Caliper Bolts.
suzi_bandit
PostPosted: 23:49 - 12 Aug 2006    Post subject: Caliper Bolts. Reply with quote
Changed the front brake pads earlier and noticed that the bolts holding the calipers to the forks (2 bolts per caliper) all look like they've been, well, sort of stretched.
I can clearly see that they narrow near the centre.
I imagine that they've been over tightened in the past. Are they weak now and should I replace them? Or am I worrying about nothing?
I want a big boys bike, preferably a Speed Triple. To date I have ?7:42p stashed away to put towards one. Need to get it in the bank & earning interest asap.
PostPosted: 23:52 - 12 Aug 2006    Post subject: Reply with quote
Not sure on your bike. Some bikes are fitted with single use stretch bolts to hold the calipers on.
suzi_bandit
PostPosted: 00:03 - 13 Aug 2006    Post subject: Reply with quote
There's a 7 stamped on the end of them, any idea what that relates to?
Sorry to ask silly questions. I just didn't expect to see stretched bolts.
Paddy Blake
PostPosted: 00:07 - 13 Aug 2006    Post subject: BOLTS Reply with quote
What bike is it.
PostPosted: 00:09 - 13 Aug 2006    Post subject: Reply with quote
Surprised it has visably stretched (would have expected it to trash the thread in the alloy caliper before that point).
Not sure what the 7 refers to.
Paddy Blake
PostPosted: 00:15 - 13 Aug 2006    Post subject: Bolts Reply with quote
If your not sure if they are ok change them,realy how much would
it cost for pease of mind. Wink
suzi_bandit
PostPosted: 00:17 - 13 Aug 2006    Post subject: Re: BOLTS Reply with quote
Paddy Blake wrote:
What bike is it.
A bandit 600
Keith, it's not just one bolt that has visably stretched, it's both bolts that hold on both calipers.
I think my best bet is to replace them, just for peace of mind if nothing else.
suzi_bandit
PostPosted: 00:19 - 13 Aug 2006    Post subject: Re: Bolts Reply with quote
Thank you paddy. Yes, that's what I'll do.
PostPosted: 00:20 - 13 Aug 2006    Post subject: Reply with quote
If they really have stretched visably then I would agree that you should replace them.
Bezzer
PostPosted: 00:29 - 13 Aug 2006    Post subject: Reply with quote
Yep replace ASAP, cleaned up a neighbours B6 calipers a few weeks ago and one of the bolts just snapped as we were tightening it up and that was with a torque wrench nowhere near the actual torque. The others were waisted so all 4 were changed. The "7" refers to the tensile strength of the bolt material and is the lower end of the high tensile scale, but it is the correct one.
PostPosted: 00:34 - 13 Aug 2006    Post subject: Reply with quote
7 isn't one I could find listed. Any idea what the strength is?
Bezzer
PostPosted: 00:44 - 13 Aug 2006    Post subject: Reply with quote
https://www.hudsonfasteners.com/fast_guide/fg_grade_markings.htm
Halfway down the righthand side Thumbs Up
suzi_bandit
PostPosted: 00:48 - 13 Aug 2006    Post subject: Reply with quote
Thank you both very much.
I thought it didn't seem quite right for the bolts to be like this.
I'll get replacements asap.
Ichy
PostPosted: 11:34 - 13 Aug 2006    Post subject: Reply with quote
Surprised its only got one number on it for bolts the property number is usually two digits, probably something to do with the Japanese origins? I know for instance that US bolts use a radial line rather than numbers to indicate strength.
For metric stuff the first digit is roughly 1/100 of the minimum tensile strength in MPa (megapascals). The second number is 1/10 of the ratio expressed as a percentage between minimum yield stress and minimum tensile stress.
So a fastener with a property class of 8.8 has a minimum tensile strength of 800 MPa and a yield stress of 0.8x800=640 MPa.
The designation system for metric nuts is a single digit. The number is roughly 1/100 of the minimum tensile strength in MPa. For example a nut of property class 8 has a minimum tensile strength of 800 MPa.
Baloo
PostPosted: 12:22 - 13 Aug 2006    Post subject: Reply with quote
Suzuki bolts are made of a cheese / chocolate combination and should be changed for real ones.
I have changed the caliper bolts on my gixxer k4 for standard Honda 03 'blade ones. They may also work on your bike.
In 18 months the bolts on my bike have alll reacted badly to this UK weather we enjoy and I have replace them with titanium where possible or proper ones. Nothing bling mind you Laughing
"We are not heroes, we are from Finchley"
The last post was made 20 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.8 - MySQL Queries: 13 - Page Size: 89.56 Kb
