| proximity |
 proximity Crazy Courier
| 0ddball |
 0ddball World Chat Champion
| Pete. |
 Pete. Super Spammer
| bish777 |
 bish777 World Chat Champion
| Pete. |
 Pete. Super Spammer
| proximity |
| 0ddball |
 Posted: 19:51 - 20 Sep 2006 Post subject: |
The ecu need to know the position of the crank so it can fire the injectors and plug at the right time. It's a toothed wheel like this
https://www.seanhylandmotorsport.com/online/images/8400.jpg
That need to be mounted very precisely to the end of the crank, i guess it would have to go on the flywheel on a bike.
And a sensor like this
https://www.siemensvdo.com/NR/rdonlyres/B151E880-0F79-4D15-B831-1055312575BF/0/sv_S107230001Z_192x146.jpg
Which has to be mounted so that the teeth of the trigger wheel pass it closely which either creates a sinewave signal by induction, or switches an applied voltage to create a square wave depending on whether you choose to go analogue or digital.
The missing tooth is what the ecu uses for reference. You mount the wheel at say 20 degrees btdc on the crank then tell the ecu that the missing tooth is at that position. That way it knows everytime it senses the missing tooth the crank will be at 20 degrees btdc and it can reference all it's calcualtions based on that.
The primary trigger most often used is the crank sensor, you can also use a cam sensor (same idea but mounted on the end of the cam) either as the primary trigger instead of the crank sensor, or as an aditional reference for the ecu is you want to have sequential injection. |
| ROB_NSR |
 ROB_NSR Nitrous Nuisance
| Pete. |
 Pete. Super Spammer
| edd |
 edd Nearly there...
 Posted: 20:02 - 20 Sep 2006 Post subject: |
you only need a crank sensor if you are running sequential injection, non sequential injection doesnt require one. TBH for the extra effort required to go sequential I wouldnt bother. A great deal of setups use non sequential injection to great effect. You also dont need a crank sensor for ignition If you are happy using the existing one. (presuming your bike runs electroninc ignition, which in your case I know it does.) ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| 0ddball |
| proximity |
 Posted: 20:16 - 20 Sep 2006 Post subject: |
I just found this on the megasquirt site;
| Quote: | Then there are three common modes of injection timing:
* batch - all injectors fire at once, but not timed to any specific cylinder,
* bank - ½ the injectors fire at once, but not timed to any specific cylinder,
* sequential - each injector fires at a specific point in the 4-stroke cyle for each cylinder (i.e., 8 independent timing events)
Throttle body injected cars are usually batch or bank fire, simply because of the geometry. Most port injection set-ups before the mid-1990s were bank fire as well (including GM Tuned Port Injection for the 305/350).
Sequential injection requires:
* as many injectors as you have cylinder, with one dedicated to each cylinder (i.e., not a 4 injector TBI on a 4 cylinder).
* as many injector drivers as you have cylinders,
* and also requires a camshaft position sensor (a crank sensor is not adequate for a 4-stroke cycle engine).
MegaSquirt has just two injector drivers (that can handle up to ten injectors each), and no provisions for a cam sensor signal, so it would be difficult to make it into a sequential injection system. |
____________________ 2004 Aprilia Tuono |
| edd |
 edd Nearly there...
 Posted: 22:41 - 20 Sep 2006 Post subject: |
Im not really sure what you mean by a reference signal. You can build a 3d map using just either throttle position, MAP or airflow sensor plus RPM (more factors help you to create a more accurate map, but these are all that are neccesary) . Your RPM is extremely accurate form the halls sensor on the crank, it has to be otherwise your spark wouldn't occur at the right time. What it doesnt tell you is when to inject for a sequential injection system because it only gives one pulse every revolution. Sequential injection does most certainly require a cam or crank sensor to determine position. Without this sensor there would be no way to tell whereabouts the intake cam was, mostly because the intake valve only opens every 2nd revolution. ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
 Posted: 23:07 - 20 Sep 2006 Post subject: |
Don't know about a bike, but I know a few peeps using MS on their cars, I intend to get one also for my project Quattro. Darn sight cheaper than a motec and just as tuneable.
 ____________________ aKa: Ducky |
| 0ddball |
| Pete. |
 Pete. Super Spammer
| proximity |
| Pete. |
 Pete. Super Spammer
| edd |
 edd Nearly there...
 Posted: 00:16 - 21 Sep 2006 Post subject: |
Id agree that EFI would be better with the system you propose, and I also realise you know what you are talking about. I have read up quite a bit on EFI, and I'm pretty sure early EFI bikes did use a halls sensor and non sequential injection. For example the GPz 750 R1. I know your EFI system must react fast, but your spark must be in exactly the right place every revolution. Even at 3000 RPM you are doing 50 rpm per second and as such getting 50 sparks a second. If you take the RPM signal from the CDI and run that into your megasquirt it should be able to calculate the gap between pulses and give you a result in 1/25th of a second (processing time is negligible). Thats not uber quick, And probably wouldnt give you as smooth fuelling as you'd like. At 6k I think it would probably be relatively unnoticable. Again I know it wouldnt give the butter-smooth EFI you guys are probably accustomed to, but I think it would work. At least I cant see any reason why. I may well have got these calculations wrong if I have please tell me. ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
| 0ddball |
The last post was made 20 years, 37 days ago. Instead of replying here, would creating a new thread be more useful? |
