Changing brake fluid / GTMoto Brake Bleeding Kit
veeeffarr
PostPosted: 17:09 - 25 Sep 2006    Post subject: Changing brake fluid / GTMoto Brake Bleeding Kit Reply with quote
Hi guys,
Anyone know the procedure for changing brake fluid? My stuff is brown and spongy as fuck...
I can't get hold of a GS500E manual at the moment and it needs doing.
Are these any good? Theyre in Halfrauds for a tenner: https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_195481_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_33975_crumb_33965_parentcategoryrn_33975
Also what brake fluid should I use? Seen some Castrol DOT4 stuff in Halfrauds.
Cheers.
veeeffarr
PostPosted: 17:39 - 25 Sep 2006    Post subject: Reply with quote
BLUEX5 wrote:
Shouldn't be too tricky to bleed if you want fresh fluid in. Just attach a length of clear pipe to the caliper nipple and take the lid off the master cylinder. Slacken the bleed nipple and pump the brake lever, the level will fall (don' let it fall too far or you'll get air in the system). Top up with fresh fluid, repeat till clean fluid comes out the caliper, tighten bleed nipple with lever back to bars, top up master cylinder, refit lid, job done.
What do you mean the lever will fall? As in fall towards the throttle grip?
Cheers,
T
T1z3R
PostPosted: 17:48 - 25 Sep 2006    Post subject: Reply with quote
its easy Toby and that kit from halfords will do the job.
and im 99% sure theres instructions in the packet Thumbs Up
duck my sick!
veeeffarr
PostPosted: 18:04 - 25 Sep 2006    Post subject: Reply with quote
Going round to a mates tonight who's gonna help me,
Will fit braided lines at some point too when I've got a bit more cash lol.
The rear brake pedal has a lot of travel and feels squishy as fuck so I'll do that one too.
Cheers,
T
0ddball
What type of fluid reservior do you have. If it's the round pot type it's much better and easier to pressure bleed them with a Gunson EZbleed for £15.
Pumping the lever gets the brakes working ok but imo never gets all the air out.
veeeffarr
PostPosted: 18:08 - 25 Sep 2006    Post subject: Reply with quote
Nope it's rectangular Sad
Bendy
Mrs Sensible
PostPosted: 18:09 - 25 Sep 2006    Post subject: Reply with quote
There a couple of guides to doing your brakes in the workshop sticky.
kenny
PostPosted: 18:22 - 25 Sep 2006    Post subject: Reply with quote
motrax do a nice no-return brake bleeding tube kit works a treat so you can do it by yourself without any help. hardest part is making sure you dont let the resievour run out of fluid.
as for brake fluid type get a synthetic type castrol or some equal good make will do the trick
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
veeeffarr
PostPosted: 19:02 - 25 Sep 2006    Post subject: Reply with quote
I think all I need to do with this kit is mount it over the nipple and squeeze the brake lever, and then click the valve until the fluid is out while filling up the master cylinder...
nrml76
PostPosted: 20:46 - 25 Sep 2006    Post subject: Reply with quote
I bought the halford thingie, found it useless and threw it away (the valve wasnt any good). I ended up using a piece of tubing and a syringe. I have heared very good things of the mityvac kit, but it is much more expensive. https://www.mityvac.com/pages/products_hvpk.asp#MV6817
fazed
Korn is my hero!
PostPosted: 21:05 - 25 Sep 2006    Post subject: Reply with quote
Learn to do it the old way with a bit of clear tube, it really isn't to hard. Smile
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
KTM Gordo
PostPosted: 21:16 - 25 Sep 2006    Post subject: Reply with quote
Yes, you can buy a special kit, or you can get a length of plastic tube from B&Q for 50p.
I did mine at the weekend, and as long as you can reach the brake caliper and lever/pedal at the same time, you can do it yourself.
Take your time, and keep an eye on the reservoir as if you run out of fluid in it you'll have to start again.
Where abouts are you? You're welcome to drop in for a brake bleeding session at Gordo Towers (Cambs).
HTH Smile
Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4
veeeffarr
PostPosted: 23:30 - 25 Sep 2006    Post subject: Reply with quote
I've done it
That halfords thing was fucking awesome, don't need to close the nipple every time.
Nearly did a stoppie at the first set of lights... LOL
Also adjusted my chain and other bits, so I'm all set Very Happy
Washed the kit out with water and left it at me mates tho lol (Don't worry, the valve comes apart to clean so I'm not going to be putting water in the brakes LOL
Delvard
PostPosted: 09:34 - 26 Sep 2006    Post subject: Reply with quote
Toby R wrote:
I've done it
So that overpriced piece of crap is actually worth the money? Brilliant. How does it work?
A thing of beauty is a joy for ever: Its loveliness increases; it will never Pass into nothingness; but still will keep A bower quiet for us, and a sleep Full of sweet dreams, and health, and quiet breathing.
veeeffarr
PostPosted: 09:47 - 26 Sep 2006    Post subject: Reply with quote
It's a clear plastic tube that attaches to a valve, lets the fluid through but doesn't let anything back up so you don't need to tighten and untighten the bleed nipple, you just leave it open.
the grim reaper
PostPosted: 13:18 - 26 Sep 2006    Post subject: Reply with quote
Or you could leave the nipple open and just use a bit of tube. When you are happy with the fluid coming out of the caliper, you squeeze the lever to the halfway point slowly while tightening the bleed nipple. Save yourself a tenner.
Grim
veeeffarr
PostPosted: 14:49 - 26 Sep 2006    Post subject: Reply with quote
Grim
Oops, I didn't squeeze the lever while tightening the nipple
the grim reaper
PostPosted: 09:49 - 27 Sep 2006    Post subject: Reply with quote
If you're using a valve, you shouldn't have to.
What happens when you let go of the lever is that the seals regaining their shape pull the pistons back into the caliper ever so slightly. When the bleed nipple is shut, this draws fluid into the caliper from the reservoir, when the nipple is open, this draws air into the caliper through the nipple. The valve should stop this happening.
FYI, I always do another minor brake bleed a week after the first one, any tiny air bubbles should have vibrated up to the bleed nipple with riding. All you have to do is to crack open the nipple and do about half a squeeze on the lever then tighten the nipple whilst holding the lever at the halfway point.
Grim
Cillit-BANG
PostPosted: 11:43 - 27 Sep 2006    Post subject: Reply with quote
I found that Halfords thing was crap and got a refund. I think it was the same as the Motrax 'Mini-Bleeder'
I really couldn't work it out as no matter how I practiced with pipes, syringes and water it always let fluid, and air in from both directions as the ball bearing inside wasn't a good enough seal.
I thought it was going to be the wonder kit for a tenner, but went back to doing it the old manual way.
If your looking for braided hoses, there is a guy on Ebay (wezmoto iirc) who sells goodridge complete kits for £40. They are Zinc fittings not stainless but these are fine for general day to day use. I've had a set for a while now and they have been great.
Itchy
PostPosted: 14:00 - 27 Sep 2006    Post subject: Reply with quote
buy some goggles from machine mart of something , Brake fluid can make you go blind if it goes in your eye ,
if you see what it does to paint , think what it can do to your eye.
The last post was made 20 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 116.59 Kb
