Indicator flash rate for mot?
ROB_NSR
PostPosted: 22:11 - 14 Aug 2006    Post subject: Indicator flash rate for mot? Reply with quote
Does it matter how fast your indicators flash?
My nsr came with no front indicators and no bulbs in the rear ones, after putting bulbs in the rear ones (10amp, as it says inside the light) and fitting indicators to the front they flash quicker than normal (or what I'd consider normal)
Do they have to flash at a certain speed or will faster be ok? I don't want to take it for a test just for it to fail on the indicators flashing too fast!
Thanks
Rob
Flip
PostPosted: 22:12 - 14 Aug 2006    Post subject: Reply with quote
Has to be a certain speed.
veeeffarr
Between 60-120 times a MINUTE AFAIK.
ROB_NSR
PostPosted: 22:17 - 14 Aug 2006    Post subject: Reply with quote
Looks like I need new bulbs then, at least I think that will slow them down!
But before I go buying new bulbs I'm gonna sit and count how many times they flash in a minute! (I take it you meant 60-120 times a minute not second! That would be some flash rate!!)
Thanks
Rob
Essex_Mike
couldn't the size of the indicator relay affect the flashing rate?
CBT - Passed - 14/07/2006 Theory - Passed - 19/08/2006 A2 test - Passed -19/07/2007
Previous Bike - Suzuki EN125
Current Bike - Suzuki GS500F
MattEMulsion
PostPosted: 22:19 - 14 Aug 2006    Post subject: Reply with quote
Toby R wrote:
Between 60-120 times a second AFAIK.
Very Happy Do you wanna change that to 60-120 times a MINUTE instead? 60-120 a second lol, can you imagine the MOT tester trying to count them!
But you are basically right, it is 60-120 times per minute to comply with the regulations.
Yamaha YZF-R6
veeeffarr
PostPosted: 22:21 - 14 Aug 2006    Post subject: Reply with quote
Edited, thought I had got away with it.
ROB_NSR
PostPosted: 22:37 - 14 Aug 2006    Post subject: Reply with quote
Just counted, 124 times a min roughly!
New bulbs time me thinks!
Thanks
Rob
nick 15
PostPosted: 23:44 - 14 Aug 2006    Post subject: Reply with quote
its not the bulbs!!
that will do jack shit..
you need to change the relay,
thats wot tells the bulb wot to do and sends the right amount of currend for the command
Nick Thumbs Up
cbr 600 kart on the way Very HappyVery HappyVery HappyVery Happy
ROB_NSR
PostPosted: 23:51 - 14 Aug 2006    Post subject: Reply with quote
Something is wrong then, they dont flash at all unless both front and rear bulbs are in, and when I had 2 16amp bulbs they flashed once then went off
The combination I have at the minute is 10amp in the rear, 16amp up front
If the worst comes to the worst I'm sure I can splash out on a new relay
Essex_Mike
PostPosted: 23:54 - 14 Aug 2006    Post subject: Reply with quote
i just got a new relay. £3.12
nick 15
PostPosted: 00:04 - 15 Aug 2006    Post subject: Reply with quote
There we go
cheap as chips!
Nick
Finglonga
PostPosted: 12:08 - 15 Aug 2006    Post subject: Reply with quote
Thing is Higher wattage bulbs would do the same thing as a new relay.
They are only flashing fast due to low resistance, you may have another problem.
Andy Sez....
F.Y.Y.F.F.
lllN30lll
PostPosted: 12:12 - 15 Aug 2006    Post subject: Reply with quote
since i installed LED indi's on the rear and kept standard indo's on the front my flash rate has doubled.
I quite like it like that TBH
MOT'ing the bike wasnt a problem, it's always good to go to an MOT'er who's a biker Thumbs Up
Turbo R1
CRF450R
nick 15
PostPosted: 12:17 - 15 Aug 2006    Post subject: Reply with quote
lol, check the connections?
might be rust on the linking connector or a shit load of dirt
Nick
killa
Won't Shut Up
PostPosted: 12:46 - 15 Aug 2006    Post subject: Reply with quote
You don't need indicators for the MOT, take them off and then sort it. Cool Thumbs Up
fuzz
PostPosted: 12:52 - 15 Aug 2006    Post subject: Reply with quote
Erm, 10 and 16 amp bulbs? I don't think your bike could handle it. I think you mean watts. You need 12V 10W bulbs in your indicators with a standard flasher relay on an NSR. I am currently using only 4W bulbs in each of my NSR indicators, but the relay can handle this small current. I got it from Wemoto. They are, to my surprise, flashing at a constant rate. Higher wattage bulbs will clog down your charging system and your battery will not be able to cope if your headlights are on aswell.
nick 15
PostPosted: 12:55 - 15 Aug 2006    Post subject: Reply with quote
I agree,
just take them out and sort it out after the MOT like "killa" said
Nick
lllN30lll
PostPosted: 13:23 - 15 Aug 2006    Post subject: Reply with quote
take it to another MOT'er who's a bit more "friendly" towards bikers
job done Thumbs Up
Turbo R1
CRF450R
feef
Energiser Bunny
PostPosted: 13:47 - 15 Aug 2006    Post subject: Reply with quote
if you still have the indicator switch, you need to have indicators.
If any of the indicator mechanism is present, the full system has to work.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
The last post was made 20 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 106.89 Kb
