Need help finding starter solenoid on nsr125 (2001)?????????
abbas
PostPosted: 15:54 - 01 Oct 2006    Post subject: Need help finding starter solenoid on nsr125 (2001)????????? Reply with quote
Hi, Question Question
Can anyone describe where I can find the starter solenoid on an nsr125 (2001 model).
thanks
finpos
PostPosted: 16:29 - 01 Oct 2006    Post subject: Reply with quote
follow the big thick (red?) wire from the battery +ve terminal...
finpos.
cagiva gezzer
Halfway between the battery and the starter, attached to (at least) two thick wires.
At a guess
abbas
PostPosted: 17:31 - 01 Oct 2006    Post subject: Reply with quote
I found it.
Thank you very much.
another question: do you know how to check if its working properly.
thanks again. Question Question Question
finpos
PostPosted: 17:37 - 01 Oct 2006    Post subject: Reply with quote
You'll need a multimeter unless you want to make a shedload of sparks.
By the way, most of the time the problem is your battery is flat. Use a car battery and some jump leads to try and start the bike before you do anything else.
finpos.
abbas
PostPosted: 17:46 - 01 Oct 2006    Post subject: Reply with quote
I am going to try and get it hocked on to a car. hopefully it'll work that way and save a lot of time.
I've taken some of the front units off the bike. this includes the clocks, the front light, front fairing and clock mount. do you know if this would stop the bike from starting bearing in mind that the bike wasnt starting before I took these parts off.
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
abbas
PostPosted: 17:50 - 01 Oct 2006    Post subject: Reply with quote
finpos
PostPosted: 18:53 - 01 Oct 2006    Post subject: Reply with quote
If you interfered with the ignitions switch wiring, you may well have a problem. There's the kill switch to worry about too, but that's more likly to stop you from stopping the engine Smile
Clocks themselves and lights shouldn't (?) make a difference.
finpos.
The last post was made 20 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 55.76 Kb
