GS500E/S - "Knocking" noise coming from chain
veeeffarr
PostPosted: 23:21 - 28 Sep 2006    Post subject: GS500E/S - "Knocking" noise coming from chain Reply with quote
Hi,
Just pushed my bike in to park it, and noticed a knocking noise coming from around the front sprocket area.
Bike was in netrual.
Recently adjusted the chain, every time I slow down for lights etc I notice a "tearing" sort of sound, sounds like tyres (but its not)
Also when I push it forward I can hear a metallic "brushing" sound, Is this normal?
Cheers,
T
Blackrhythms
PostPosted: 23:29 - 28 Sep 2006    Post subject: Reply with quote
Hi Toby. Was the wheel properly balanced after adjusting the chain? It's possible that it's slightly off track, causing the chain to rub where it should be moving freely.
Cool
veeeffarr
PostPosted: 23:32 - 28 Sep 2006    Post subject: Reply with quote
Pretty sure it is, swingarm notches are lined up
Blackrhythms
PostPosted: 23:37 - 28 Sep 2006    Post subject: Reply with quote
Hmmm! Thinking What about the condition of the chain - is it still in good nick - is there much more room for further adjustment?
Cool
Bendy
Mrs Sensible
PostPosted: 23:38 - 28 Sep 2006    Post subject: Reply with quote
The swingarm notches are a work of fiction, wouldn't rely on them.
edd
PostPosted: 23:41 - 28 Sep 2006    Post subject: Reply with quote
swingarm notches are well known to be as accurate as a pea shooter Wink
Bluespark Automotive - Diesel Tuning for Performance and Economy
veeeffarr
PostPosted: 23:50 - 28 Sep 2006    Post subject: Reply with quote
Chain is in Okish nick, about 30% along adjusters.
Some tight spots, got some latex gloves on and a lot of chain lube and freed them up.
KatOwner
PostPosted: 23:51 - 28 Sep 2006    Post subject: Reply with quote
Could be something as simple as the chain rubbing on the chainguard.
If the front sprocket has never been changed it may be that the thing has worn and the teeth are 'hooked'. Tightening up the chain might have made that more noticable.
Also... have you checked to make sure your chain is not over-tight? Always run it around when adjusting and make sure you are measuring the free-play at the tightest point. If you have a tight spot on the chain, this can also get noisy.
Finally....how often do you lube the chain? If it's dry, then it will get more noisy than a well lubricated one.
PostPosted: 00:38 - 29 Sep 2006    Post subject: Reply with quote
Tight spots will make a chain "knock" as you call it. If you had tight spots, your chain is ruined and you need a new one. If your chain snaps the power of the engine can cause it to bunch-up inside the sprocket cover and punch through the engine cases.
veeeffarr
PostPosted: 00:43 - 29 Sep 2006    Post subject: Reply with quote
Buggeration, is there a botch I can do in the mean time? I am completely fuckerated money wise
Blackrhythms
PostPosted: 00:46 - 29 Sep 2006    Post subject: Reply with quote
Not really Toby - only take it very very handy when riding!
Cool
veeeffarr
PostPosted: 00:49 - 29 Sep 2006    Post subject: Reply with quote
Will do
I'm commuting on 40 limits so I'll shove in top gear all the way for the time being
Whosthedaddy
PostPosted: 00:50 - 29 Sep 2006    Post subject: Reply with quote
<cough cough>
https://www.bikechatforums.com/files/fzr600_073.jpg
veeeffarr
PostPosted: 00:53 - 29 Sep 2006    Post subject: Reply with quote
Well I don't want _that_ to happen Sad
Whosthedaddy
PostPosted: 00:57 - 29 Sep 2006    Post subject: Reply with quote
Found it today when I was trying to clean it up a little.
If a loose chain can smash through steel its going to make a mess out of your leg Sick
KatOwner
PostPosted: 20:15 - 29 Sep 2006    Post subject: Reply with quote
Unfortunately, when it comes to chains, it's prevention not cure.
A tight spot happens when the particular pin running through the link has siezed due to lack of lubrication and wear. This stops the thing from flexing like it should.
If it's not too bad, you might get away with it for a while, but expect your chain to stretch badly. If it's bad...then you get something like the picture above..... The gearbox sprocket is the bit where the chain run curves the most...and what happened there is a result of the chain not following the curve it had to in order to get around the sprocket. It snags up and horrible things happen as chain and sprocket part company at speed.
Might be worth trying to scrounge a chain from a scrappy if you know a good breakers near you. Nobody buys second hand chains....so you might get a bargain to see you through until you can afford to get a proper chain to replace yours.
veeeffarr
PostPosted: 20:23 - 29 Sep 2006    Post subject: Reply with quote
I've seen a DID kit for £73 on Wemoto, I think I might be able to get that.
Don't they come with a normal link and a split link? If I split the link and ride it to a garage to you think they'll crimp up the proper link for me FOC? Smile
EuropeanNC30R...
Gay Hairdresser
PostPosted: 20:33 - 29 Sep 2006    Post subject: Reply with quote
Definitely not if you buy it from Wemoto Laughing
Finglonga
PostPosted: 21:19 - 29 Sep 2006    Post subject: Reply with quote
Before you buy a new chain and sprocket kit get the old chain to the tightest point then sit on the bike and get a friend/neighbour/goose/ferret? to check that the chain isnt too tight.
Reason is...........I had a KLR600 and it had a tight spot, I adjusted to the book on the tight spot and sat on the bike. The suspesion moved that much the chain was as tight as a drum with just my weight on it.
Andy Sez....
F.Y.Y.F.F.
chris___
PostPosted: 21:48 - 29 Sep 2006    Post subject: Reply with quote
Get a new one mate, my chains doing exactly the same thing and I'm skint aswell! but after seieng that picture I'd rather be even more skint than have my engine cases fooked!
Yamaha rxs100 > Kawasaki ZZR600 > Kawasaki ZX6R > Honda Hornet 600 > Honda Bros 400 > Suzuki SV650S K2
Bikepics page
cestrian
PostPosted: 00:33 - 30 Sep 2006    Post subject: Reply with quote
I had a similar noise from my GS500, although this is probably similar for any bike. I removed the cover and inspected the front sprocket, found it to be a bit loose on the splines. Also had to clean out a ton of crap from around the driveshaft and sprocket, dang that rea really does collect some sh1t.
I have a manual on CD if you want it.
veeeffarr
PostPosted: 21:08 - 03 Oct 2006    Post subject: Reply with quote
Do you think the chain could be too tight? There's an inch of play when the bike is on the centrestand, should I have adjusted with my weight on it?
There's also a faint metallic grinding noise from the rear brake disc when I spin the wheel, is this normal?
Cheers,
T
(PS: Got a loobman on order, I will get a C&S kit on it ASAP but need to wait until next month!)
irving
PostPosted: 21:45 - 03 Oct 2006    Post subject: Reply with quote
Mr. Green
Finglonga
PostPosted: 22:11 - 03 Oct 2006    Post subject: Reply with quote
How much play when your full weight on it in the chains tightest spot?
Andy Sez....
F.Y.Y.F.F.
veeeffarr
How hard is it to take the front sprocket cover off on this bike? Will I need a new gasket?
The last post was made 19 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 125.44 Kb
