Things to do when buying a new bike...
veeeffarr
PostPosted: 21:51 - 18 Sep 2006    Post subject: Things to do when buying a new bike... Reply with quote
What do you guys do mechanically to a bike when you first buy it privately?
At the moment I'm thinking
Arrow Change oil
Arrow Change brake fluid
Arrow New plugs
Arrow Clean air filter
Anything else I could have in mind? The bike in question is a '95 GS500E.
PS: The rear tyre is a BT45, the front one a Dunlop? Is this a problem or should I just leave it as is?
Ta
Toby
mr.z
PostPosted: 22:00 - 18 Sep 2006    Post subject: Reply with quote
Isn't it a paper filter? (if it i then needs replaceing really if it needs it)
Fork oil change is worth doing too, and coolant change (allthough you can skip that one Razz)
If your feeling really fruity tappets, and then carb ballance (just so you know how long it'll be till it needs it)
Headstock bearings check/tighten
Rear wheel allignment (chain adjuster buisness)
If the bike handles fine then its not a problem, changing them would be a waste of money unless there knackered anyway (or has been stood a year unused or something)
veeeffarr
PostPosted: 22:01 - 18 Sep 2006    Post subject: Reply with quote
Fork seals were done recently.
Bike has done about 500ish miles in 2 years
Tyres are new though, with the front dunlop being newer than the BT45
Ichy
PostPosted: 22:03 - 18 Sep 2006    Post subject: Reply with quote
Don't worry about the tyres until its time to change them, unless they have unusual wear or damage or your feeling unsure about them. Its all down to the bike giving you confidence.
Tyre pressure
Chain
steering
pads
swingarm play.
bulbs
make sure theres a spare fuse in the fuse box.
I realise it has an MOT but its really worth going over it all. Gives me a bit of confidence knowing that I've touched virtually all the nuts and bolts. Guess I'm just a bit paranoid after finding one bike I brought only had the bottom yolk bolts tightened, the top ones had been fitted but were only hanging in by a couple of threads.
colin1
Captain Safety
PostPosted: 22:10 - 18 Sep 2006    Post subject: Reply with quote
id only replace what has worn out, but i guess putting all new consumables in does sort of stamp your mark on it and its reassuring that nothing needs doing for a bit
veeeffarr
PostPosted: 22:11 - 18 Sep 2006    Post subject: Reply with quote
I wonder what a full service will include and how much it will be, I'd happily pay for peace of mind if it wasn't too much.
cagiva gezzer
PostPosted: 22:12 - 18 Sep 2006    Post subject: Reply with quote
Decent pads and a brake check.
iCraig
PostPosted: 22:15 - 18 Sep 2006    Post subject: Reply with quote
Toby, what Dunplop is it?
If its an Arrowmax, replace it as soon as humanly possible!
As for a service would cost around £150, but it'd be fairly easy to attempt yourself on a GS500E, with only 4 valves and everything else pretty simple it'd be easy to do yourself. I'd even give you a hand if you wanted!
veeeffarr
PostPosted: 22:24 - 18 Sep 2006    Post subject: Reply with quote
Cheers matey, yeah it's an arrowmax, name rings a bell.
The last post was made 20 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.39 - MySQL Queries: 16 - Page Size: 63.36 Kb
