Mixing coolant...
TiN
Pocket Tin
PostPosted: 17:55 - 14 Aug 2006    Post subject: Mixing coolant... Reply with quote
Ello,
Could someone please tell me just how catastrophic it is to just top up coolant levels, without knowing exactly what was/is already in there?
The vehicle in question is fairly old, so I doubt that it's any fancy stuff, and I've just got some standard coolant at hand...
(And no, I don't really want to have to flush the system)
Cheers in advance.
TiN
dotgems.net
T1z3R
PostPosted: 18:12 - 14 Aug 2006    Post subject: Reply with quote
wont do any harm in my opinion unless you end up at an extreme i.e. all coolant or all water.
duck my sick!
Whosthedaddy
PostPosted: 18:14 - 14 Aug 2006    Post subject: Reply with quote
If you read the back of the bottle of anti freeze then it states that it should a certain mixture for summer and a different concentration during the winter. Does this mean that you are supposed to drain the radiator and colling system twice yearly? (Await for the yes you are replies Shifty)
I've always made up a mixture in an old coke bottle thats somewhere in between and just used it to top up he cooling system as and when required
edd
PostPosted: 18:16 - 14 Aug 2006    Post subject: Reply with quote
you can just top up your fluid levels, at this time of year it doesnt really matter how much anti freeze is in there so long as there is enough to inhibit corrosion, and so long as you replace the coolant before winter.
Bluespark Automotive - Diesel Tuning for Performance and Economy
PostPosted: 18:47 - 14 Aug 2006    Post subject: Reply with quote
Mix it up in a seperate bottle to the right strength and top up using that. I doubt there would be any problem with different brands of coolant reacting with one another.
They are pretty much all ethylene glycol with corrosion inhibitors in (usually sodium nitrate) and a dye.
Marci
PostPosted: 13:19 - 15 Aug 2006    Post subject: Reply with quote
All coolants need draining and replacing at certain intervals anyway - ultimately depends on how many various metals are within the cooling loop. The more mixed metals, the more "worn out" the corrosion inhibitors become over time to the point that they no longer inhibit, and then the entire lot wants dumping and replacing.
I tend to dump mine every 6 months and replace with fresh deionised water + Zerex Additive @ 10% by volume, or LiquidCosworth @ 5% by volume.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
The last post was made 20 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 48.66 Kb
