| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| stinkwheel |
| 5v3d3b0 |
| stinkwheel |
 Posted: 20:04 - 01 Oct 2006 Post subject: |
No sheared, SEIZED.
Something that has sheared would have snapped in two. Something that has seized would be stuck.
When you said you'd sheared the cylinder, I though you had cracked the liner of the barrel which could have lead to more serious problems.
So there was no coolant in the actual barrel? (over the top of the piston?)
A simple seizure, you should be able to get the barrel reconditioned providing it isn't too deeply scored. They are probably nikosil plated so this can be pretty expensive. Then it is a case of fitting a new piston kit and putting it all back together again with new gaskets.
As to filling the coolant system. If it is like any normal bike. You take the radiator filler cap off and fill it to the brim with coolant. Replace the cap and top-up the expansion bottle to between the max and min lines. You then run the engine for a few minutes to remove any air bubbles, top it up again and you're done. |
| 5v3d3b0 |
| jay_666 |
 jay_666 World Chat Champion
 Posted: 23:08 - 01 Oct 2006 Post subject: |
i think your're supposed to re-fill coolant through the radiator cap. ____________________ CBT - Done | Theory - Passed | Test - 4th Oct [PASSED!]
https://www.bikepics.com/members/jay666/ |
| Paddy Blake |
 Paddy Blake World Chat Champion
| 5v3d3b0 |
| stinkwheel |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| 5v3d3b0 |
| stinkwheel |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 01:51 - 02 Oct 2006 Post subject: Re: How to bleed a coolant system? + Some other questions |
| stinkwheel |
| 5v3d3b0 |
| finpos |
 finpos World Chat Champion
| 5v3d3b0 |
The last post was made 19 years, 352 days ago. Instead of replying here, would creating a new thread be more useful? |
