Old 'keycode' radio help
JodieWodie
Reflective Banana
PostPosted: 21:19 - 12 Sep 2006    Post subject: Old 'keycode' radio help Reply with quote
Hi all
Thanks in advance for any help offered.. Karma
I basically have a keycode radio in my 'new' (not) car
It has power to it, so it is not a fuse or anything
The screen lights up, but is blank..does not say anything
There was a tape stuck in it, but that popped out of it's own accord yesterday
But still no joy with radio Sad Nada
Could it be that someone has programmed a code into it and I simply don't know it ?
Or would it ask for a code ?
(Never had a k code one before)
If there is no hope I will just have to rip it out and buy a new one
Cheers
JO xxx
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
LustyLew
PostPosted: 21:27 - 12 Sep 2006    Post subject: Reply with quote
Make/model of the car?
Most 'factory fit' radios come with a key-code of sorts.
JodieWodie
Reflective Banana
PostPosted: 21:30 - 12 Sep 2006    Post subject: Reply with quote
It is an L reg Ford Fiesta
1.1
LustyLew
PostPosted: 21:36 - 12 Sep 2006    Post subject: Reply with quote
Ahhh, yes I had to replace my sisters for this exact reason.
You can pick up new stereo's off ebay for next to nothing these days. Simple CD/Radio. Chances are the Ford one is probably knackered!
Seems to be places online that will do it for a fiver if you can get to the serial number. (Need to remove the front of the centre console (screws behind the ash tray) to get at it).
DucatiEVO
PostPosted: 21:47 - 12 Sep 2006    Post subject: Reply with quote
Normally a code radio will actually say 'CODE' when you first turn it on, IF a code is required. Sounds to me like it's knackered, power to the screen (and hence it lights up), but no display.
Perhaps the electronics are duff.
I recall you used to be able to throw the early radios in the freezer overnight to reset them though!
aKa: Ducky
Phil_G
PostPosted: 21:53 - 12 Sep 2006    Post subject: Re: Old 'keycode' radio help Reply with quote
JodieWodie wrote:
Hi all
Cheers
JO xxx
1) See if you can get a manual for this radio. Some will only activate the code entry sequence after pushin some buttons in a certain way
2) check the fuses anyhow as your stereo should have TWO live feeds. One is a permanant feed that takes care of the radio memory and suchlike, and one is a switched current which enables the radio to come on with the ignition. Sometimes, with one powerfeed the radio will function and sometimes it may just "light up"
I only say to check this as I had a customer come to me once, and declare their radio dead as it "just stopped and wont come on apart from the lights". It turned out that they had hit a power interrupt in the drivers cabin (it was a big lincoln TownCar limo) and the radio was actually fine. It also saves potentially shelling out for a radio only to have it still be "faulty"
Phil
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
Nb
PostPosted: 21:57 - 12 Sep 2006    Post subject: Reply with quote
Sounds like the radio is faulty. What happens when you press any of the buttons?? You dont get 4 dashes appear do you?
The last post was made 20 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 53.48 Kb
