on a friend's 'Full power' one. |
| element |
 Posted: 18:21 - 14 Aug 2006 Post subject: |
mines restricted and feels exactly as you describe. Im guessing a fully derestricted should have the powerband kick in at 5-6k and stay all the way to red line in each gear. Someone correct me if im wrong. ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
| stevo as b4 |
| Tim_H |
| stevo as b4 |
| Tim_H |
 Posted: 12:56 - 30 Sep 2006 Post subject: |
- After more reading and thinking.
I believe that with the bike having the P-valve working as standard on a 2000 model, it's restricted by,
Option A) I've read that Yamaha altered the CDI unit, so that as the revs climb above approx 7k, it starts to close the powervalve.
Option B) But, - if you read the DTr125.co.uk blog, he suggests that the P-valve is installed 180' out.
The feeling on my bike is like this. - The power really starts at around 6k, but tails off really quickly (as the p-valve closes?), but will still rev to 9 or 10k, but creeps there.
Q. Is changing the CDi for one from an earlier bike the answer? - or is it installed 180' out? - Please is there definitive answer?
PS, I've just ordered a 'Big One' front pipe.
Tim. |
| Tim_H |
 Posted: 09:11 - 11 Oct 2006 Post subject: |
Update -
Just fitted the 'Big One' (ex Fresco) front pipe, and left the original silencer fitted.
It's a good fit and at £80 is a lot cheaper than a DEP.
All I can say is - WOW
Let's say it is like a changed bike. The power band has moved up higher in the rev range, and it positively zings round to 10K. - must be much improved breathing.
Ok, and it sounds great too!.
Thanks for all the opinions, and i'll probably leave it alone for a while now.  |
There is a gap of 13 years, 98 days between these two posts... |
| Andetover |
 Andetover L Plate Warrior
 Posted: 21:16 - 14 Jan 2020 Post subject: |
I've owned a DT125R since 2004 (now 2020), I'm a mature rider, and the 2 strokes I've owned include a Kawasaki KH250 with a 350cc barrel swap, Yamaha RD350YPVS F2, Yamaha TDR(250), and Suzuki RG500 project bike.
My DT is quite possibly my favourite bike of all time.
It is totally standard, except for the "reed switch" behind the speedo being gently moved to one side and wrapped in plastic to protect it.
When you remove the front section of the exhaust and shake it, you can hear metallic rattling, presumably the factory fitted restricting disc in the header has rusted its welds and very kindly dropped out of harms way.
Unlike a lot of posters on here, I've not only had the bike dynoed, I've also verified its top speed, on standard gearing, with a GPS.
OK, these are the realities:
In top gear, 1000 rpm = 8mph
In lightly derestricted form, it produces a genuine 17.4 bhp at the rear wheel (you can say 20 bhp at the crank).
On a sunny day, when the atmospheric conditions are perfect, top speed was a verified 82mph.
RPM 10,300.
The speedo hit the stop, and was the most accurate I have seen on any vehicle, never more than 2 mph out from the GPS. That was a surprise.
The exhaust emissions were checked, and it confirmed that in standard set up, carburation is safely RICH at the top end, allowing novice owners to thrash the engine all day.
I wouldn't change the settings. Its not worth it for a brief extra 3/4 mph.
Zeeltronic do a fully adjustable ignition system that also regulates the power valve, in an article in Practical Classics a couple of years ago, they got output up to 19 bhp, and a much snappier mid range.
The trouble is finding a tuner who can fit it and set it up properly on the dyno.
Bear in mind, BIG differences can be achieved by:
Using a NEW, CLEAN, ORIGINAL air filter.
Honestly, if they are clean, they shift enough air.
Also...
Fully synthetic 2 stroke oil... helps keep your plug clean too.
And...
Atmospherics.
There is nothing you can do about this, but bear in mind 2 stroke bikes that use old school carburetors are very sensitive to air density, temperature, humidity and well maintained air filters.
(As well as float height, stale fuel, perforated air inlet hoses, loose hose clamps, clogged fuel filters).
A well maintained STANDARD DT will get about 95 of the performance of a "tuned" version with different pipes, etc... but essentially it should also stay reliable.
If you do want to add goodies, always book a dyno run BEFORE you fit them. Then book a second run AFTER.
Not only will you see if any gains are illusionary, you can also check the fuelling and re-jet if necessary.
And believe me, if your new set up leans off the mixture to any degree, you MUST re-jet or you will end up with a melted engine.
TDRs by the way do about 113mph on @48bhp
RD350 YPVS do about 125 mph on 52 bhp
Kawasaki KH250s do around 83 mph on 28 bhp
Anyone who tells you they can get 100 mph from even a 20 bhp DT is utterly wrong. Maybe they are confusing a KPH clock with mph?
They simply aren't aerodynamic enough.
Bear in mind a TDR does barely 113 or so with an extra 30 bhp!!!
Keep it real, and sunny side up everyone!! |
| redeem ouzzer |
| Andetover |
 Posted: 21:40 - 14 Jan 2020 Post subject: |
9 years + must be some kind of record!
The aim was to put some myths to bed, before all us old geezers who've been through the whole (if I put a 21 tooth front sprocket on, will it hit 100? etc) buy, tune, melt piston, and finally afford to get it done properly cycle die of old age or give up and buy a Volvo!
I'm no expert, but, like you I've lived it, and if we don't pass it on, then this generation of new riders won't know what works, and may well give up trying.
Plus you'd need a fecking magnifying glass to see my William, too many years riding in soggy Frank Thomas "waterproofs"... |
| Easy-X |
 Easy-X Super Spammer
| Andetover |
 Posted: 23:01 - 14 Jan 2020 Post subject: |
I just googled "What is the Top speed of a Yamaha DT125R?"
I was hoping to find some tuning knowledge, or maybe contemporary small capacity 2 stroke enthusiasts. I read the thread, and was disappointed that after much discussion it petered out without any of the crucial questions being answered.
I know these guys are in their 30s now, and probably left bikes behind years ago, so I thought, I can't be the only one who may want answers, why not add some knowledge gained from 16 years of ownership and take some of the guesswork out?
My bike is 2002 model, late registered in 2003, I'm its 2nd owner, it's got 6,000 miles on the clock, and runs sweet as. I actually prefer it to my GSX-R 750K2, because I can thrash it! If I tried to thrap a gixxer, I'd be dead. |
| Easy-X |
 Posted: 02:26 - 15 Jan 2020 Post subject: |
I don't know whether to be gratified or horrified that Google led you here  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| stevo as b4 |
| Andetover |
 Posted: 00:53 - 16 Jan 2020 Post subject: |
Yep, I must admit I was surprised to see a decade + old thread still popping up on a search, you'd think, legendary bikes like DTs which sold in the 1000s over nearly 2 decades, and which were quite tough little buggers would have people still talking about them.
All the big stuff, RG500s, Kwaka H2s and KR1s, even RD350s/250s and Aprilia RSs have sky rocketed in price, the only stuff left is the small, mass market stuff... and some of 'em are actually a fecking riot!
So I guessed there'd be some people discussing these little gems, and how good they are right now... got that wrong! |
The last post was made 6 years, 153 days ago. Instead of replying here, would creating a new thread be more useful? |
