| RedEye |
 RedEye L Plate Warrior
| andy198712 |
 andy198712 Borekit Bruiser
| RedEye |
| wristjob |
 wristjob World Chat Champion
| RedEye |
| hmmmnz |
 hmmmnz Super Spammer
| Dischord |
 Dischord World Chat Champion
 Posted: 14:17 - 25 Sep 2006 Post subject: |
For the 05+ models it is different but from what I've gathered -
1) take the headlight off, find the block connector with the black and green wires going to it. Disconnect then earth the wire, like you say you've done this!
2) Buy yourself a full DEP system, before fitting it check where it connects onto the expansion chamber for a restriction washer. It shouldn't have one but some do, if it does pop it off with a screwdriver. Now your exhaust is fully derestrcited.
3) Intake is the next bit. either but a foam bolt on filter or modify the stock airbox. Remove the cover but leave the foam filter in. (I would personally buy something like a ramair filter).
4)If the carb is a 28mm Mikuni like on the old models whack in a 220 mainjet (racespec.co.uk sell them) you can also lower the clip on the needle to the bottom, this will make the bike run slightly richer but give it more fuel. Only needed if you've modified exhaust and intake, don't use a 220 mainjet on stock setup.
5)examine reed block for restrictions, possibly add carbon fibre reeds.
6)adjust and open the powervalve.
https://img169.imageshack.us/img169/6352/ffmx3.png
one you've done athat to the servo you should notice less torque in lower RPM but more snap at high RPM and hopefully more speed.
Other than those things you can't really do much, sprockets are an option, just don't over gear or it will have trouble pulling til 10,00rpm and against wind etc.
Also the CDI's are restricted, I think the pre-96 UK DT CDIs are free from restrictions as are foreign DT CDIs so try get your hands on one! :d ____________________ 2012 KTM EXC 250
Check out my vids - https://www.youtube.com/user/KTMSparky/videos |
| Dischord |
 Posted: 14:20 - 25 Sep 2006 Post subject: |
DOUBLE POST ____________________ 2012 KTM EXC 250
| Leggy_Girl |
 Leggy_Girl World Chat Champion
 Posted: 10:34 - 26 Sep 2006 Post subject: |
The most i've had so far out of my derestricted, 05 DT125X is 80mph (before i have to slow down because it's rattling so much it's going to spit me off ), and 85 ish down hill.
It's only a 125 tho, so i don't really expect it to go any faster. ____________________ "One moment can change a day, one day can change a life and one life can change the world." Siddhartha Gautama |
The last post was made 19 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
