Emergency stops!
akaDAVE
PostPosted: 10:39 - 29 Aug 2006    Post subject: Emergency stops! Reply with quote
Yesterday morning I remember my bike instructor's words of wisdom when he advised me to practice a few emergency stops every time I went out on the bike.
I only remembered this when sitting 1/2ft away from the back of a Micra after about 20yards of sideways tail-sliding, arse clenching drama.
I had just come around a bend on a familiar, normally fast flowing nsl country road to find someone had stopped a big caravan for no apparent reason what so ever without indicators/hazards mid lane.
He did a good job of using the bend and trees to hide the caravan just out of site to following traffic.
If it wasn't for the obvious reaction of the car in front I would have been fucked to be honest. The micra was going realatively slowly for that road but had to stamp on the brakes ahead of me which gave me a warning. It really was a freak incident there and I was well caught by suprise.
I went straight off to practice some stops and realised I was well off. I was locking up the back dreadfully and had no feel at all.
Does anyone make a disciplined habit of practicing emergency stops? When was the last time you actually practiced/did one?
I think it's a good idea.
GSXR600
Suzuki
Roger
PostPosted: 10:44 - 29 Aug 2006    Post subject: Reply with quote
I never go out to 'practice' them. Occasionally have to hit the brakes pretty hard though.
Never had too much trouble with a snakey rear-end.
Sounds like you might be applying a little too much rear brake?
Well done for stopping pre-micra though! Wink
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
jay_666
PostPosted: 10:46 - 29 Aug 2006    Post subject: Reply with quote
I was practising mine yesterday. Why? Because i had a lesson Mr. Green
edit: its tuesday today isnt it. i had my lesson sunday! Doh!
But yeh, I was once going round a 90 degree left hand bend that i know well and some idiot decided they would just do a 3 point turn just round the bend!
Luckily i stopped just inches from the car and gave the driver a right dirty stare Evil or Very Mad
Akira
PostPosted: 10:50 - 29 Aug 2006    Post subject: Reply with quote
ooh you reckless beast you Laughing
akaDAVE
PostPosted: 10:57 - 29 Aug 2006    Post subject: Reply with quote
Far too much!
There isn't much resistance on the rear brake lever on my bike so it's hard to feel pressure especially through boots. Combined with strong front brakes the rear slides very easily.
After snaking both ways I abandoned it and just pulled hard on the front whilst I was straight.
GSXR600
andrea
PostPosted: 11:27 - 29 Aug 2006    Post subject: Reply with quote
I will practise when i have a bike to practise on!
From what i was taught, in a straight line in the dry use 75% front and 25% back blah blah, but to be honest i was taught to just use front for the e-stop as the back locks up too easily when you are loading the front. i locked the front once on a loose surface, thought i was coming off, that was scary.
Practise, practise practise though, because you never know when you might need it and id rather know what to do in an emergency rather than just grab and stomp and hope for the best (which is what i would probably do Wink )
APNess
PostPosted: 11:35 - 29 Aug 2006    Post subject: Reply with quote
Had the same yesterday. Unfamiliar roads, under trees after being in bright sunlight, road surface poor/chopped up, and junction at the end of the road with a car in front of me - if not for car slowing/stopping I'd have missed that one - no obvious junction signs that I saw, half blinded by sunlight/sudden shade anyway :S
Locked front up first, then back, then eased off slightly on both, wheels chattering away like ABS, back end of car looming up in front of me.
I stopped ok, last few feet a slide (only doing 30mph before then!) and my backside was chattering as well :S
Not something I want to practise every day, but glad I can keep my head when the easiest thing to do would have been to panic and nail the brakes as hard as poss.
Just thinking about it makes me want to nip to the loo :S
colin1
Captain Safety
PostPosted: 13:37 - 29 Aug 2006    Post subject: Reply with quote
leaving a safe gap means you dont usually need to do emergency stops
2 second gap in dry, 4 second gap in wet
watch a bit of road as it passes the car in front, and make sure it takes 2 seconds to get to you
most people seem to leave 1 second gaps or less
Dark
PostPosted: 13:42 - 29 Aug 2006    Post subject: Reply with quote
akaDave, sounds like your suspension could do with a few tweaks, its ususally the cause of instability under very hard braking
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
Itchy
PostPosted: 13:45 - 29 Aug 2006    Post subject: Reply with quote
I'd say Thumbs Up for safe gaps or space to move into if you should ever find yourself in such a situation, ie behind the right indicator or even more to the right , so you can swerve out the way , since practicing is no real indicator of how to do them in real life , I can stand the NTV on its nose if I try in a dry controlled environment , but on the road where things pop up unexpectely its a bit late to think oh I think I shall brake sharpish ,
if you regularly lock the front (I rarely do now but have done , due to people not seeing you and coming out junctions) , ABS might be an option to look for on your next
PostPosted: 13:48 - 29 Aug 2006    Post subject: Re: Emergency stops! Reply with quote
First problem seems to be using the rear brake... don't use it and it won't lock up Smile.
You can usually get all the braking you need from the front - to the point that the rear is just about to lift up - at which point braking from the rear won't do anything.
jonboy22
PostPosted: 13:57 - 29 Aug 2006    Post subject: Reply with quote
Ahhh was wondering what that funny little pedal on the right hand side did, thought it operated my wind screen wipers.....
um my back brake seems to do very very little and when I'm emergency stopping (which is very very rarely because I'm 92 and very mature) most of the time the back end will go super light as all my weight is transfered forward into "oh shit I'm going to endo" position.....
Skiddy back only seems to happen when it locks after dumping the clutch whilst emergency stopping.
current bike: GSX-R 750 K6 stolen, found the next day in a van in Durham, returned to me 3 months later costing me my NCB and my excess...
last bike: GSXx-R 600 K4 - written off, now converting to track bike Smile
colin1
Captain Safety
PostPosted: 14:01 - 29 Aug 2006    Post subject: Reply with quote
yeah id say back brake is good for dropping a bit of speed on a bend as it will make the bike oversteer and turn into the bend rather than straighten up, but under hard braking, if you use the back brake much the back wheel will slide about
under heavy braking, all the weight goes to the front, so it doesnt take much for the back to break traction as there isnt much pushing it down onto the road. Then it can slide sideways, which is probably best avoided unless you really know what you are doing.
sickpup
Old Timer
PostPosted: 14:18 - 29 Aug 2006    Post subject: Reply with quote
Always amazes me how many people claim not to use the rear brake. Tis really strange considering the amount of rear pads I've fitted to these peoples bikes over the years. Confused
In the words of Mick Doohan 'If you don't use the rear brake yer a wanker'.
Visitor Q
$25 whore
PostPosted: 14:22 - 29 Aug 2006    Post subject: Reply with quote
If it locks, let off it and start again... Rolling Eyes
Thought about this the other day, when coming round a sweeping corner and *cough cough* mph, and you suddenly need to scrub speed but you're quite leant over, does everyone else stand it up straight line BRAKE, corner, stand up BRAKE, corner etc to lose speed?
Any problems with that?
jonboy22
PostPosted: 14:35 - 29 Aug 2006    Post subject: Reply with quote
didn't quite follow the stand up etc bit but in those situations I find that I sort of progressively squeeze brake as I start to straighten it up.
Visitor Q
$25 whore
PostPosted: 14:56 - 29 Aug 2006    Post subject: Reply with quote
I mean i'll stand the bike upright, brake hard for a second or so, let off the brakes and corner heavily, then stand it up for more braking.... Etc
Only on sweeping fast bends mind you. On tight bends i wouldnt be going so fast i couldn't do that (if i couldn't see properly).
But it allows me to brake hard, slough off lots of speed, and NOT end up in the other lane. So very useful when roaring down A roads at 160 and some muppet decides to randomly swap lanes.
Dom_
Points Mean Prizes
PostPosted: 15:24 - 29 Aug 2006    Post subject: Reply with quote
Emergancy stops are horrible, bars wobbling like fook, tyre screeching now and again due to warped disk (sounds a bit like abs)
Thats a real emergancy stop btw, not just stopping quickly for an examinor.
Trixie
PostPosted: 16:00 - 29 Aug 2006    Post subject: Reply with quote
I had an instance on the bike a few weeks back. I rounded a bend and had to scrub off the speed Very Quickly Indeed due to a line of cars at a standstill on my side of the road and a bunch of Coppers the other side tending to some sort of spillage with no room to get through. A grass bank on one side of the road and a 50' drop to the sea the other side gave me no room for manouvre. I had to brake from a fair speed, as I was in a derestricted zone at the time.
I seriously thought that was it and that I was either coming off or I was going to hit something; my bike has crap brakes at the best of times.
Needless to say I bought some braided stainless hoses the next day.
Dead nobodies in company cars...
The last post was made 20 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.14 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 106.91 Kb
