kitting out my workshop...
carsounds_dan
PostPosted: 21:29 - 13 Aug 2006    Post subject: kitting out my workshop... Reply with quote
right....
i need ur advice on what tools to get for my workshop, im planning on getting:
1: A complete socket set with most different head patterns (i.e. torx)
2a: A complete spanner set, normal type not ratcheted
b: A complete spanner set ratchet type (not sure if i need this)
3: full line up for pliers, mole grips and other similar items
4: a set of screwdrivers, including the interchangable tip ones
5: My electrical gear (crimpers, sidecutters, strippers, test light, multimeter, diagnostic reader etc.)
6: anything else that would be handy
So... i'm asking, what brands do u advise (i dont want a whole thread on how amazing snap-on are), ive got a limited budget, i can afford the halfords pro stuff and probably a little bit more but ive also got to get a cabinet for it all to in aswell...
I work with the companies snap-on stuff and i understand how good that is, but my workshop won't be used daily so i dnt need everything to be the most amazing tool, but having a lifetime warrenty would be a really nice thing.
Any ideas would be nice, any tools ive missed off my list? stuff like that...
cheers
dan
add me on msn for info on CAT 2 immobalisers, and cheap fitting in the crawley area
T1z3R
PostPosted: 21:38 - 13 Aug 2006    Post subject: Reply with quote
halfords pro is all you need. lifetime guarantee you see.
duck my sick!
syl
PostPosted: 21:40 - 13 Aug 2006    Post subject: Re: kitting out my workshop... Reply with quote
Torque wrenches
Impact driver
Blow torch
Fuck off big hammer for when other tools just won't work Laughing
Current bike: Kawasaki Z750S
carsounds_dan
PostPosted: 21:43 - 13 Aug 2006    Post subject: Re: kitting out my workshop... Reply with quote
Torque wrenches
Impact driver
Blow torch
i have a hammer.... infact a whole selection of hammers, and a small blow torch.... and an old impact driver
KatOwner
PostPosted: 21:48 - 13 Aug 2006    Post subject: Reply with quote
Torque wrench is a must..... and I wouldn't be without my handy rubber mallet. Not as good as a genuine old-fashioned hide-faced mallet...but an excellent 'persuader' that won't break your alloy bits!
I wouldn't bother with ratchet spanners.
With a decent socket set, some combination spanners and a set of allen-key sockets, there is nothing a ratchet set will do that the others can't.
If you are buying from scratch, a T-bat screwdriver set is a good investment. Easier to keep pressure on those cross-head screws to stop them chewing.
PostPosted: 21:49 - 13 Aug 2006    Post subject: Reply with quote
Halfords Pro stuff isn't bad. Facom, Britool and a few others are pretty much as good as Snap On.
Other things that are useful.
G clamps
Small socket sets (ie 1/4" drive)
Jewellers screw drivers
Dremel
Clear pipe for bleeding brakes
Set of punches
Old tooth brushes
Axle stands
And probably loads more things.
carsounds_dan
PostPosted: 21:51 - 13 Aug 2006    Post subject: Reply with quote
is a dremel really that needed?
ive never seen one before let alone used one..
PostPosted: 21:55 - 13 Aug 2006    Post subject: Reply with quote
Very useful. With the small grinding disk you can do loads of stuff, just as cutting a groove in a rounded off fastener or chopping off corroded jubilee clips.
T1z3R
PostPosted: 23:09 - 13 Aug 2006    Post subject: Reply with quote
what he said ^^^
my dremel (actually mines a "rotary tool" Razz ) has come in handy for a number of jobs including cleaning up rusty bits and removing baffles from exhausts...can be had quite cheap too
duck my sick!
PostPosted: 23:31 - 13 Aug 2006    Post subject: Reply with quote
As kickstart mentioned, a small but good quality 1/4" drive socket set is very usefull for working on a bike.
Wobble extension bars come in handy.
Feeler guages? Vacuum guages? Compression tester? Strobe?
Hacksaws (full size and junior).
Angle grinder.
Small petrol tank for running the engine with the main tank off (nick one off an old lawnmower, you can usually hang it off the handlebars).
Another vote for a deadblow hammer. Nylon are ok, the old fashioned lead-shot filled ones with one hide face and one copper face are best though.
stevo as b4
PostPosted: 01:33 - 14 Aug 2006    Post subject: Reply with quote
Ive been buying garage tools and equipment since 2002. I started with a Halfords pro 1/2" socket set and just added more and more stuff over the last 4years. I tend to buy most items at times of the year when there are sales on. I have kept as far as possible to Halfords pro stuff, but ive got some teng tools kit and Draper expert tools that i also rate well!
The Tool cabinet i have is all Halfords stuff, but you don't need the expensive roller bearing slide draws or top of the range toolbox's for domestic use, so don't waste your cash on these, just spend the money on more quality tools, as a when you can afford them. Ive added lots of individual peices and bit's to my tool collection mainly as and when i need them.
I don't use everything though, and i find that some tools like ratchet spanners while they can be useful, they are certainely not essential or as useful as a quality set of combination spanners. As for socket set's you can manage on a bike normally with either all 3/8" sized stuff, or what i did insteal was get a 1/4" and 1/2" set, instead of 3/8" drive tools, as then you have the capacity for any job big or small. To get a decent set of Halfords pro tools for just about every job, and the cabinet to keep them all in, is going to get close to £1000 worth tho, so just buy things a bit at a time and and slowly build up your tool collection.
The most important point is that if you have £££'s or ££££'s worth of tools, you need a decent garage with several bloody good locks, to keep it all safe IMO!
ZRX61
Victor Meldrew
PostPosted: 04:41 - 14 Aug 2006    Post subject: Reply with quote
I've had one for at least 12 years, probably used it twice....couldn't even tell you where it is in the garage...
carsounds_dan
PostPosted: 10:40 - 14 Aug 2006    Post subject: Reply with quote
no problem with the security, the workshop is alarmed and has steel bars behind all the doors and windows that bolt into the walls and floor when i lock the door.
I recon im gunna need a 7 draw cabinet to keep it in for starters, but im off to halfords later to eye up some of their stuff...
cheers
dan
edd
PostPosted: 11:46 - 14 Aug 2006    Post subject: Reply with quote
Depending on your budget there are lots of avenues you can take. Its nice to have shiny new tools, but if your just starting out its better to have used decent kit than brand new shoddy stuff. You can get lots of good tools at auctions, car boot sales etc. I got a full set of britool sockets and a ratchet for £10 at a car boot sale a while ago, and although I have a new Sealey socket set (Id recccomend Sealey they have a lifetime guarantee on everything and despite my abuse Ive not broken anything they make yet) those britool ones are still going strong. If any members of your family are mechanically minded there is a good chance they will have a lot of old tools that they may well have replaced and would be willing to hand down to you. (My uncle gave me a load of decent tools when he restocked his rally van)
I have some halfords pro kit (a few bits and pieces, spanners, screwdrivers and one of my tool boxes) and as people say it is pretty good. I would think carefully about what you buy, as tools are something you are likely to use a lot.
Bluespark Automotive - Diesel Tuning for Performance and Economy
Marci
PostPosted: 13:06 - 14 Aug 2006    Post subject: Reply with quote
Old margarine tub or coffee jar...
Make a fortune if u use it as a swear box and work on lots of 2strokes Wink
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
the grim reaper
PostPosted: 14:08 - 14 Aug 2006    Post subject: Reply with quote
Also, spend a little more cash and go for 6 point sockets instead of 12 point, or even face drive sockets, they don't round anything off.
I've probably got over 2k worth of tools but the things I use most are my 1/4" Halfords Pro socket set and my magnetic tool/fastener holder.
Grim
sickpup
Old Timer
PostPosted: 14:15 - 14 Aug 2006    Post subject: Reply with quote
But then you don't work on the heaps I've had to when working at a shop. They come in very useful when a bearing has completely collapsed and you have to remove the outer race of a bearing from a wheel. Only ever use mine for fiddley cutting though.
Granted though if a bike is kept well you never need it.
ZRX61
Victor Meldrew
PostPosted: 16:37 - 14 Aug 2006    Post subject: Reply with quote
Actually those 2 times I've used it was on household stuff, not a vehicle.
hmm.. maybe it's in the household toolbox.... with the plumbing, tiling, electrical, painting, drywalling & roofing etc stuff.... Thumbs Up
sickpup
Old Timer
PostPosted: 16:40 - 14 Aug 2006    Post subject: Reply with quote
I find them good for cutting curves in tiles. Thumbs Up
The last post was made 20 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 106.32 Kb
