does my Neo's have a rare problem?
contoy
PostPosted: 10:25 - 02 Oct 2006    Post subject: does my Neo's have a rare problem? Reply with quote
hi all. first time here and i thought some one can be of help. i have this kind of rare(?) problem with my Yamaha Neo's scooter.
it sounds very simple: the motor always go out when i stand stil and doesn't react properly when i drive. i always have to play with the chock or pump up the gas handel...
what i tried already:
- I tuned the scooter stationery,
- i cleaned the carburator and other benzin tubes
- air filter is clean.
this all seem to be a very basic problem, never the less, the problem doesn't go away!
any ideas, help, suggestions? i'm puzzled!
thnx
contoy
finpos
PostPosted: 11:51 - 02 Oct 2006    Post subject: Reply with quote
You should look at the condition of the spark plug.
finpos.
hmmmnz
PostPosted: 15:37 - 02 Oct 2006    Post subject: Reply with quote
yep i would check the plug for a good spark, and make sure you don't have an air leak between the carb and the engine, (spray wd40 at the carb boot while running, if the revs change, then you have a air leak)
good luck.
where about are you based?? germany??
the humans are dead
I kick arse for the lord
contoy
PostPosted: 23:35 - 02 Oct 2006    Post subject: Reply with quote
will do. thnx for advice.
oh yeh, one more thing i forgot to mention that might clear this matter. after cleaning the carb it went perfectly but exactly 1 day after the problem return...
contoy
finpos
PostPosted: 00:03 - 03 Oct 2006    Post subject: Reply with quote
Is it possible your fuel tank has water in it? Maybe scooter was stood for a long time outside and fuel lid is faulty?
Try to drain carburettor float bowl, see if engine is better.
finpos.
contoy
PostPosted: 01:51 - 08 Oct 2006    Post subject: Reply with quote
problem fixed. i checked again the carb. there was something still stuck in there. my scooter runs again smoothly.
thnx for your input guys.
contoy
The last post was made 20 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 45.87 Kb
