photography help.
v4forlife
PostPosted: 14:03 - 02 Oct 2006    Post subject: photography help. Reply with quote
right, i have been really getting into photography recently, but the problem is, is that i juat got 3 rolls back(35mm canon rebel200, 28-80mm lens) and all of them are grainy.
why did this happen, and what may i be doing wrong??
www.wilcollinsphoto.co.uk
Suzuki
Roger
PostPosted: 14:09 - 02 Oct 2006    Post subject: Reply with quote
What ISO was the film you were using?
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
map
Mr Calendar
PostPosted: 14:10 - 02 Oct 2006    Post subject: Re: photography help. Reply with quote
v4forlife wrote:
...all of them are grainy....
Nice to see someone putting the effort into 'old fashioned' photography. Learning how to compose an image and adjust for lighting pays off if/when you move to digital.
On topic I'd first check the ASA/ISO was set right for the film you were using. Pushing up the rating for a film can result in a grainy image.
If set right then I'd look at what aperture size and light levels you had when taking the pics.
HTH Thumbs Up
Silver
PostPosted: 16:13 - 02 Oct 2006    Post subject: Reply with quote
As above, check you're using the correct speed film for the job and also have a look at lighting (i.e. your positioning in relation to the sun if you're outside).
Davo
Davo To The Rescue!
PostPosted: 16:17 - 02 Oct 2006    Post subject: Reply with quote
Just out of interest, where are you getting the films developed?
I've put some films in at Tesco a while back, got them back and they all came back really grainy.
Mjolnir
PostPosted: 19:04 - 02 Oct 2006    Post subject: Reply with quote
I had a film come back REALLY grainy a while ago. Couldn't think why and I went through a load of stuff trying to work out what I was doing wrong.
It seems my major mistake was using ancient film. I totally forgot about it and jammed a chunk of 35mm in the back of the camera that Noah had previously been using to document the building of the ark with.
You could always take it back to the place and ask them to check it for you. It could be their fault and hopefully they will sort it out. Have you used this camera before?
PostPosted: 19:58 - 02 Oct 2006    Post subject: Reply with quote
What's the exposure like? The light-reactive emulsion covering the film and paper is made up of lots of little crystals.
Bigger crystals react more quickly to the light, smaller ones more slowly. Every film will have a mixture of sizes of crystal on it.
Slower films have more of the small crystals, they respond more slowly to light but give a more detailed and less grainy picture.
Faster films have more of the larger crystals, they respond more quickly to the light but give a grainier picture.
The same happens with the paper.
So, you shouldn't be able to see the grains on a 200ASA film unless you magnify it a lot. BUT if you significantly underexpose it, only the bigger crystals will have time to respond to the light, you get a grainy picture.
I've done some pictures showing this, I have some film photos scanned in at very high resolution which shows the grains if you zoom in.
This picture shows a small part of exactly the same scene at full size. I picked it because I was fiddling with long exposures in the dark. Both have the same aperature setting (f5.6), both are on the same 200ASA film. The top one is fairly well exposed using a 10 second exposure, the bottom one is badly underexposed using a 4 second exposure. You should be able to see that the underexposed one is a lot grainier.
https://i48.photobucket.com/albums/f216/stinkwheel/overunder.jpg
This picture shows two well exposed pictures in good light conditions, using the same shutter speed and aperature (1/500s and f16). They are scanned using the same resolution. I have zoomed in on them 300% (so imagine the actual photo was the size of an A1 sheet of paper at this degree ofg detail). The top picture is a 400ASA film, the bottom one is a 200ASA film. The scanner reads the grains as a 'pixel' (no point in going for higher resolution than this). The difference in 'graininess' is obvious.
https://i48.photobucket.com/albums/f216/stinkwheel/filmspeed.jpg
divuk83
PostPosted: 21:12 - 02 Oct 2006    Post subject: Reply with quote
How old is the film? I had a roll sat in my old SLR for a few years before I got round to processing it before I sold the camera. They were pretty grainy when I got them back.
Dave
PostPosted: 21:34 - 02 Oct 2006    Post subject: Reply with quote
Another vote for checking the age of the film.
However it is quite possible to screw up developing the film and give some noticeable grain.
v4forlife
PostPosted: 12:43 - 03 Oct 2006    Post subject: Reply with quote
the film was 400isox2 and one 200, and i had one piece of film, well half a roll left over, from maybe a few months back, whenever hideout had their open day, and the others, i have no clue, from anywhere between 97, to 2001/2, lol. just found them and needed some film.
it is the dark parts of the picture that are like this, darker the part, ie shadow etc, then the higher the grain.
and yes, id rather get it right with film first then move over to digital.
ill post some of the pics when i get a chance.
PostPosted: 22:28 - 03 Oct 2006    Post subject: Reply with quote
Thinking this through (and please point out any hole in my logic), with more light meaning more grain to the image. If a dark part of the image has gone grainy then that suggests it is the paper that is causing the grain. If it was the film then the lighter sections of the final image would be grainy (as the lighter sections of the final image have had less light, but correspond to the darker sections of the negative which received more light).
All th ebest
LustyLew
PostPosted: 22:35 - 03 Oct 2006    Post subject: Reply with quote
Oh gawd, it was years ago I studies the theory of films and paper developing. That sounds on the right track though.
Not used my SLR in a while, must get it back out. Something satisfying about a 35mm photography, I think it's the phsyical result at the end. Smile
PostPosted: 02:14 - 04 Oct 2006    Post subject: Reply with quote
I suppose the only way to decide is to inspect the prints under high magnification. You should be able to differentiate the projected image of the grains on the film from the actual grains on the paper.
That's assuming the developers had their enlarger properly focused though, which in my experience is not a foregone conclusion.
Clanger
Stirrer
PostPosted: 09:33 - 04 Oct 2006    Post subject: Reply with quote
Best bet is to keep films in the fridge too.
v4forlife
PostPosted: 18:43 - 06 Oct 2006    Post subject: Reply with quote
here are some pics then.
these 2 are from the good film, maybe 3-4 months old.
https://i7.photobucket.com/albums/y253/v4forlife/CNV00026.jpg
https://i7.photobucket.com/albums/y253/v4forlife/CNV00002_2.jpg
the rest of these are from the old old film, between 4-8 years, not sure, found it in my room and needed some, so save me some money.
https://i7.photobucket.com/albums/y253/v4forlife/CNV00002.jpg
https://i7.photobucket.com/albums/y253/v4forlife/CNV00013-1.jpg
https://i7.photobucket.com/albums/y253/v4forlife/CNV00004.jpg
ali-b
PostPosted: 19:16 - 06 Oct 2006    Post subject: Reply with quote
It kinda *looks* like chroma noise (from the in car pic) with a high luminance content. If you can get your film scanned rather than on to paper you'd rule out the paper as the cause.
I thought chroma noise was a digital thing, but could be wrong...
Only ever used B&W film and certainly would expect a bit of grain at ISO400 - especially with my old dev gear Smile
I like the final rail slide (wide angle) picture though Smile
A.
v4forlife
PostPosted: 16:15 - 07 Oct 2006    Post subject: Reply with quote
yea, its a mates fisheye lens. he only remembered it at the last min, so i played with it for a bit.
The last post was made 19 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 97.17 Kb
