| kawakid |
 kawakid World Chat Champion
 Posted: 17:59 - 22 Sep 2006 Post subject: RAF are useless. |
Pretty bad comments from such a senior soldier.
Makes you wonder, what the RAF are good for, if they can't support the infantry. Comments like we call in the americans because they offer better support, doesn't sound good to me.
Soldiers crying, because they've been abandoned by the flight boys.
They might be good for shooting down the odd mig, but what abount engaging ground targets.
Probably another daming account of our armed forces, being pushed to the limit.
https://news.bbc.co.uk/1/hi/world/south_asia/5371392.stm |
| Mister James |
 Mister James I want to believe!
| king kong |
 king kong Nearly there...
| carvell |
 carvell Scuttler
| Mister James |
 Posted: 21:16 - 22 Sep 2006 Post subject: |
| Kickstart wrote: | Is a Harrier really the best choice of aircraft for ground support against "infantry", or just chosen because they are available and can travel rapidly to where required (rather than using greater numbers of local and more suitable aircraft).
Keith |
Longbows would be far more use, they are specifically designed to engage ground targets in a CAS role, whereas the Harrier's use is negated by its vulnerability if operated at low speeds.
Some good ol' Hind D's would do the trick, it was about the only thing the Russians had that scared the Mujihadeen back in the day. I'm sure we could buy some cheaply off a tin-pot ex-Sovbloc state and retrofit them for pennies.
| Quote: |
Consider also ordenance that the Harriers may have at their disposal at the time of request for air support, 25mm Aden canon, LGBs' etc. Did these incidents highlighted occur at night or day. The Harrier GR7, GR7A are equipped with FLIR (forward Looking Infra Red), but the images are no better than greyscale.
The article specifically mentions 25mil strafing runs and CR7's - both specifically carried for CAS, so there is no real excuse to be found there. ____________________ >Soultrader Mister James, I bet you are a copper
>Bazza Wow. Eyes like a shithouse rat, you... |
| king kong |
| zaknafien |
 zaknafien
| Mister James |
| Rovman |
 Rovman Scooby Slapper
| WildGoose |
 WildGoose White Van Man
 Posted: 13:32 - 23 Sep 2006 Post subject: |
| Quote: | The Harrier pilots are only as good as the Forward Air Controllers(FACs'). |
they can designate their own targets just as easily as they can pick up a designation from a FAC, that is to say if they are even using laser guided weapons
was never fitted operationally to any harrier GR7 due to the composite construction of the GR7 over the alloy of the sea harrier, tests have shown that the canon (a design from the first half of the century) puts far too much strain on the airframe and basically rips it to pieces in the air
| Quote: | Also consider the fact that the Harriers time on target is limited to avoid surface to air contact, they're high up and travelling at 600 mph. |
they will be very very low to increase the effectiveness of the show of force, its been shown that often a low and loud flyby is enough to give the opposing force a kick up the backside and fuck him off
furthermore, you cant fire CRV-7 rockets effectively from altitude
regarding the best aircraft for the job, the harrier is all we have that can operate from dumps like kandahar and actually get to the target quick enough, doesnt mean it will be particularly good...as its probably the most susceptible aircraft in the fleet to foreign object damage causing great amounts of unserviceability, FOD is rife in places like iraq and afghanistan
pisses me off every ignorant fool will start bad mouthing the services because of one dodgy news bulletin from the bbc suddenly makes them an expert
there is no money, the harriers are dated and falling apart, there are no spares, no tools. aircraft are being cannibalised just to keep others in the air, serviceability as the airframes age is dropping to somewhere in the region of 50-60 hours on the ground for every 1 flying, and morale is rock bottom
and yet the government just continue taking more money out, whilst demanding longer tours of duty, excessive sorties, longer hours for pilots and groundcrew, and then one major gets the hump because the close air support wasnt quite close enough
by all means call in the americans, they have the money and equipment to sort you out  ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| king kong |
 Posted: 16:03 - 23 Sep 2006 Post subject: |
Wildgoose I stand corrected about the Aden canon.
The Harrier uses a variety of weapons such as laser and GPS-guided bombs against buildings (Paveway), infra-red missiles against tanks (Maverick), cluster munitions and general-purpose bombs. When required, the Harrier can also be fitted with a pod fitted with cameras to provide reconnaissance of the target and battle areas. |
| Mister James |
 Posted: 23:11 - 23 Sep 2006 Post subject: |
King Kong - Goose used to be a spanner monkey on them  ____________________ >Soultrader Mister James, I bet you are a copper
| king kong |
| shaun_04 |
 shaun_04 Brolly Dolly
| plugger147 |
 plugger147 World Chat Champion
 Posted: 22:23 - 26 Sep 2006 Post subject: |
One of the guys who works with me is ex raf and if he's anything to go by useless would be a mojor compliment.  ____________________ Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me... |
| killa |
 killa Won't Shut Up
 Posted: 10:23 - 27 Sep 2006 Post subject: |
Certainly that A-10 is something you wouldn't want to be on the receiving end of.
I'm not to up on the technicalities but helicopters surely are the better choice, especially in a small group.
lol at Mr James, the Hind would scare the towel heads away even before it let off a round.  ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| bazza |
 bazza World Chat Champion
| Mister James |
| colin1 |
 colin1 Captain Safety
| Mister James |
 Posted: 11:16 - 28 Sep 2006 Post subject: |
Humvees are better protected than the Snatch LR's, but we are getting some other american kit which is even better.
https://www.forceprotectioninc.com/models/cougar/
Take a butchers, they're quite cool looking, in an ugly sort of way. Supposed to provide protection against IEDs and RPGs. ____________________ >Soultrader Mister James, I bet you are a copper
| killa |
 killa Won't Shut Up
| colin1 |
| killa |
 killa Won't Shut Up
The last post was made 19 years, 320 days ago. Instead of replying here, would creating a new thread be more useful? |
