Pinlock system Q?
short1uk
PostPosted: 10:12 - 18 Aug 2006    Post subject: Pinlock system Q? Reply with quote
I bought a new tinted black visor and got it pre drilled with the pin lock poles added. Just tried to add the clear insert and it does not seem to want to lie flat against the front of the visor. It says on the instructions that you need to twist the pin lock poles until it is flat. Anyone had any luck with these do-it-your-self kits?
Catherine
Kara
PostPosted: 14:00 - 18 Aug 2006    Post subject: Reply with quote
Is it the right insert for your visor? They do different ones for different make and model helmets.
What I find makes it easier to fit is removing the visor and bending the visor as flat as it will go (Arai visors will do this) holding one end with my knee on the floor while I put the insert in. Then when it is in place I let the visor bend back to how it usually is and it seems to seal it in place.
I hope this helps.
Pinlock is great!
NC30 + Bandit 6
www.eabikers.co.uk
T1z3R
PostPosted: 14:07 - 18 Aug 2006    Post subject: Reply with quote
just to be sure sure you are fitting it to the inside of the visor?
im sure you are but its just that you mention the front.
i do the same, lay the visor out as flat as you can then in on one side then the other.
duck my sick!
P4LERIDER
PostPosted: 16:41 - 18 Aug 2006    Post subject: pinlock Reply with quote
I also have a black pin lock ready shoei visor. I recently received the insert & installed it without a problem.
I took the visor off, knelt on one end to flatten it & inserted the insert without having to twiddle the pins..
It fitted flush with the inside of the visor & has been fine...... up until now.
It seems that it no longer sites flush with the visor & when riding in the rain this morning it misted up!!
I've called the people who i ordered it from & they've asked me to send them the visor & the insert so that they can check this out. Bit of a pain in the arse eh??
Does anyone know if this is a common problem? Up until now it's been fine so am a little disappointed I've got to send it back Sad
The last post was made 20 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 39.61 Kb
