Helping regarding de-choking and ring piston changing
mjt
PostPosted: 00:36 - 15 Aug 2006    Post subject: Helping regarding de-choking and ring piston changing Reply with quote
I have just bought my first bike a week back. It is Honda NSR 125R (2000). Mileage is 16500 km. How can I check if it needs de-choking and ring piston changing or not. Is there any easy method other than by looking at spark plug ? As far as I know it is never serviced before ... but it is still working properly somehow Surprised I have already done basic service like changing gear oil, air filter cleaning ( I had removed whole air box) and new spark plug. Bike is starting properly ... about sound I cannot say much as it is my first bike, there is smoke from exhaust at the start but it becomes less as the bike gets warm. Any kind of help is greatly appreciated.
PostPosted: 00:41 - 15 Aug 2006    Post subject: Reply with quote
Using modern oils they rarely need a decoke (although if you have the top end off the engine it is worth cleaning everything up).
Best thing to check is to do a compression check. From memory it should be 142psi +/- 14psi on the NSR.
nick 15
PostPosted: 00:47 - 15 Aug 2006    Post subject: Reply with quote
if there is smoke,
you might have a oil gasket blown somewere but as for the piston ring changing
thats fairly simple but you will need a piston ring compressor unless you have strong enough fingers, lol
cbr 600 kart on the way Very HappyVery HappyVery HappyVery Happy
PostPosted: 00:51 - 15 Aug 2006    Post subject: Reply with quote
Never needed a piston ring compressor on a 2 stroke.
nick 15
PostPosted: 00:53 - 15 Aug 2006    Post subject: Reply with quote
Well,
I haven't had to use them yet
although i suppose it depends on how big the piston is
Nick
mjt
PostPosted: 01:06 - 15 Aug 2006    Post subject: Reply with quote
Anyone can explain me step by step how to change ring piston or point to some simple and clear workshop article ? also from where I can get cheap parts etc. I am living in germany and here it is very complex to find anything ( lots of rules for everything Surprised ). Thanks a lot.
nick 15
PostPosted: 01:07 - 15 Aug 2006    Post subject: Reply with quote
ill find you a article now...
mjt
PostPosted: 01:11 - 15 Aug 2006    Post subject: Reply with quote
Thanks Thumbs Up .... I am waiting Surprised
nick 15
PostPosted: 01:15 - 15 Aug 2006    Post subject: Reply with quote
Have a look on google
loads came up
Nick
PostPosted: 01:16 - 15 Aug 2006    Post subject: Reply with quote
PM Waiting
nick 15
ill try and find you a deciend link
Jubal
PostPosted: 01:19 - 15 Aug 2006    Post subject: Reply with quote
If the performance is where it should be and it sounds OK leave well alone, as stated modern oils are very low ash.
Smoke initially then deminishing as you run is normal for a 2-stroke.
Best to deal with problems as they arise, ie as soon as you notice something has changed, obviously keep an eye on things like fluid levels, chain tension/lubrication and brake condition etc.
Golden rule- "If it ain't broke, don't fix it". keep the bike regularly serviced and use a good quality injector oil. Allow the engine time to warm up in the morning using the minimum amount of revs until it has.
Good luck.
nick 15
PostPosted: 01:20 - 15 Aug 2006    Post subject: Reply with quote
here you are the manual should tell you...
https://www.motorcyclespecs.co.za/model/Honda/honda_nsr125r%2003.htm
is you scroll down a tiny bit were it says "manual" there is a link next to it, click on it, and when the thing pops up, click "save"
then make sure you save it to your destop
then when its finished downloading
open it
TA DA!
that should help Very Happy
Nick
nick 15
PostPosted: 01:27 - 15 Aug 2006    Post subject: Reply with quote
hope that helped Very Happy
Nick
mjt
PostPosted: 01:29 - 15 Aug 2006    Post subject: Reply with quote
Thanks for the help ... I found this manual on this forum before but it is for professionals not for begainers like me Sad .... Jubal gave nice advice ... I will first look for compression test and then decide what to do... Cool
nick 15
PostPosted: 01:31 - 15 Aug 2006    Post subject: Reply with quote
wasn't a prob
Always there for future reference though
Lol
Nick
The last post was made 20 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 93.49 Kb
