knocking noise when idling
SteveyRF600
PostPosted: 18:40 - 28 Aug 2006    Post subject: knocking noise when idling Reply with quote
i have a 93 Suzuki RF 600. the bike runs fine and smooth, however on start up and idling there is a knocking noise coming somewhere from the engine, there only other time it sounds like it is when you nearly stall the bike and the revs drop!....
The other issue is when i pull up at lights the revs stay at 2k for about 10 seconds before returning to its normal (about 1300)
I must admit i have cocked about with the idle screw!
The bike has had new filters all round and new oil
Any suggestions welcome!
Cheers Very Happy
Jubal
PostPosted: 19:30 - 28 Aug 2006    Post subject: Reply with quote
Sounds like the carbs are out of balance.
SteveyRF600
PostPosted: 19:35 - 28 Aug 2006    Post subject: Reply with quote
i am not mechanically minded... is this an expensive job if i took it to the local bike shop??
Just had the sparks changed as well and they where in crap condition, was gonna run it for a few hundred miles and check them again... i think it was running rich, again would this be the carbs??
Very Happy
jamieclayton9
PostPosted: 06:35 - 29 Aug 2006    Post subject: Reply with quote
my cousin had a 1994 rf. the engine on his was always lumpy on tick over. they usally always are. even my old mans 900 is a bit lumpy and thats only done 8000miles. could be cam chain. what sort of miles has it done cheers. jamie
all my previous rides, c50 steppie, h100s, cb250n superdream, gpz500s, gsf600s bandit, gsf1200s bandit, zx6r, thunderace, dr350, sv650s, cb600f hornet ooohhhhh and the mrs
Ichy
PostPosted: 08:43 - 29 Aug 2006    Post subject: Reply with quote
Does the noise change if you pull the clutch in?
What about if you put it in gear, obviously with the clutch in?
And finally, Slowly release the clutch without increasing the revs, any change?
Does sound like backlash from badly balanced / set carbs but it doesn't hurt to check.
SteveyRF600
PostPosted: 18:23 - 29 Aug 2006    Post subject: Reply with quote
The bike has just turned 30, 000 miles, when riding the bike everything is good, i have just been to the local bike shop who had a look at it and agreed it was up and down on the idle... funnily though he said a new air filter can sometimes upset the bike, but he did say the first thing he would look at was the carb balance, so gonna take it in tomorrow and see what happens!
cheers for the right direction Thumbs Up
There is a gap of 10 years, 100 days between these two posts...
Len16
PostPosted: 17:55 - 05 Dec 2016    Post subject: Rf600r knocking Reply with quote
[quote="Ichy"]Does the noise change if you pull the clutch in?
Does sound like backlash from badly balanced / set carbs but it doesn't hurt to check.[/quote]
I have the same bike. I have a 1994 rf600r with 28,000 miles and it has knocking near the clutch and when I let out the clutch it seems to get louder what does this mean I just got this bike and I have no clue about motorcycle engines but dirtbike I can work on. Help appreciated thanks.
Robby
Dirty Old Man
PostPosted: 18:18 - 05 Dec 2016    Post subject: Reply with quote
Wow, 10 year old thread revived.
Balance the carbs, it's the usual cause of clutch knocking.
janner_10
PostPosted: 08:44 - 06 Dec 2016    Post subject: Re: Rf600r knocking Reply with quote
I hope this advice will put him out of his 10 year misery.
The last post was made 9 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 60.52 Kb
