Polishing stainless steel parts
loply
PostPosted: 15:16 - 30 Sep 2006    Post subject: Polishing stainless steel parts Reply with quote
Morning folks,
I took some 600 grit wet & dry and applied it to my stainless steel downpipes, and it turned them from brown/rust colored to silver.
But they're a sort of "dull" silver. Very clean looking, but definately not shiney.
Can they be polished up at all, or will the effect be too temporary?
Same applies for the heel plates on my rearesets.
Thanks for any tips!
Yamaha SZR660 Caution to the wind, the throttle pinned!
Whosthedaddy
PostPosted: 15:20 - 30 Sep 2006    Post subject: Reply with quote
My down pipes are the same, brown and rusty, rubbed down and now shiny but they wont stay that way for long.
Craigs23 please do not open
Thats what happens when you polish something and dont lacquer and protect it, I know my FZR is rusty, but Shocked Rolling Eyes
Cillit-BANG
PostPosted: 17:37 - 30 Sep 2006    Post subject: Reply with quote
The stainless steel will naturally brown (not rust) from the heat after a very short period of time. By all means clean off the surface rust but polishing them for appearance is short lived. A polishing mop for a drill is the best way to get them from dull to shiney. £20 usually gets you a good 3-grade set from ebay.
Stanless steel being quite hard will take a while to get a good polished finished. Personally I'd leave them at the dull stage.
As for the heel plates, it depends on what they are made of. If they are aluminium then said polishing kit will bring them to a mirror finish within a hour of working down the different grades.
jimbothe
PostPosted: 01:52 - 01 Oct 2006    Post subject: Reply with quote
I found a 1200 grit (much finer) worked well on my old zzr.I then polished over the top with autosol and it came up a treat (clean the nasty excess off first though before using the polish).Lasted around three months with a brilliant shine before it dulled a little but a quick once over again with autosol brought it back again.
I think using the 600 grit has scratched the pipes giving you the dull appearance which is a lot harder to polish out than finer scratches.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
ZRX61
Victor Meldrew
PostPosted: 02:32 - 01 Oct 2006    Post subject: Reply with quote
Is it bollocks. The "best" method is to take the pipes off & use a SS polishing compound with a bench mounted buffer/polisher.... (at least for home use...)
The only thing using a drill accomplishes is buggering up the thrust bearing in the drill by subjecting them to a sideload they aren't designed to handle..... Rolling Eyes
cestrian
PostPosted: 16:07 - 01 Oct 2006    Post subject: Reply with quote
I use Autosol on my pipes, although they are quite new.
Cillit-BANG
PostPosted: 16:22 - 01 Oct 2006    Post subject: Reply with quote
Dude, your getting pedantic.
Be it bench mounted or hand held, your ultimately getting the same goal; using a cloth wheel and a cutting compound to polish the pipework, which is what I was getting at.
Sure a bench mounted polisher is a beter solution but your average Joe is much more likely to have access to a drill than a bench grinder. And as for ruining your drill thats slightly OTT. I've polished loads of stuff using my drills and have never had any issues. The side loads are minimal as the pressure your applying is minimal and anything other than your Woolworths-special is more than up to the job.
Jesus, the stick my drills get at work, a little light polishing in comparison is a walk in the park.
colin1
Captain Safety
PostPosted: 18:09 - 01 Oct 2006    Post subject: Reply with quote
his custom title is victor meldrew
says it all really
mr jamez
PostPosted: 18:12 - 01 Oct 2006    Post subject: Reply with quote
When you can get a 550W mains drill for a tenner, who gives a toss if it doesn't last forever?
loply
PostPosted: 23:30 - 02 Oct 2006    Post subject: Reply with quote
Thanks for the advice folks, I'll try and post pics of the outcome. The downpipes look (and feel) gorgeous, and I havent got the polishing mop stage.
It'll be a shame when my new tires come and I ride it again...
Paddy Blake
PostPosted: 01:30 - 03 Oct 2006    Post subject: Reply with quote
Never laequer down pipes.
Pappy.
loply
PostPosted: 22:18 - 04 Oct 2006    Post subject: Reply with quote
I opted for the bench grinder route, bought a 350 watt 6" grinder, though I'm going to fit 8" mops to it and sort out various parts.
Impulsive buy Laughing Polished half my tools so far, just waiting on mops to arrive to do the bike itself.
The last post was made 19 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 73.22 Kb
