De-restriction trouble
Will
PostPosted: 18:04 - 28 Jun 2003    Post subject: De-restriction trouble Reply with quote
Hi,
My dad and I are currently trying to de-restrict my NSR. But we can't get the bolt out that holds the fuel tank in place out. It seems to be stuck in by the fairing. Can anyone tell me how to remove it?
Thanks
Will
Scooby
Scrappy Doo
PostPosted: 18:21 - 28 Jun 2003    Post subject: Reply with quote
Get an adjustable spanner and secure it in place (so the bolt won't move) on one side, then use an 8mm (maybe 10mm) socket to loosen the bolt. You can do it without removing the rear fairings, the rear fairings pop off slightly because they're held in place partly by a plastic stub with a rubber washer thing.
Guest
PostPosted: 19:24 - 28 Jun 2003    Post subject: Reply with quote
Right, new problem. We now can't get the left screw, that holds the air box in place, out. We've been trying for about half an hour and we can't shift it. We're going for the big one like it said in the instructions. Can anyone help us on this?
Thanks
Will
Will
PostPosted: 19:26 - 28 Jun 2003    Post subject: Reply with quote
That was me. Forgot to log in.
Scooby
Scrappy Doo
PostPosted: 21:50 - 28 Jun 2003    Post subject: Reply with quote
Bloody hell, it ain't that difficult, you ain't turning it with enough force. Try getting a spanner on it then using a screwdriver or something for extra leverage.
Will
PostPosted: 22:44 - 29 Jun 2003    Post subject: Reply with quote
Ok a quick update:
We've successfully removed the intake restrictor. But when I turn the ignition key to 'on' usually their is a whirring. But now when I turn it, it starts to whir then just stops. Have I not replaced something or put something in the wrong place? Also I was told by 'TrueBlue' that it took him about 2 hours to drill the holes. Well we've been going on and off for most of the day and we've only managed 2 nearly 3 holes. We're using a 500 W drill. Can anyone tell me if this is enough or are my blobs of weld stubborn.
Will
True Blue
PostPosted: 23:19 - 29 Jun 2003    Post subject: Reply with quote
That was 2 hours for the whole thing mate Laughing
Make sure you have decent i.e sharp drill bit. And drill small pilot holes first. I used a 2mm drill bit then 5mm then 8mm then 10mm.
A 500w drill should deal with it no probs, I used a battery drill Wink
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
True Blue
PostPosted: 23:21 - 29 Jun 2003    Post subject: Reply with quote
Will
Don't know anything about "wirring" but if the bike starts, I wouldn't concern myself with it
The BeefMeister
PostPosted: 23:30 - 29 Jun 2003    Post subject: Reply with quote
Is it anything to do with the powerbands? My mates DT125 does that when you switch the ignition to "ON". Same with the Cagiva Supercity125. I wondered what it was to begin with. I could be wrong but that's what I've been told.
"Put your hands up motherstickers, this is a f*ck up!"
EuropeanNC30R...
Gay Hairdresser
PostPosted: 23:49 - 29 Jun 2003    Post subject: Reply with quote
On my RGV the whirring noise when you turn the ignition on was the powervalves opening and closing.
Will
PostPosted: 00:00 - 30 Jun 2003    Post subject: Reply with quote
[quote="True Blue"]That was 2 hours for the whole thing mate Laughing [/quote]
Bloody hell Shocked
And I'm pretty sure the whirring is nothing to do with the powerband or powervalves. Anyone who has a fairly recent NSR, look underneath the tank and you should see a shiny silver circular thing. With, what looks like, two pieces of wire wrapped around it. This is what I am referring to.
Will
PostPosted: 00:22 - 30 Jun 2003    Post subject: Reply with quote
This is the servo for the powervalve*, check to see there's nothing blocking it.
For the exhaust, ideally you want a faster drill, but more important is decent drills in small sizes. You will need a few 2 or 3mm ones, because tehy will blunten and brake.
Crappy drills often become blunt before you've finished the first hole. You need small ones to make accurate holes, then a bigger one to drill it out.
Laughing at the powerbands... talk to bend that does a good line in replacement ones Smile
McJamweasel
BCF Junkie
PostPosted: 15:30 - 30 Jun 2003    Post subject: Reply with quote
Yeah, I just got a 'Go-Fasta' red one - I'm sure I've gained about 15mph! Mr. Green
Scotty
Scooter Boi
PostPosted: 15:35 - 30 Jun 2003    Post subject: Reply with quote
And what about my Go faster Square Can.
Or my loose chain.
Or my lack of starter motor (less weight you know)
Not to mention the go faster scratch's and squidgy grips...
Regards
Scott
Danny
Ask Me About Stoppie School
PostPosted: 18:50 - 30 Jun 2003    Post subject: Reply with quote
Or my loose chain.
I want those grips, bring me a pair to RnB please Wink
Oh and my new yellow screen must add a few mph because Zim got 105mph out of it, fully loaded with luggage Laughing
Will
PostPosted: 00:50 - 01 Jul 2003    Post subject: Reply with quote
I have finally de-restricted my NSR. One problem: It only goes 60mph. Can anyone tell me why it's going so slowly?
Will
Shaun
Likes 'em bent
PostPosted: 00:57 - 01 Jul 2003    Post subject: Reply with quote
Maybe you forgot to change out of 3rd gear!
Or you've put on about 300lbs in the past two days and your bike just can't take it anymore.
PostPosted: 01:18 - 01 Jul 2003    Post subject: Reply with quote
Given that you say it no longer whirs at you when you turn the ignition on I suspect you have disconnected the power valve
Will
PostPosted: 15:54 - 01 Jul 2003    Post subject: Reply with quote
No it does whir when I turn the ignition on now but the bike only goes up to 60mph. Any ideas?
Scooby
Scrappy Doo
PostPosted: 19:48 - 01 Jul 2003    Post subject: Reply with quote
You've probably put the powervalve in the wrong way.
Will
PostPosted: 00:51 - 02 Jul 2003    Post subject: Reply with quote
Sorry Scoob this is going to piss you off but could you elaborate on what you said as I'm not mechanically minded.
And sorry for having a go at you the other day. I don't know why I did that I'm not usually like that.
cc
Guest
PostPosted: 01:46 - 02 Jul 2003    Post subject: Reply with quote
have you drilled out the restricter in the exhaust or have you pit a new exhaust on
Will
PostPosted: 01:51 - 02 Jul 2003    Post subject: Reply with quote
We have drilled out the restrictor.
Scooby
Scrappy Doo
PostPosted: 01:56 - 02 Jul 2003    Post subject: Reply with quote
Ok, apology accepted Smile
When you took the airbox and stuff off to get to the carb did you interfere with the powervalve in any way? I did this but I only took the powervalve off when I dropped the engine out, and when I put everything back together I didn't assemble the powervalve correctly. I put something in the wrong way and the powervalve wasn't opening properly.
I am suggesting this because when people say my bike's restricted, and it's a 2 stroke, a lot of people may think it's a powervalve restriction, so if anyone at all has fiddled with it (even before you had it) it might be that.
Will
PostPosted: 16:05 - 04 Jul 2003    Post subject: Reply with quote
Well, unbelievably, I've come across yet another problem with de-restricting my NSR. I've just been told by Bernards in Peterborough that the 2003 model can't be de-restricted. Is this true? Has anyone on this forum de-restricted their 2003 NSR?
Any help would be very welcome.
Will
The last post was made 23 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 124.31 Kb
