| stinkwheel |
 Posted: 22:29 - 26 Sep 2006 Post subject: Carburettion setup for KLE/GPZ. *updated* |
Ok, the bike is a KLE500.
It has a GPZ500s engine in it complete with the CDI that goes with that engine.
It has a 'wide open' sports exhaust system designed for a KLE500. Basically a 2-1 with an unbaffled end can, made by laser pro-duro.
When I first fitted the engine I used the carbs that went with the engine (the GPZ ones). With these fitted the engine was totally dead over 6,000rpm. No power, cutting out, as if the throttle had reached a 'stop'. I tried removing the airbox, this made it even worse.
So, I fitted the carbs off the KLE (same choke diameter). It runs ok with these and will rev to the redline (eventually). It has increased midrange but nothing like the top-end you get from a GPZ500, no howl of acceleration, just a steady and rather slow climb. Nothing to be gained by pushing it over 8,000rpm.
The bike is currently perfectly rideable and somewhat better than in standard KLE guise, I just know it could be so much better
The KLE airbox is half the size of the GPZ one.
So, my thoughts revolve around the airbox/carb combo not matching the engine setup.
The way I see it I have three options:
1) Fit a dynojet kit and free-flowing air filter designed for a KLE500 which would retain the airbox, something I have always thought of as desirable. Given the GPZ engine is essentially a 'tuned' KLE lump, this should work.
2) Go the whole hog and fit a stage 3 kit and pod filters designed for the GPZ motor. Do away with the airbox and learn to live with any problems assosciated with this.
3) But a selection of main jets and have a fanny about myself.
Of course, taking the bike to a dyno centre would be the best course of action. There isn't one I am aware of that I'd entrust my bike to less than two and a half hours away from where I am in North Cumbria (ie, there's one in Edinburgh).
Any comments would be welcome, especially with experience of using a stage 3 setup on a road bike which does reasonably high mileages.
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
| sickpup |
 sickpup Old Timer
| Kickstart |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 23:47 - 26 Sep 2006 Post subject: |
id put the original carbs and airbox back in, checking that the carbs havnt been restricted, (extra hole in the slides or smaller jets)
but possibly the carbs and airbox you have in now could be tuned to the new engine with out too much trouble.
i wouldn't go the pod filter route, i havn't managed to get my set up perfect yet even after 6 rejets and numorus tweaks it seems to play one area off another,
check that all the rubbers from air box to carbs and carbs to engine havn't got any leaks,
check the jet needle is set to the right clip position and the float needle valve isn't worn,
my guess is you are running lean, and bigger mains are in order,
all just speculation on my behalf with out riding it i'd never know
what colour are your plugs??
good luck ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| stinkwheel |
| hmmmnz |
 Posted: 02:18 - 27 Sep 2006 Post subject: |
right well the exhaust really wont make to much difference to a 500 (mabee a teeny tiny bit leaner nothing worth worrieing about)
but the air box, thats a whole different kettle of fish,
if you can fit the original airbox in there i'd do that, other wise you'll have to figure if the smaller air box is sucking more, or less air through.
if there is a leak between the carbs you have on there now and the airbox you will be running lean, get those rubbers on there if you arnt going to put the orinal box back in
good luck
| Kickstart |
| hmmmnz |
 Posted: 11:43 - 27 Sep 2006 Post subject: |
hmmm is that how it works kickstart(always good to know these things), but compared to the airbox and jetting its a small thing, i changed my exhaust over(also a 500) to a free flowing one no baffles, and it didn't make any difference at all (a hell of alot noiser for the most part). i dare say the system he has in there isn't much different in lenth to the orignal any way.
just my opinion of course  ____________________ the humans are dead
| Kickstart |
 Posted: 21:44 - 27 Sep 2006 Post subject: |
Silencer isn't that important compared to the downpipes and how they join up.
Given that he has an exhaust designed for use on a KLE engine it is probably designed for power lower down, probably peaking not long after a GPZ would want to take off. If you used that along with single filters with no ram tube them that might try and move peak power further up the rev range. Then the GPZ cams. Result is you have an engine that is trying to peak at (rough example) 8000rpm (exhaust), 10000rpm (cams, ignition, etc) and 12000rpm (carbs). Results in no real top end performance. Say each of those is worth 5hp at their peak, then on a bike making 60hp at peak, 15hp is down to those items all peaking at the same moment. Move them out a bit and at that same peak you now only have 50hp (all VERY rough figures).
| hmmmnz |
| stinkwheel |
 Posted: 02:34 - 01 Oct 2006 Post subject: |
I've been tinkering this weekend.
The exhausts are exactly the same diameter on both bikes, roughly the same length although there are sharper bends on the KLE ones. The airbox rubbers are identical. The inlet stubs are the same length.
I was going to try the GPZ needles in the KLE carbs. Bloody flange snapped on the carb casting as I was undoing the top of the carb so I've only got the GPZ carb bodies to play with now.
Gave them a good clean in the ultrasonic bath at work (they've done 65k miles and looked it) and washed all the jets in benzene followed by ether. (whoo. head rush!) so there is categorically no crap in there.
So, what now? Well, I had another fiddle, tried the GPZ main jet (112->130) with the KLE needle. Didn't like that, filled the airbox with petrol.
Tried the GPZ needle with the smaller jet. Ran, but with the same 'brick wall' in the rev range, although now moved closer to 8k.
Tried the KLE needle and jet in the GPZ carbs. Runs pretty well, more top-endy. Still not as much as the GPZ but better. I can only put this down to the 'power jets' being different between the two sets of carbs because the choke is the same diameter.
So, what I've learned from this.
1) Definately the airbox causing the problems.
2) The needle and jet need to match the airbox, not the engine.
This means if I get a performance jet kit and filter designed to work with the KLE airbox, I should get results.
Also noticed some differences between the two sets of carbs. There is a balance pipe on the KLE ones which is not present on the GPZ ones.
There is also a 'bit' bolted on the side of the right hand carb of the KLE carbs. I don't know what it is and does? I see from the manual it is called a "coaster enricher". I presume this is what makes it 'pop-pop-pop' as you're going down hills on a closed throttle. What would the implications be of not having this? Would I need to blip the throttle periodically like you do on a 2-stroke? (picture attached) |
| 0ddball |
 0ddball World Chat Champion
| stinkwheel |
| finpos |
 finpos World Chat Champion
 Posted: 11:33 - 01 Oct 2006 Post subject: |
Also well known for the diaphagm splitting when they get older, letting MORE air into the carb and making the decelleration popping problem much worse . Present on plently of big-cylinder bikes from the 80s.
By the way, that lumiweld stuff works like magic on bits of snapped off carbs.
finpos. |
| stinkwheel |
| tsmith |
 tsmith Traffic Copper
 Posted: 00:07 - 03 Oct 2006 Post subject: |
The last post was made 20 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
